    Help with a couple CSS issues
    22 Posts 4 Posters 36.1k Views 7 Watching
      sdetweil @Nneuland
      @nneuland to close the developer window u can click the close x in the top right, or ctrl-shift-i again
      • N Offline
        Nneuland @sdetweil
        For the NYC-Transit module Changing the font size within the the developers window was smooth as silk.
        However, scaling in the custom.css has yielded nothing.
        I have attached a screenshot of what I believe is the proper location.
        Removing the duration of individual albums seems more difficult considering every album in the collection is different, or it doesn’t have a location at all due to not being in the description.
        To clarify, I should be modifying the “custom.css” (blank by default) file. not amending the specific mmm-nyc-transit.css or mmm-discogs.css files?Nyc_transit_font.jpg
          sdetweil @Nneuland
          @nneuland so, in custom.css you need this pattern
          .modulename (space) .classname {
              stylename: value;
          SO, in this case from the dev window
          go up to the module_11_MMM-nyc-transit
          remove the module_11_ prefix and add a dot
          .MMM-nyc-transit
          then we need the class name of the element u want to change
          mta__train–list (add a dot in front)
          now we have
          .MMM-nyc-transit   .mta__train--list {
          it IS font-size: medium;
          in main.css
          .medium {
            font-size: 30px;
            line-height: 35px;
          u want to change that, SO
                  font-size:   20px;
          • N Offline
            Nneuland
            YES!!! My spacing was allllllll off.
            You’re a genius! Thank you so much.
            You have the patience of a saint
            N
              sdetweil @Nneuland
              @nneuland yes, spacing is critical… it means something else if there are NO spaces between items in the selector list ( stuff before open brace { )
              something worth reading
              https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
              • N Offline
                Nneuland
                Your so knowledgeable with this realm.
                Can I ask, what you know about the hue module?
                Specifically, is it only displaying what lights are on, or is it interactive?
                I’m genuinely curious what your smart mirror looks like.
                If you have one, I imagine it’s incredible.
                N
                  sdetweil @Nneuland
                  @nneuland i am a moderator… i don’t know much about specific modules…
                  I know HOW to do some debugging and some limited css…
                  I also do the scripted installer and upgrader tools
                  i have 5 single board computers running different things… Pi0, Pi3, Pi4, Jetson Nano, and Odroid Xu4. also a vm with Macos catalina, and my desktop running ubuntu.
                  and I know how to google for answers…
                  there are lots of talented folks here… I reference their work. all the time…
                  N 1 Reply Last reply Reply Quote 1
                  • N Offline
                    Nneuland @sdetweil
                    That’s great. Can’t thank you enough.
                      matt216
                      @sdetweil I wonder if I can ask for some help? I have MMM-ip module that I’d like the change the font size. Following your instructions with dev tools I can see:
                      So I have put in my custom.css:
                      .MMM-ip .dimmed {
                      font-size: 16px;
                      But it doesn’t seem to take effect. Any advice?
                      Thanks in advance.
                      Matt
                        sdetweil @matt216
                        @matt216 while in the dev window,
                        u can see the custom.css value is strike thru, cause the div wins
                        so u need to apply the style to the div
                        add it to the element box above.
                        if that works, you can mark/copy that top right box, and paste to custom.css, should have the right targeting syntax
