    Annual Dates are off by one day in default Calendar module
    calendardaterepeating
    17 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @ctkjedi
      @ctkjedi well, in this particular case the daylight savings adjustment calculation is wrong, so we get off a day
      in 1952, DST starts on April 27th
      in 1992. DST starts on April 5th
      in 2007 DST starts on March 11
      the date/time gave me the right offset but i ‘assumed’ it was same as now…
      if u reset the start year of the entry to 2008, it comes out right…
      next release is on april 1st… don’t know if I can get this change in by then
        ctkjedi @sdetweil
        @sdetweil goddang daylight saving time! I really hope they follow through this time and get rid of it.
        I’m not really sure where the start date was set though. I only added it to this particular calendar a few days ago and there isn’t a way, that I can see, to edit it.
          sdetweil @ctkjedi
          @ctkjedi I submitted a fix for this issue, #2483
          and the fix has been accepted for next release.
            ctkjedi @sdetweil
            @sdetweil Awesome. thanks for the follow up!
              ctkjedi
              @sdetweil This may or may not be related, so I’m happy to start a new thread.
              I have a weekly D&D game, scheduled for every Saturday evening. The ICS reads as
              BEGIN:VEVENT
              DTSTART;TZID=America/Los_Angeles:20210319T200000
              DTEND;TZID=America/Los_Angeles:20210319T230000
              DTSTAMP:20210316T001016Z
              UID:**REDACTED**
              RECURRENCE-ID;TZID=America/Los_Angeles:20210320T200000
              CREATED:20210213T021153Z
              DESCRIPTION:**REDACTED**
              LAST-MODIFIED:20210315T194037Z
              SEQUENCE:1
              STATUS:CONFIRMED
              SUMMARY:D&D
              TRANSP:OPAQUE
              END:VEVENT
              However, I rescheduled this week’s event for Friday, which reflects correctly on Google Calendar, but now all the entries on the mirror have been re-calculated as being on every Friday going forward.
                sdetweil @ctkjedi
                @ctkjedi can u show the updated ics event with the rule (repeating rule)…
                this one is not repeating
                  ctkjedi @sdetweil
                  BEGIN:VEVENT
                  DTSTART;TZID=America/Los_Angeles:20210227T200000
                  DTEND;TZID=America/Los_Angeles:20210227T230000
                  RRULE:FREQ=WEEKLY;BYDAY=SA
                  UID:**REDACTED**
                  LAST-MODIFIED:20210227T015344Z
                  SEQUENCE:0
                  STATUS:CONFIRMED
                  SUMMARY:D&D
                  TRANSP:OPAQUE
                  END:VEVENT
                    sdetweil @ctkjedi
                    @ctkjedi thanks… I submitted fix #2488 for this… the library that does repeating rules ASSUMES the date is in local time, not utc time (from the ical parser library)
                    this fix has also been accepted for next release (April 1)
                      ctkjedi @sdetweil
                      @sdetweil Rockin!
                        Memphismark @ctkjedi
                        @ctkjedi The module is fine. Well, kinda. I had a problem where weekly events were showing up 6 days late. My problem was I had Google Calendar repeat frequency set to “weekly.” It started working when I set it to “every 7 days.”
                        Adjust the frequency on Google and see what it does.
                          sdetweil @Memphismark
                          @memphismark thanks. there were a couple more bugs related to daylight savings, and full day events.
                          one more fix to go in
                            Memphismark @sdetweil
                            @sdetweil said in Annual Dates are off by one day in default Calendar module:
                            Specifically, it was a weekly occurrence that started after 6pm on Saturdays. It worked fine any other time and DOW. It busted my brain until I solved it by doing the IDIC thing. :-)
                              @memphismark idic?
