    Fan control
    7 Posts 4 Posters 2.1k Views 3 Watching
    • brobergB Offline
      broberg Project Sponsor
      or just a 12v supply with a relay that reacts to the 3v/5v output of the raspberrys gpio …
      or just a relay if you already have the 12v supply.
        bibi @broberg
        @broberg thx for your input. As mentioned above, i wanted to avoid using a relay to have a silent system
        • brobergB Offline
          broberg Project Sponsor @bibi
          @bibi fan controllers are cheap.
          or get 5v fans?
            bibi @broberg
            @broberg have already a 5v fan… i am rather interested in gaining knowledge about transistors by building a “project” to cool down my whole MM system.
            • H Offline
              harney
              Here is a great system. Fully automatic and silent(ish) with variable control. Took about 5 minutes to make a small board with the resistors and diode and the code is already done.
              [link text]https://www.instructables.com/PWM-Regulated-Fan-Based-on-CPU-Temperature-for-Ras/(link url)
              • JerryPJ Offline
                JerryP @bibi
                @bibi
                I use this one
                https://www.elektor.nl/fan-shim-active-cooling-for-raspberry-pi-4
                works ferry well
