MM Install Error
Hi!
I’m trying to install MM on a RP 4 . I followed the Manual Installation steps , however, from step two on scripts indicate no file or directory. This is all new to me so your advice will be much appreciated!pi@raspberrypi:~ $ https://github.com/MichMich/MagicMirror bash: https://github.com/MichMich/MagicMirror: No such file or directory pi@raspberrypi:~ $ cd MagicMirror/ bash: cd: MagicMirror/: No such file or directory pi@raspberrypi:~ $ npm install npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json' npm notice created a lockfile as package-lock.json. You should commit this file. npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm WARN pi No description npm WARN pi No repository field. npm WARN pi No README data npm WARN pi No license field. up to date in 0.797s found 0 vulnerabilities pi@raspberrypi:~ $ cp config/config.js.sample config/config.js cp: cannot stat 'config/config.js.sample': No such file or directory pi@raspberrypi:~ $ npm run start npm ERR! code ENOENT npm ERR! syscall open npm ERR! path /home/pi/package.json npm ERR! errno -2 npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm ERR! enoent This is related to npm not being able to find a file. npm ERR! enoent npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2021-03-26T07_35_06_236Z-debug.log pi@raspberrypi:~ $
@etatsu you have the first command wrong.
You need to put ingit clone https://github.com/MichMich/MagicMirror
And please PLEASE take care when the system throws errors at you Basically all answers you got from the system on the way told you something’s wrong.
Thank you for your help!
