    MMM-Stock Cannot read property 'toLowerCase'
    34 Posts 2 Posters 12.5k Views 2 Watching
      brendan_c23
      Stock module used to run just fine, now I am given this error when pulling up ‘npm start dev’ can anyone offer any guidance on how to fix this?
        sdetweil @brendan_c23
        @brendan_c23 usually this happens when a module retrieves data and EXPECTS success, but never really checks, or the data changes format.
        this specific error is related to a string (“abcdefgh”) and wanting to convert all the chars to lowercase before comapring… BUT the string didn’t get created…
        in json data its like this
        if(json_data.key.toLowerCase() ==‘test’)
        but the item changed name to Key, so its undefined.toLowercase()…
        or key is not a string anymore,
        but an object {}
        net, the code has to change
          brendan_c23 @sdetweil
          @sdetweil Could you help guide me on how to fix the code? Would you like me to post the .js file?
            @brendan_c23 which module is that
            this one works fine (with the example stocks)
            https://github.com/hakanmhmd/MMM-Stock
              @brendan_c23 ok, I see the error on refresh…
              change line 90 from
              	if(this.config.currency.toLowerCase() != "usd"){
              to
              	if(that.config.currency.toLowerCase() != "usd"){
                @sdetweil Hey I tried that, now it says Cannot read property ‘toLowerCase’ of undefined at MMM-stock.js:90
                Any other suggestions?
                u are only changing the word this to the word that on that one line
                  brendan_c23 @brendan_c23
                  @brendan_c23 Uncaught TypeError: Cannot read property ‘toLowerCase’ of undefined
                    @brendan_c23 you are only changing one word
                    ‘this’ to the word ‘that’ on one line
                      @sdetweil Yes I made that change, but the error was still coming up for me
                        @brendan_c23 show me those 10 lines
                        • 1 / 4
