    Help with a couple CSS issues
    22 Posts 4 Posters 36.9k Views 7 Watching
    • N Offline
      Nneuland @sdetweil
      For the NYC-Transit module Changing the font size within the the developers window was smooth as silk.
      However, scaling in the custom.css has yielded nothing.
      I have attached a screenshot of what I believe is the proper location.
      Removing the duration of individual albums seems more difficult considering every album in the collection is different, or it doesn’t have a location at all due to not being in the description.
      To clarify, I should be modifying the “custom.css” (blank by default) file. not amending the specific mmm-nyc-transit.css or mmm-discogs.css files?Nyc_transit_font.jpg
        sdetweil @Nneuland
        @nneuland so, in custom.css you need this pattern
        .modulename (space) .classname {
            stylename: value;
        SO, in this case from the dev window
        go up to the module_11_MMM-nyc-transit
        remove the module_11_ prefix and add a dot
        .MMM-nyc-transit
        then we need the class name of the element u want to change
        mta__train–list (add a dot in front)
        now we have
        .MMM-nyc-transit   .mta__train--list {
        it IS font-size: medium;
        in main.css
        .medium {
          font-size: 30px;
          line-height: 35px;
        u want to change that, SO
                font-size:   20px;
        • N Offline
          Nneuland
          YES!!! My spacing was allllllll off.
          You’re a genius! Thank you so much.
          You have the patience of a saint
          N
            sdetweil @Nneuland
            @nneuland yes, spacing is critical… it means something else if there are NO spaces between items in the selector list ( stuff before open brace { )
            something worth reading
            https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
            • N Offline
              Nneuland
              Your so knowledgeable with this realm.
              Can I ask, what you know about the hue module?
              Specifically, is it only displaying what lights are on, or is it interactive?
              I’m genuinely curious what your smart mirror looks like.
              If you have one, I imagine it’s incredible.
              N
                sdetweil @Nneuland
                @nneuland i am a moderator… i don’t know much about specific modules…
                I know HOW to do some debugging and some limited css…
                I also do the scripted installer and upgrader tools
                i have 5 single board computers running different things… Pi0, Pi3, Pi4, Jetson Nano, and Odroid Xu4. also a vm with Macos catalina, and my desktop running ubuntu.
                and I know how to google for answers…
                there are lots of talented folks here… I reference their work. all the time…
                N 1 Reply Last reply Reply Quote 1
                • N Offline
                  Nneuland @sdetweil
                  That’s great. Can’t thank you enough.
                    matt216
                    @sdetweil I wonder if I can ask for some help? I have MMM-ip module that I’d like the change the font size. Following your instructions with dev tools I can see:
                    So I have put in my custom.css:
                    .MMM-ip .dimmed {
                    font-size: 16px;
                    But it doesn’t seem to take effect. Any advice?
                    Thanks in advance.
                    Matt
                      sdetweil @matt216
                      @matt216 while in the dev window,
                      u can see the custom.css value is strike thru, cause the div wins
                      so u need to apply the style to the div
                      add it to the element box above.
                      if that works, you can mark/copy that top right box, and paste to custom.css, should have the right targeting syntax
                        matt216 @sdetweil
                        @sdetweil Thanks for the help.
                        How do I reference the div in custom.css not the class?
                        Adjusting the value in the element box above successfully adjusts the font, but this looks to adjust the ‘dimmed’ class.
