    where can i set a colour for up/down in MMM-ServerStatus?
    20 Posts 5 Posters 6.1k Views 5 Watching
      chris47803
      Hello, I can’t find anything about where I can make this setting.
      It’s about this module :
      https://github.com/XBCreepinJesus/MMM-ServerStatus
      Chris
        sdetweil @chris47803
        @chris47803 did u read the README? clearly documents what to do
          chris47803
          I read it, but I don’t speak English very well. I don’t understand it though.
          It says:
          | upColor | String. Set a color for up / online results. This gets passed directly to the color setting of the<span>tag so it can be anything you can use in HTML / CSS styling (e.g.," green “or” # 00ff00 ").
          In which file do I have to enter the color?
            @chris47803 those settings go in the module entry in config.js
              chris47803
              Thank you.
              I understand that, but where exactly do I have to enter what?
              Can you please help me?
                      module: "MMM-ServerStatus",
                      header: "Network Devices",   // Can be anything you want, or blank
                      position: "top_right",       // Choose a position
                          hosts: [    // For example
              { ip: "192.168.2.2", name: "Fritz!Box"},
              { ip: "192.168.2.1", name: "Huelsen DC"},
              { ip: "192.168.2.5", name: "NAS 542"},
              { ip: "192.168.2.24", name: "Christian PC"},
              { ip: "192.168.2.23", name: "Marion PC"},
              { ip: "192.168.2.30", name: "Nikolai PC"},
              { ip: "192.168.2.34", name: "Wohnzimmer PC"},
              { ip: "192.168.2.29", name: "Christian NB"},
              { ip: "192.168.2.28", name: "Christian NB"},
              { ip: "192.168.2.37", name: "Nikolai NB"},
              { ip: "192.168.2.44", name: "Magic Mirror"},
              { ip: "192.168.2.27", name: "Christian A40"},
              { ip: "192.168.2.38", name: "Christian Tab A7"},
              { ip: "192.168.2.31", name: "Nikolai Honor 20 Pro"},
              { ip: "192.168.2.36", name: "Nikolai Honor"},
              { ip: "192.168.2.25", name: "Christian HTC"},
              { ip: "192.168.2.21", name: "Marion A40"},
              { ip: "192.168.2.104", name: "Drucker Schwarz"},
              { ip: "192.168.2.110", name: "Drucker Farbe"},
              { ip: "192.168.2.41", name: "Maxico Luftbefeuchter"},
              { ip: "192.168.2.48", name: "LG TV"},
              { ip: "192.168.2.35", name: "Link2Home Balkon"},
              { ip: "192.168.2.47", name: "Link2Home Schlafzimmer-Licht"},
              { ip: "192.168.2.45", name: "Link2Home Strauch"},
              { ip: "192.168.2.20", name: "Link2Home Garage"},
              { ip: "192.168.2.43", name: "Link2Home-Rose"},
              { ip: "192.168.2.32", name: "Unbekannt"},
              { ip: "192.168.2.33", name: "Unbekannt"},
              { ip: "192.168.2.50", name: "Unbekannt"},
              { ip: "192.168.2.40", name: "Unbekannt"},
              { ip: "192.168.2.39", name: "Unbekannt"},
              { ip: "192.168.2.46", name: "Unbekannt"},
              { ip: "192.168.2.26", name: "Unbekannt"}
                @chris47803 anywhere inside the config:{} section of the module.
                before or after the list of hosts.
                read the ‘how to add modules’ link in my signature below
                  chris47803
                  Many thanks for your response. But I can program badly in English and even worse. If I put it this way, Magic Mirror won’t start anymore.
                          upColor: "green",
                    @chris47803 do
                    npm run config:check
                    report the error…
                      chris47803
                      [13.03.2021 15:34.45.242] [INFO] Checking file… /home/pi/MagicMirror/config/ config.js
                      [13.03.2021 15:34.45.360] [ERROR] Your configuration file contains syntax errors :(
                      [13.03.2021 15:34.45.363] [ERROR] Line 182 col 2 Parsing error: Unexpected token ]
                        @chris47803 said in where can i set a colour for up/down in MMM-ServerStatus?:
                        so, what is on line 181?
                          chris47803
                          On line ist ]
                          its the end from modules: [
                            chris47803
                            Magic Mirror will now start again. But no color is displayed
                                    header: "MagicMirror status",   // Can be anything you want, or blank
                                    upColor: "green",
                            [13.03.2021 16:08.46.280] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
                            [13.03.2021 16:08.46.501] [INFO] Your configuration file doesn’t contain syntax errors :)
                              @chris47803 how about adding downColor: “red”,
                              i don’t know anything about the module myself…
                                @chris47803 the module uses a template and does this
                                {% for host in pingResults %}
                                			{% if host.isAlive %}
                                				<span style="color: {{ config.upColor }};" class="fas fa-{{ config.upSymbol }}"></span> {{ host.name }} {{ config.upText }}
                                			{% else %}
                                				<span style="color: {{ config.downColor }};" class="fas fa-{{ config.downSymbol }}"></span> {{ host.name }} {{ config.downText }}
                                			{% endif %}
                                			<br />
                                		{% endfor %}
                                  chris47803
                                  I got it. The color is for symbols only
                                  Thank you
                                          header: "Netzwerk",   // Can be anything you want, or blank
                                          upColor: "#00ff00",
                                          downColor: "#ff0000",
                                          upSymbol: "globe",
                                          downSymbol: "globe",
                                    @chris47803 ah
                                      miniashman @sdetweil
                                      Is there a way to left-align the device/network names and right-align the status? current view looks centred
                                      Screen Shot 2021-04-17 at 10.54.30 AM.png .
                                        miniashman @miniashman
                                        Solved, i figured it out but going through how it works on other modules. Just incase anyone else needs to know this is what I added to custom.css
                                        .MMM-ServerStatus table td {
                                          text-align: left !important;
                                          bdream
                                          Hey @miniashman great having your information here. That solved partwise my color problem, but I have shown my device, the colored icon and additional the word UP.
                                          I can’t find how to get rid of this word. I haven’t it in my config :angry_face:
        header: "",
        position: "top_center",
        upSymbol: "thumbs-up",
        upColor:  "#00ff00",
        downColor: "thumbs-down",
        hosts: [
        { name: "door-bell", ip: "192.168.0.6" },
                                          Any help for me?
                                          cheers, bdream
                                            sdetweil @bdream
                                            @bdream try
                                            upText:"",
                                            downText:""
                                            in the module config section
