    Help with a couple CSS issues
    22 Posts 4 Posters 44.9k Views 7 Watching
      sdetweil @Nneuland
      @nneuland time to learn the developers window
      on the MM screen, press ctrl-shift-i, a new window will open beside your mm screen
      select the elements tab
      in the upper left corner of the elements page is a pointer symbol (box with mouse pointer in it) , click it with the mouse
      and then use your mouse to locate the content in the MM screen u want to analyze
      (as u navigate, different areas of content will be highlighted)
      click on the content u are interested in… and the web page tree will open to that content (pink). and the bottom of the page will show the class name list left to right(green), with rightmost the one set closest to the content, left most set by MM
      also on the right column is the class hierarchy, closest at the top, furthest MM further down…
      SO, you want to find the class that sets the fontsize, and edit the topmost right column entry (black) field to add a new fontsize and see it change (Mothers day entry in this example is a different font size now)
      so, now you know what and where
      so, in custom.css you add and entry for that using this pattern
      .modulename .class {
          style_name : value;
      so for this module (in topic discussion, not this example)
      .MMM-nyc-transit .small {
         fontsize 12px;
      in addition, you can copy/paste everything in the top right styles window into custom.css
      and put a selector wrapper around it
      but in this case, small, might be everything …
      for MMM-Discogs, same approach, BUT the item u want to hide might not be addressable easily . if it IS, then
      .MMM-Discogs ???? {
          display: none;
      if not easily, there are all kinds of css selectors (how to target content) that can be used, div after a page, after a heading of ‘jjj’
      i use this to help me get to the right element
      https://www.w3schools.com/cssref/css_selectors.php
      N 1 Reply Last reply Reply Quote 1
      • N Offline
        Nneuland @sdetweil
        @sdetweil Sam!
        You’ve been a godsend. I’m going to give this a go when I get home later.
        I can’t thank you enough for your time and patience.
        N
          sdetweil @Nneuland
          @nneuland to close the developer window u can click the close x in the top right, or ctrl-shift-i again
          • N Offline
            Nneuland @sdetweil
            For the NYC-Transit module Changing the font size within the the developers window was smooth as silk.
            However, scaling in the custom.css has yielded nothing.
            I have attached a screenshot of what I believe is the proper location.
            Removing the duration of individual albums seems more difficult considering every album in the collection is different, or it doesn’t have a location at all due to not being in the description.
            To clarify, I should be modifying the “custom.css” (blank by default) file. not amending the specific mmm-nyc-transit.css or mmm-discogs.css files?Nyc_transit_font.jpg
              sdetweil @Nneuland
              @nneuland so, in custom.css you need this pattern
              .modulename (space) .classname {
                  stylename: value;
              SO, in this case from the dev window
              go up to the module_11_MMM-nyc-transit
              remove the module_11_ prefix and add a dot
              .MMM-nyc-transit
              then we need the class name of the element u want to change
              mta__train–list (add a dot in front)
              now we have
              .MMM-nyc-transit   .mta__train--list {
              it IS font-size: medium;
              in main.css
              .medium {
                font-size: 30px;
                line-height: 35px;
              u want to change that, SO
                      font-size:   20px;
              • N Offline
                Nneuland
                YES!!! My spacing was allllllll off.
                You’re a genius! Thank you so much.
                You have the patience of a saint
                N
                  sdetweil @Nneuland
                  @nneuland yes, spacing is critical… it means something else if there are NO spaces between items in the selector list ( stuff before open brace { )
                  something worth reading
                  https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works
                  • N Offline
                    Nneuland
                    Your so knowledgeable with this realm.
                    Can I ask, what you know about the hue module?
                    Specifically, is it only displaying what lights are on, or is it interactive?
                    I’m genuinely curious what your smart mirror looks like.
                    If you have one, I imagine it’s incredible.
                    N
                      sdetweil @Nneuland
                      @nneuland i am a moderator… i don’t know much about specific modules…
                      I know HOW to do some debugging and some limited css…
                      I also do the scripted installer and upgrader tools
                      i have 5 single board computers running different things… Pi0, Pi3, Pi4, Jetson Nano, and Odroid Xu4. also a vm with Macos catalina, and my desktop running ubuntu.
                      and I know how to google for answers…
                      there are lots of talented folks here… I reference their work. all the time…
                      • N Offline
                        Nneuland @sdetweil
                        That’s great. Can’t thank you enough.
                          matt216
                          @sdetweil I wonder if I can ask for some help? I have MMM-ip module that I’d like the change the font size. Following your instructions with dev tools I can see:
                          So I have put in my custom.css:
                          .MMM-ip .dimmed {
                          font-size: 16px;
                          But it doesn’t seem to take effect. Any advice?
                          Thanks in advance.
                          Matt
                            sdetweil @matt216
                            @matt216 while in the dev window,
                            u can see the custom.css value is strike thru, cause the div wins
                            so u need to apply the style to the div
                            add it to the element box above.
                            if that works, you can mark/copy that top right box, and paste to custom.css, should have the right targeting syntax
                              matt216 @sdetweil
                              @sdetweil Thanks for the help.
                              How do I reference the div in custom.css not the class?
                              Adjusting the value in the element box above successfully adjusts the font, but this looks to adjust the ‘dimmed’ class.
                                sdetweil @matt216
                                @matt216 and when u copy/paste that from the top box to custom.css, what do u get?
                                just swipe mark the element entry, copy
                                here is my favorite cheet sheet on css selectors
                                https://www.w3schools.com/cssref/css_selectors.asp
                                  I’m guessing
                                  .MMM-ip  .dimmed div {
                                       font-size:16px;
                                    matt216 @sdetweil
                                    @sdetweil Thank you, this works:
                                         font-size:16px;
                                      sdetweil @matt216
                                      @matt216 what did the copy/paste result look like?
                                      • A Anthony referenced this topic on
                                        Shawangunk
                                        I’m a raspi & linux newbie (used C years ago. some Arduino experience) and this is my first post so…
                                        In attempting to modify MM I’ve experienced a number of custom.css failures. I found this @sdetweil post https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1623901330356 and believe the “developer Tools” will be a big help, but I quickly got lost. The Tool’s built in help doc (kebab>Help>Documentation) appears to be a null link. I tried to find documentation for this tool online without luck. Can anyone provide a documentation link or more detailed tutorial?
                                        • S Shawangunk referenced this topic on
                                          sdetweil @Shawangunk
                                          @Shawangunk this would be all in the/a browser, nothing w mm.
                                          I have never seen any doc
                                            @Shawangunk see this
                                            https://developer.chrome.com/docs/devtools/
                                            but this will not teach u the DOM, css, html (and attributes)
                                            only provides tool to examine and change Dom element styles
