    http connection denied despite open whiteList
    4 Posts 3 Posters 884 Views 3 Watching
    • K Offline
      Klinge
      I tried to connect to my MM via Firefox on Port 8080. By it doesn´t works. I got the error “connection refused”.
      When I tried to connect via telnet I get the error “connection error”.
      But my whiteList is completely open.
      My config is
      var config = {
              address: "localhost",   // Address to listen on, can be:
              electronOptions: {
              webPreferences: {
              webviewTag: true
              port: 8080,
              basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
              ipWhitelist: [],        //**** Set [] to allow all IP addresses
              useHttps: false,                // Support HTTPS or not, default "false" will use HTTP
              httpsPrivateKey: "",    // HTTPS private key path, only require when useHttps is true
              httpsCertificate: "",   // HTTPS Certificate path, only require when useHttps is true
              language: "de",
              logLevel: ["INFO", "LOG", "WARN", "ERROR"],
              timeFormat: 24,
      So I allow all IPs.
      My second MM has the same whiteList. And I can connect.
      It would be fine, when you have some good ideas for me to help.
      Thank you in advance.
      Lars
      F S 2 Replies Last reply Reply Quote 0
      • F Offline
        fribse @Klinge
        @klinge you are tying it to localhost only? If you do that, you can’t connect to it, it should be 0.0.0.0 or something like that?
        K 1 Reply Last reply Reply Quote 1
          sdetweil @Klinge
          @klinge localhost means only apps INSIDE the mm system can connect.
          • K Offline
            Klinge @fribse
            @fribse That´s it! I thought there must be something simple. I changed it to 0.0.0.0 and it works.
            Thanks to both of you for your help.
