    MMM-Stock Cannot read property 'toLowerCase'
    34 Posts 2 Posters 12.5k Views 2 Watching
      sdetweil @brendan_c23
      @brendan_c23 ok, I see the error on refresh…
      change line 90 from
      	if(this.config.currency.toLowerCase() != "usd"){
      to
      	if(that.config.currency.toLowerCase() != "usd"){
        brendan_c23 @sdetweil
        @sdetweil Hey I tried that, now it says Cannot read property ‘toLowerCase’ of undefined at MMM-stock.js:90
        Any other suggestions?
        u are only changing the word this to the word that on that one line
          brendan_c23 @brendan_c23
          @brendan_c23 Uncaught TypeError: Cannot read property ‘toLowerCase’ of undefined
            @brendan_c23 you are only changing one word
            ‘this’ to the word ‘that’ on one line
              @sdetweil Yes I made that change, but the error was still coming up for me
                @brendan_c23 show me those 10 lines
                  @sdetweil //if another currency is required - usd is default
                  var differentCurrency = false;
                  if(that.config.currency.toLowerCase() != “usd”){
                  differentCurrency = true;
                  var requiredCurrency = this.config.currency.toUpperCase();
                  	for (var key in data) {
                  		if (!data.hasOwnProperty(key)) {continue;}
                  		var symbol = key;
                  		var obj = data[key];
                  		var current = obj[0];
                  		var prev = obj[1];
                  		var price = current["4. close"];
                  		var change = prev["4. close"] - current["4. close"];
                  		var html = "";
                  		var priceClass = "greentext", priceIcon="up_green";
                  		if(change < 0) {
                  			priceClass = "redtext";
                  			priceIcon="down_red";
                    @brendan_c23 no, these, around line 90
                    	scheduleUpdate: function(delay) {
                    		var loadTime = this.config.updateInterval;
                    		if (typeof delay !== "undefined" && delay >= 0) {
                    			loadTime = delay;
                    		var that = this;
                    		setInterval(function() {
                    			that.getStocks();
                    			if(that.config.currency.toLowerCase() != "usd"){ // line 90 changed
                    				that.getExchangeRate();
                    		}, loadTime);
                      @sdetweil Ok, I changed the ‘this’ to ‘that’ some lines above! not on those lines, going to try running it after changing the line you just sent
                        @brendan_c23 just the ONE line, line 90…
                        • 1 / 4
