Weatherbit Unit
16 Posts 6 Posters 3.0k Views 5 Watching
    Matthewlawson3
    Hi, I have been having a hard time finding a Weather module that allows a free API and works. I am trying out the MMM-NOAA3 module found out the link below and am trying to use Weatherbit. I need to change the units to Fahrenheit. Can I do this?
    Also, can anyone recommend a working good module besides NOAA3?
    link text
    G S B 3 Replies Last reply Mar 13, 2021, 7:58 PM Reply Quote 0
    • G Offline
      George @Matthewlawson3
      @matthewlawson3 Hi, I do not use this module but for other similar modules the change of temperature units, distance, wind measurement units … can be set in the module’s config.js. Search there.
      M 1 Reply Last reply Mar 14, 2021, 12:37 AM Reply Quote 0
        swvalenti Project Sponsor @Matthewlawson3
        @matthewlawson3
        https://github.com/jclarke0000/MMM-OpenWeatherForecast
          BKeyport Module Developer @Matthewlawson3
          @matthewlawson3 MMM-OpenWeatherForecast is the best.
          M 1 Reply Last reply Mar 13, 2021, 10:37 PM Reply Quote 0
            Matthewlawson3 @BKeyport
            @bkeyport I noticed that on the city list provided by Open Weather that it has the wrong latitude and longitude for my city. I’ll have to double check, but if I recall correctly it had it wrong.
            I don’t suppose one can input coordinates manually?
            S 1 Reply Last reply Mar 13, 2021, 10:51 PM Reply Quote 0
              scumbelly @Matthewlawson3
              @matthewlawson3
              All I did was go to Google maps, found my “village” coordinates and plugged them into lat and long in the config.sys and “Bob’s your uncle”.
              M 1 Reply Last reply Mar 14, 2021, 12:39 AM Reply Quote 0
                Matthewlawson3 @George
                @george Thanks. I tried using “unit” in the config area of the module and set it to imperial and also tried just the letter “I” and when I launched with npm start it said something was wrong with the config file.
                  Matthewlawson3 @scumbelly
                  @scumbelly this was with OpenWeather? If so, I’ll try that rather than going through the OpenWeather city ID list and looking for my city.
                  S 1 Reply Last reply Mar 14, 2021, 1:11 PM Reply Quote 0
                    @matthewlawson3
                    From the module .js file…
                    Module.register(“MMM-OpenWeatherForecast”, {
                    This module uses the Nunjucks templating system introduced in
                    version 2.2.0 of MagicMirror. If you’re seeing nothing on your
                    display where you expect this module to appear, make sure your
                    MagicMirror version is at least 2.2.0.
                    requiresVersion: “2.2.0”,
                    defaults: {
                    apikey: “”,
                    latitude: “”,
                    longitude: “”,
                    …and add lat and long into the config.js (sorry for wrong extension in earlier post).
                    Example,
                    			module: "MMM-OpenWeatherMapForecast",
                    			disabled: false,
                    			header: "",
                    			apikey: "wholelottanumbers",
                    			latitude: "4X.XXXXXX",
                    			longitude: "-7X.XXXXXX",
                    			iconset: "4c",
                    			concise: false,
                    			forecastLayout: "table",
                    			showCurrentConditions: false,
                    			showExtraCurrentConditions: false,
                    			showSummary: false,
                    			showForecastTableColumnHeaderIcons: false
                    Cheers
                    M 2 Replies Last reply Mar 14, 2021, 7:16 PM Reply Quote 0
                      @scumbelly @scumbelly I am running version 2.14.0
                      I don’t see that particular information in the config file. Below is what I see. Do I need to install OpenWeather from the 3rd party modules even though it was pre-installed? Or can I just copy and paste in what you have given me?
                      module: “currentweather”,
                      position: “top_right”,
                      locationID: “5128581”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      appid: “YOUR_OPENWEATHER_API_KEY”
                      module: “weatherforecast”,
                      header: “Weather Forecast”,
