    where can i set a colour for up/down in MMM-ServerStatus?
    20 Posts 5 Posters 5.4k Views 5 Watching
      sdetweil @chris47803
      @chris47803 did u read the README? clearly documents what to do
        chris47803
        I read it, but I don’t speak English very well. I don’t understand it though.
        It says:
        | upColor | String. Set a color for up / online results. This gets passed directly to the color setting of the<span>tag so it can be anything you can use in HTML / CSS styling (e.g.," green “or” # 00ff00 ").
        In which file do I have to enter the color?
          @chris47803 those settings go in the module entry in config.js
            chris47803
            Thank you.
            I understand that, but where exactly do I have to enter what?
            Can you please help me?
                    module: "MMM-ServerStatus",
                    header: "Network Devices",   // Can be anything you want, or blank
                    position: "top_right",       // Choose a position
                        hosts: [    // For example
            { ip: "192.168.2.2", name: "Fritz!Box"},
            { ip: "192.168.2.1", name: "Huelsen DC"},
            { ip: "192.168.2.5", name: "NAS 542"},
            { ip: "192.168.2.24", name: "Christian PC"},
            { ip: "192.168.2.23", name: "Marion PC"},
            { ip: "192.168.2.30", name: "Nikolai PC"},
            { ip: "192.168.2.34", name: "Wohnzimmer PC"},
            { ip: "192.168.2.29", name: "Christian NB"},
            { ip: "192.168.2.28", name: "Christian NB"},
            { ip: "192.168.2.37", name: "Nikolai NB"},
            { ip: "192.168.2.44", name: "Magic Mirror"},
            { ip: "192.168.2.27", name: "Christian A40"},
            { ip: "192.168.2.38", name: "Christian Tab A7"},
            { ip: "192.168.2.31", name: "Nikolai Honor 20 Pro"},
            { ip: "192.168.2.36", name: "Nikolai Honor"},
            { ip: "192.168.2.25", name: "Christian HTC"},
            { ip: "192.168.2.21", name: "Marion A40"},
            { ip: "192.168.2.104", name: "Drucker Schwarz"},
            { ip: "192.168.2.110", name: "Drucker Farbe"},
            { ip: "192.168.2.41", name: "Maxico Luftbefeuchter"},
            { ip: "192.168.2.48", name: "LG TV"},
            { ip: "192.168.2.35", name: "Link2Home Balkon"},
            { ip: "192.168.2.47", name: "Link2Home Schlafzimmer-Licht"},
            { ip: "192.168.2.45", name: "Link2Home Strauch"},
            { ip: "192.168.2.20", name: "Link2Home Garage"},
            { ip: "192.168.2.43", name: "Link2Home-Rose"},
            { ip: "192.168.2.32", name: "Unbekannt"},
            { ip: "192.168.2.33", name: "Unbekannt"},
            { ip: "192.168.2.50", name: "Unbekannt"},
            { ip: "192.168.2.40", name: "Unbekannt"},
            { ip: "192.168.2.39", name: "Unbekannt"},
            { ip: "192.168.2.46", name: "Unbekannt"},
            { ip: "192.168.2.26", name: "Unbekannt"}
              @chris47803 anywhere inside the config:{} section of the module.
              before or after the list of hosts.
              read the ‘how to add modules’ link in my signature below
                chris47803
                Many thanks for your response. But I can program badly in English and even worse. If I put it this way, Magic Mirror won’t start anymore.
                        upColor: "green",
                  @chris47803 do
                  npm run config:check
                  report the error…
                    chris47803
                    [13.03.2021 15:34.45.242] [INFO] Checking file… /home/pi/MagicMirror/config/ config.js
                    [13.03.2021 15:34.45.360] [ERROR] Your configuration file contains syntax errors :(
                    [13.03.2021 15:34.45.363] [ERROR] Line 182 col 2 Parsing error: Unexpected token ]
                      @chris47803 said in where can i set a colour for up/down in MMM-ServerStatus?:
                      so, what is on line 181?
                        chris47803
                        On line ist ]
                        its the end from modules: [
