    How to use this module? Please help!
    2 Posts 2 Posters 509 Views 2 Watching
      rubens
      https://github.com/zuo000/MMM-HomeAssistant.
      I don’t find any information. The integration with Home Assistant it would be unbelievable.
      Can someone help me? Are there other modules? Is it possible that there is no way to control directly from the mirror at least the simplest entities such as lights?
      lavolp3L 1 Reply Last reply
      • lavolp3L
        lavolp3 Module Developer @rubens
        @rubens Well the config options seem self-explanatory. You need to create an accessToken inside home assistant however.
        THere are some other MMM Home Assistant modulesout there, e.g. MMM-HomeAssistant-sensors by @snille.
        Or https://github.com/aserramonner/MMM-HASS by aserramonner.
        You could have a look at these as well.
        It is very possible that the module only gives a status since most MM modules are not programmed to be interactive but only to provide information.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
