    Help with a couple CSS issues
    22 Posts 4 Posters 44.9k Views 7 Watching
      sdetweil @Nneuland
      @nneuland i am a moderator… i don’t know much about specific modules…
      I know HOW to do some debugging and some limited css…
      I also do the scripted installer and upgrader tools
      i have 5 single board computers running different things… Pi0, Pi3, Pi4, Jetson Nano, and Odroid Xu4. also a vm with Macos catalina, and my desktop running ubuntu.
      and I know how to google for answers…
      there are lots of talented folks here… I reference their work. all the time…
      N 1 Reply Last reply Reply Quote 1
      • N Offline
        Nneuland @sdetweil
        That’s great. Can’t thank you enough.
          matt216
          @sdetweil I wonder if I can ask for some help? I have MMM-ip module that I’d like the change the font size. Following your instructions with dev tools I can see:
          So I have put in my custom.css:
          .MMM-ip .dimmed {
          font-size: 16px;
          But it doesn’t seem to take effect. Any advice?
          Thanks in advance.
          Matt
            sdetweil @matt216
            @matt216 while in the dev window,
            u can see the custom.css value is strike thru, cause the div wins
            so u need to apply the style to the div
            add it to the element box above.
            if that works, you can mark/copy that top right box, and paste to custom.css, should have the right targeting syntax
              matt216 @sdetweil
              @sdetweil Thanks for the help.
              How do I reference the div in custom.css not the class?
              Adjusting the value in the element box above successfully adjusts the font, but this looks to adjust the ‘dimmed’ class.
                sdetweil @matt216
                @matt216 and when u copy/paste that from the top box to custom.css, what do u get?
                just swipe mark the element entry, copy
                here is my favorite cheet sheet on css selectors
                https://www.w3schools.com/cssref/css_selectors.asp
                  I’m guessing
                  .MMM-ip  .dimmed div {
                       font-size:16px;
                    matt216 @sdetweil
                    @sdetweil Thank you, this works:
                         font-size:16px;
                      sdetweil @matt216
                      @matt216 what did the copy/paste result look like?
                      • A Anthony referenced this topic on
                        Shawangunk
                        I’m a raspi & linux newbie (used C years ago. some Arduino experience) and this is my first post so…
                        In attempting to modify MM I’ve experienced a number of custom.css failures. I found this @sdetweil post https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1623901330356 and believe the “developer Tools” will be a big help, but I quickly got lost. The Tool’s built in help doc (kebab>Help>Documentation) appears to be a null link. I tried to find documentation for this tool online without luck. Can anyone provide a documentation link or more detailed tutorial?
                        • S Shawangunk referenced this topic on
                          sdetweil @Shawangunk
                          @Shawangunk this would be all in the/a browser, nothing w mm.
                          I have never seen any doc
                            @Shawangunk see this
                            https://developer.chrome.com/docs/devtools/
                            but this will not teach u the DOM, css, html (and attributes)
                            only provides tool to examine and change Dom element styles
                              Shawangunk
                              All help at the bottom of the curve is appreciated. Thank you. Cheers
                              • K kasperinline referenced this topic on
                              • R ruff.hi referenced this topic on
                              • M movingfish referenced this topic on
                              • C com1cedric referenced this topic on
