    MMM-Strava
    Scheduled Pinned Locked Moved Health
    activity trackerhealthstrava
    138 Posts 34 Posters 288.8k Views 35 Watching
      sdetweil @gab0ru
      @gab0ru don’t know… please use code block for any config items…
      paste the text, select the text, push the button above the editor, </>
        mike2323
        When using table or chart the activities config seems to be ignored, and just shows ride, run and swim. However, if I used the radial option, then it respects the config and just shows the rides. Is there another setting I’m missing to just shows rides in chart view?
        I 1 Reply Last reply
        • I
          ianperrin @mike2323
          @mike2323 the activities option should work for the table and chart modes. Could you check you are using the latest version and post your config for the module (removing or masking the client id and secret)?
          Here’s a working example
                      module: "MMM-Strava",
                      header: "Strava",
                          client_id: "000000",
                          client_secret: "z793xxxxxxxxxxxxxxxxxxxx498d2",
                          mode: "chart",
                          activities: ["ride"],
                          period: "ytd"
          If you want two activities, you can enter them as follows: activities: ["ride", "run"]
          “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
          A M 2 Replies Last reply
          • A
            antsve @ianperrin
            @ianperrin Have been trying to set up multiple instances of the module but which ever user is authenticated last will be the one whos stats are shown in all (both) the instances. Tried autheniticating, resstarting container and authenticating other module but with no sucess. Do you know where I’m going wrong or could you aid me in some direction?
            ps. both modules use the same client_id and client_secret, but that shuld not matter right?
            GREAT module by the way !
            A 1 Reply Last reply
            • A
              antsve @antsve
              here’s my config:
                      position: "bottom_right",
                      header: "Anton",
                          client_id: "23___",
                          client_secret: "a9ea3d50442______________72f4ca93a792",
                          activities: ["run", "ride"],
                          mode: "chart",
                          chartType: "bar",
                          period: 'ytd',
                          updateInterval: 5000000,
                      header: "Sofia",
                          client_id: "23___",
                          mode: "chart",
                          chartType: "bar",
                          period: 'ytd',
                mike2323 @ianperrin
                @ianperrin Sorry for the delayed reply, I’ve just got around to looking at my Mirror config again. Have updated to the latest version and here is the config for MMM-Strava:
                			   position: "bottom_left",
                			   header: "Michael's Garage Rides",
                			        client_id: "00000",
                			        client_secret: "cxxxxxxxxxxxxxxxxxxxxxxxxxb",
                				mode: "chart",
                				activites: ["ride"],
                				period: "ytd",
                			   header: "Stephen's Garage Rides",
                			       client_id: "00000",
                				mode: "chart",
                				activites: "ride",
                				period: "ytd",
                And here is a photo of how it appears on the Mirror (showing ride, run and swim instead of just ride).
                alt text
                Thanks for the help (and the great module)
                  Jan
                  Hey @ianperrin.
                  First of all thx for you wonderful module. I have one question - I have added “rowing” as activity which works fine - excepted the symbol for rowing is not working. Is it possible to reference that symbol more or less easy in the sourcecode ?
                  Thx in advance
                  Jan
                  • I
                    ianperrin @Jan
                    @jan support for additional activities in chart mode is in the works, keep an eye out for updates ;)
                    Reply Quote 2
                    • I
                      ianperrin @mike2323
                      @mike2323 said in MMM-Strava:
                      If this is still causing problems, can you try making sure the activities option is specified as an array, even if only one activity type is required? It looks like you haven’t done this in the options for the second module definition
                      In other words:
                        Jan
                        @ianperrin thx so much!!! Works fine, looks amazing!
                        • joela85J
                          joela85
                          My Strava module needs to be re-authorised every few days or at least once a week. I’m not sure what is causing this. Has anyone else had a similar issue?
                          • F
                            fox
                            Can we aggregate virtual ride together with ride for the mirror?
                            Issues With MMM-WatchDog known?
                            https://forum.magicmirror.builders/post/29827
                            Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                            • K
                              kevmang
                              Great app @ianperrin. Looks slick on the mirror too!
                              M 1 Reply Last reply
                                MisterT @kevmang
                                @ianperrin i use Strava module for my mirror but recently Strava update api and now I have the message : 429 limits exceed. I changed reloadinterval to 15601000 and updateinterval to 60*1000 but still the same message.
                                Have you an idea ?
                                Thx for next answer
                                  sdetweil @MisterT
                                  @MisterT 60*1000 is every minute,
                                  1440 times a day
                                  their limit us 100/15 minutes and 1000/ day
                                  • 7 / 7
