    Config file not found
    12 Posts 5 Posters 4.0k Views 5 Watching
      mintpizza
      Hello guys, I m making my first mirror and when I add a module to the config file it stops working, but the orignal code works perfectly fine, and a new module code makes it think there is a error even when it is perfectly fine. I tried to use the inbuilt checker and it is worse. It was giving me errors on things like clock and calander and wanting me to remove all the modules. Is there any way I can put the modules? Thanks!
        sdetweil @mintpizza
        @mintpizza read the links in my signature below
        any syntax error can really generate a lot of errors.
        I would need to see the output of
        npm run config:check
        to help more.
          mintpizza @sdetweil
          @sdetweil the output tells that clock, calander or etc module lines are unknown or not required
            mintpizza @sdetweil
            @sdetweil I saw the signature and redid everything to confirm but the result was same, Config not found
              sdetweil @mintpizza
              @mintpizza again show me the output and the config file
              • cowboysdudeC Offline
                Just copy your config file here…
                  mintpizza
                  pi@raspberrypi:~/MagicMirror/config $ npm run config:check
                  > magicmirror@2.14.0 config:check /home/pi/MagicMirror
                  > node js/check_config.js
                  [18.03.2021 09:29.40.609] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                  [18.03.2021 09:29.40.676] [ERROR] Your configuration file contains syntax errors :(
                  [18.03.2021 09:29.40.678] [ERROR] Line 49 col 3 Parsing error: Unexpected token {
                    mintpizza
                    /* Magic Mirror Config Sample
                     * By Michael Teeuw https://michaelteeuw.nl
                     * MIT Licensed.
                    var config = {
                    	address: "localhost", 	// Address to listen on, can be:
                    	port: 8080,
                    	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    	modules:
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			header: "US Holidays",
                    						symbol: "calendar-check",
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "currentweather",
                    				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                    	module: "MMM-cryptocurrency",
                    		apikey: '1234-5678-9009-8765-4321',
                    		currency: ['ethereum', 'bitcoin'],
                    		conversion: 'EUR',
                    		headers: ['change24h', 'change1h', 'change7d'],
                    		displayType: 'logoWithChanges',
                    		showGraphs: true
                    • BKeyportB Offline
                      BKeyport Module Developer @mintpizza
                      @mintpizza said in Config file not found:
                      	modules:
                      should be
                      	modules:  [
                      As a start.
                        mintpizza @BKeyport
                        @BKeyport I wrote this and still check wants me to delete all mdules
                         * MIT Licensed.
                        var config = {
                        	port: 8080,
                        	language: "en",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: "alert",
                        			position: "top_bar"
                        			module: "newsfeed",
                        				feeds: [
                        		conversion: 'EUR',
                        		showGraphs: true
                          mintpizza @mintpizza
                          @mintpizza
                          [18.03.2021 09:56.31.426] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
                          [18.03.2021 09:56.31.476] [ERROR] Your configuration file contains syntax errors :(
                          [18.03.2021 09:56.31.478] [ERROR] Line 45 col 10 Parsing error: Unexpected token :
                            BravoOscar @mintpizza
                            @mintpizza
                            You are missing a {
                            before module: “updatenotification”,
                            It should be:
                            			module: "alert",
                            			position: "top_bar"
