    MMM-Stock Cannot read property 'toLowerCase'
    34 Posts 2 Posters 14.2k Views 2 Watching
      brendan_c23 @brendan_c23
      @brendan_c23 Uncaught TypeError: Cannot read property ‘toLowerCase’ of undefined
        sdetweil @brendan_c23
        @brendan_c23 you are only changing one word
        ‘this’ to the word ‘that’ on one line
          brendan_c23 @sdetweil
          @sdetweil Yes I made that change, but the error was still coming up for me
            @brendan_c23 show me those 10 lines
              @sdetweil //if another currency is required - usd is default
              var differentCurrency = false;
              if(that.config.currency.toLowerCase() != “usd”){
              differentCurrency = true;
              var requiredCurrency = this.config.currency.toUpperCase();
              	for (var key in data) {
              		if (!data.hasOwnProperty(key)) {continue;}
              		var symbol = key;
              		var obj = data[key];
              		var current = obj[0];
              		var prev = obj[1];
              		var price = current["4. close"];
              		var change = prev["4. close"] - current["4. close"];
              		var html = "";
              		var priceClass = "greentext", priceIcon="up_green";
              		if(change < 0) {
              			priceClass = "redtext";
              			priceIcon="down_red";
                @brendan_c23 no, these, around line 90
                	scheduleUpdate: function(delay) {
                		var loadTime = this.config.updateInterval;
                		if (typeof delay !== "undefined" && delay >= 0) {
                			loadTime = delay;
                		var that = this;
                		setInterval(function() {
                			that.getStocks();
                			if(that.config.currency.toLowerCase() != "usd"){ // line 90 changed
                				that.getExchangeRate();
                		}, loadTime);
                  @sdetweil Ok, I changed the ‘this’ to ‘that’ some lines above! not on those lines, going to try running it after changing the line you just sent
                    @brendan_c23 just the ONE line, line 90…
                      brendan_c23
                      @sdetweil still waiting to see if it will display, theres a big delay, but no errors have popped up yet
                      if (typeof delay !== “undefined” && delay >= 0) {
                      loadTime = delay;
                      	var that = this;
                      		that.getStocks();
                      	}, loadTime);
                        @sdetweil No errors have come up, but it also has not displayed, have been waiting for around 10 minutes
                          @brendan_c23 did u change the other lines back?
                          open the developers window ctrl-shift-i, console tab, ‘stock’ in the filter field (no quotes)
                            @sdetweil They should be, but just in case Im missing something…
                            Module.register(“MMM-Stock”, {
                            result: {},
                            defaults: {
                            updateInterval: 60000,
                            fadeSpeed: 1000,
                            companies: [“GOOGL”, “YHOO”],
                            currency: “usd”,
                            baseURL: “https://www.alphavantage.co/”,
                            apikey: “IPWULBT54Y3LHJME”
                            getStyles: function() {
                            	return ["MMM-Stock.css"];
                            getTranslations: function() {
                            	return false;
                            start: function() {
                            	this.getStocks();
                            	if(this.config.currency.toLowerCase() != "usd"){
                            		this.getExchangeRate();
                            	this.scheduleUpdate();
                            getDom: function() {
                            	wrapper.className = "quotes";
                            	var list = document.createElement("ul");
                            	var data = this.result;
                            	// the data is not ready
                            	if(Object.keys(data).length === 0 && data.constructor === Object){
                            		return wrapper;
                            		var symbol = key;
                            		var prev = obj[1];
                            		var html = "";
                            		if(change < 0) {
                            		html = html + "<span class='" + priceClass + "'>";
                            		html = html + "<span class='quote'> (" + symbol + ")</span> ";
                            		html = html + parseFloat(price).toFixed(2) + " USD";
                            		html = html + "<span class='" + priceIcon + "'></span>" + parseFloat(Math.abs(change)).toFixed(2);
                            		var stock = document.createElement("span");
                            		stock.className = "stockTicker";
                            		stock.innerHTML = html;
                            		var listItem = document.createElement("li");
                            		listItem.innerHTML = html;
                            		list.appendChild(listItem);
                            	wrapper.appendChild(list);
                            	return wrapper;
                            		loadTime = delay;
                            	var that = this;
                            		that.getStocks();
                            	}, loadTime);
                            getStocks: function () {
                            	var allCompanies = this.config.companies;
                            	var urls = [];
                            	for(var company in allCompanies){
                            		var url = this.config.baseURL + "query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=" + allCompanies[company] + "&apikey=" + this.config.apikey;
                            		urls.push(url);
                            	this.sendSocketNotification("GET_STOCKS", urls);
                            getExchangeRate: function () {
                            	var url = this.config.baseURL + "?q=select%20*%20from%20yahoo.finance.xchange%20where%20pair%20in%20('USD" + this.config.currency + "')&format=json&diagnostics=true&env=store%3A%2F%2Fdatatables.org%2Falltableswithkeys&callback="
                            	this.sendSocketNotification("GET_EXCHANGE_RATE", url);
                            	if (notification === "STOCK_RESULT") {
                            		this.result = payload;
                            		this.updateDom(self.config.fadeSpeed);
                            	} else if(notification === "EXCHANGE_RATE"){
                            		this.rate = payload;
                              @sdetweil Load script: modules/MMM-Stock//MMM-Stock.js
                              module.js:517 Module registered: MMM-Stock
                              loader.js:148 Bootstrapping module: MMM-Stock
                              loader.js:153 Scripts loaded for: MMM-Stock
                              loader.js:195 Load stylesheet: modules/MMM-Stock/MMM-Stock.css
                              loader.js:155 Styles loaded for: MMM-Stock
                              loader.js:157 Translations loaded for: MMM-Stock
                                @brendan_c23 so, no errors
                                does the config entry have a position:
                                if not the content is thrown away
                                  @sdetweil yes, and I remember there being a delay before when it worked (around 5 mins) , but never this long as I am yet to see it, but here is the config
                                  module: “MMM-Stock”,
                                  position: “bottom_right”,
                                  companies: [“SPY”, “GME”, “AMC”, “NOK”, “BB”]
                                    @sdetweil Could you try running it with both my config entry and MMM-stock.js entry I’ve posted and let me know if it works for you?
                                      @brendan_c23 I have been doing that… it worked before, and doesn’t work now…
                                      the node_helper request for the stock info says that the response isn’t right…
                                        @sdetweil What do you think it could be? I am going to try copying original .js from hakanmhmd and make sure I didnt make any small changes I wasnt aware of , or maybe just delete and try to re download it
                                        S B 2 Replies Last reply Reply Quote 0
                                          @brendan_c23
                                          [06.03.2021 12:14.17.736] [LOG]   stock processing request urls=["https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=MSFT&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=GOOG&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=ORCL&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=FB&apikey=xxxxxxxxxxxxxxxxx","https://www.alphavantage.co/query?function=TIME_SERIES_DAILY&outputsize=compact&symbol=AAPL&apikey=xxxxxxxxxxxxxxxxx"]
                                          [06.03.2021 12:14.17.828] [LOG]   stock received request response
                                          [06.03.2021 12:14.17.828] [LOG]   stock request response no meta info
                                          the api is not returning the data expected… it was working for before with that one little change…
                                          I have tried all kinds of updates, but nothing resolves this issue…
                                          the module sent the request to the node helper, the helper is working thru the list, but never gets a good response
                                            @brendan_c23 Not completely sure on how to delete a module though, my Pi4 doesnt give me the option when right-clicking on the folder
