    MMM-Stock Cannot read property 'toLowerCase'
    34 Posts 2 Posters 14.8k Views 2 Watching
      brendan_c23 @sdetweil
      @sdetweil Yes I made that change, but the error was still coming up for me
        sdetweil @brendan_c23
        @brendan_c23 show me those 10 lines
          @sdetweil //if another currency is required - usd is default
          var differentCurrency = false;
          if(that.config.currency.toLowerCase() != “usd”){
          differentCurrency = true;
          var requiredCurrency = this.config.currency.toUpperCase();
          	for (var key in data) {
          		if (!data.hasOwnProperty(key)) {continue;}
          		var symbol = key;
          		var obj = data[key];
          		var current = obj[0];
          		var prev = obj[1];
          		var price = current["4. close"];
          		var change = prev["4. close"] - current["4. close"];
          		var html = "";
          		var priceClass = "greentext", priceIcon="up_green";
          		if(change < 0) {
          			priceClass = "redtext";
          			priceIcon="down_red";
            @brendan_c23 no, these, around line 90
            	scheduleUpdate: function(delay) {
            		var loadTime = this.config.updateInterval;
            		if (typeof delay !== "undefined" && delay >= 0) {
            			loadTime = delay;
            		var that = this;
            		setInterval(function() {
            			that.getStocks();
            			if(that.config.currency.toLowerCase() != "usd"){ // line 90 changed
            				that.getExchangeRate();
            		}, loadTime);
              @sdetweil Ok, I changed the ‘this’ to ‘that’ some lines above! not on those lines, going to try running it after changing the line you just sent
                @brendan_c23 just the ONE line, line 90…
                  brendan_c23
                  @sdetweil still waiting to see if it will display, theres a big delay, but no errors have popped up yet
                  if (typeof delay !== “undefined” && delay >= 0) {
                  loadTime = delay;
                  	var that = this;
                  		that.getStocks();
                  	}, loadTime);
                    @sdetweil No errors have come up, but it also has not displayed, have been waiting for around 10 minutes
                      @brendan_c23 did u change the other lines back?
                      open the developers window ctrl-shift-i, console tab, ‘stock’ in the filter field (no quotes)
                        @sdetweil They should be, but just in case Im missing something…
                        Module.register(“MMM-Stock”, {
                        result: {},
                        defaults: {
                        updateInterval: 60000,
                        fadeSpeed: 1000,
                        companies: [“GOOGL”, “YHOO”],
                        currency: “usd”,
                        baseURL: “https://www.alphavantage.co/”,
                        apikey: “IPWULBT54Y3LHJME”
                        getStyles: function() {
                        	return ["MMM-Stock.css"];
                        getTranslations: function() {
                        	return false;
                        start: function() {
                        	this.getStocks();
                        	if(this.config.currency.toLowerCase() != "usd"){
                        		this.getExchangeRate();
                        	this.scheduleUpdate();
                        getDom: function() {
                        	wrapper.className = "quotes";
                        	var list = document.createElement("ul");
                        	var data = this.result;
                        	// the data is not ready
                        	if(Object.keys(data).length === 0 && data.constructor === Object){
                        		return wrapper;
                        		var symbol = key;
                        		var prev = obj[1];
                        		var html = "";
                        		if(change < 0) {
                        		html = html + "<span class='" + priceClass + "'>";
                        		html = html + "<span class='quote'> (" + symbol + ")</span> ";
                        		html = html + parseFloat(price).toFixed(2) + " USD";
                        		html = html + "<span class='" + priceIcon + "'></span>" + parseFloat(Math.abs(change)).toFixed(2);
                        		var stock = document.createElement("span");
                        		stock.className = "stockTicker";
                        		stock.innerHTML = html;
                        		var listItem = document.createElement("li");
                        		listItem.innerHTML = html;
                        		list.appendChild(listItem);
                        	wrapper.appendChild(list);
                        	return wrapper;
                        		loadTime = delay;
                        	var that = this;
                        		that.getStocks();
                        	}, loadTime);
                        getStocks: function () {
                        	var allCompanies = this.config.companies;
                        	var urls = [];
                        	for(var company in allCompanies){
                        		var url = this.config.baseURL + "query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=" + allCompanies[company] + "&apikey=" + this.config.apikey;
                        		urls.push(url);
                        	this.sendSocketNotification("GET_STOCKS", urls);
                        getExchangeRate: function () {
                        	var url = this.config.baseURL + "?q=select%20*%20from%20yahoo.finance.xchange%20where%20pair%20in%20('USD" + this.config.currency + "')&format=json&diagnostics=true&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys&callback="
                        	this.sendSocketNotification("GET_EXCHANGE_RATE", url);
                        	if (notification === "STOCK_RESULT") {
                        		this.result = payload;
                        		this.updateDom(self.config.fadeSpeed);
                        	} else if(notification === "EXCHANGE_RATE"){
                        		this.rate = payload;
                          @sdetweil Load script: modules/MMM-Stock//MMM-Stock.js
                          module.js:517 Module registered: MMM-Stock
                          loader.js:148 Bootstrapping module: MMM-Stock
                          loader.js:153 Scripts loaded for: MMM-Stock
                          loader.js:195 Load stylesheet: modules/MMM-Stock/MMM-Stock.css
                          loader.js:155 Styles loaded for: MMM-Stock
                          loader.js:157 Translations loaded for: MMM-Stock
                            @brendan_c23 so, no errors
                            does the config entry have a position:
                            if not the content is thrown away
                              @sdetweil yes, and I remember there being a delay before when it worked (around 5 mins) , but never this long as I am yet to see it, but here is the config
                              module: “MMM-Stock”,
                              position: “bottom_right”,
                              companies: [“SPY”, “GME”, “AMC”, “NOK”, “BB”]
                                brendan_c23 @brendan_c23
                                @sdetweil Could you try running it with both my config entry and MMM-stock.js entry I’ve posted and let me know if it works for you?
                                  @brendan_c23 I have been doing that… it worked before, and doesn’t work now…
                                  the node_helper request for the stock info says that the response isn’t right…
                                    @sdetweil What do you think it could be? I am going to try copying original .js from hakanmhmd and make sure I didnt make any small changes I wasnt aware of , or maybe just delete and try to re download it
                                    S B 2 Replies Last reply Reply Quote 0
                                      @brendan_c23
                                      [06.03.2021 12:14.17.736] [LOG]   stock processing request urls=["https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=MSFT&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=GOOG&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=ORCL&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=FB&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=AAPL&apikey=xxxxxxxxxxxxxxxxx"]
                                      [06.03.2021 12:14.17.828] [LOG]   stock received request response
                                      [06.03.2021 12:14.17.828] [LOG]   stock request response no meta info
                                      the api is not returning the data expected… it was working for before with that one little change…
                                      I have tried all kinds of updates, but nothing resolves this issue…
                                      the module sent the request to the node helper, the helper is working thru the list, but never gets a good response
                                        @brendan_c23 Not completely sure on how to delete a module though, my Pi4 doesnt give me the option when right-clicking on the folder
                                          @brendan_c23 from the MagicMirror/modules folder
                                          rm -rf module_folder_name
                                          careful, rf - recursive force… get the wrong folder and there is no recovery
                                            @sdetweil Do you think I should delete it then redownload? Might be the companies… although they have worked before
