    MMM-CalendarExt3
    689 Posts 82 Posters 3.1m Views 86 Watching
      sdetweil @KD
      @KD said in MMM-CalendarExt3:
      Calendar-Fetcher: Broadcasting 0 events.
      so, the calendar module didnt find any events…
      if you download the ICS file and look inside,
      see the BEGIN VCALENDAR
      BEGIN VEVENT
      END VEVENT
      END VCALENDAR
      we can turn on debug to get more detail
      change the config.js
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      to
      	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
      then start mm with
      npm start >somefile.txt
      wait til the cal message comes up
      then
      ctrl-c (in the terminal window where u did npm start, or ctrl-q (if u didn’t start with pm2, as pm2’s JOB is to keep MM running, so it will restart it after it shuts down unexpectedly
      • K Offline
        KD @sdetweil
        @sdetweil Added “Debug” to the config, and ran the npm start with the log file and waited for the calendar to say it was not able to find events - here is the output of the somefile.txt :
        > magicmirror@2.20.0 start
        [11.09.2022 14:20.39.366] [LOG]   Starting MagicMirror: v2.20.0
        [11.09.2022 14:20.39.373] [LOG]   Loading config ...
        [11.09.2022 14:20.39.380] [LOG]   Loading module helpers ...
        [11.09.2022 14:20.39.383] [LOG]   No helper found for module: clock.
        [11.09.2022 14:20.39.384] [LOG]   No helper found for module: MMM-CalendarExt3.
        [11.09.2022 14:20.39.628] [LOG]   Initializing new module helper ...
        [11.09.2022 14:20.39.629] [LOG]   Module helper loaded: calendar
        [11.09.2022 14:20.39.631] [LOG]   No helper found for module: weather.
        [11.09.2022 14:20.40.066] [LOG]   Initializing new module helper ...
        [11.09.2022 14:20.40.081] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
        [11.09.2022 14:20.40.082] [LOG]   All module helpers loaded.
        [11.09.2022 14:20.40.206] [LOG]   Starting server on port 8080 ...
        [11.09.2022 14:20.40.224] [LOG]   Server started ...
        [11.09.2022 14:20.40.226] [LOG]   Connecting socket for: calendar
        [11.09.2022 14:20.40.228] [LOG]   Starting node helper for: calendar
        [11.09.2022 14:20.40.229] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
        [11.09.2022 14:20.40.230] [LOG]   Sockets connected & modules started ...
        [11.09.2022 14:20.40.667] [LOG]   Launching application.
        [11.09.2022 14:20.44.986] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/embed?src=konstantin.denishev%40gmail.com&ctz=Europe%2FLondon - Interval: 300000
        [11.09.2022 14:20.45.260] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/" for images.
        [11.09.2022 14:20.45.273] [INFO]  BACKGROUNDSLIDESHOW: 171 files found
        [11.09.2022 14:20.45.315] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
        [11.09.2022 14:20.45.317] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages//20161126_135734.jpg"
        [11.09.2022 14:20.46.043] [DEBUG] parsed data={"value":"void 0}})},f=function(){var g={};return g.v=g.next=g.head=g},h=0;return c});var ea=function(a,b){a instanceof String&&(a+=);var c=0,d=!1,e={next:function(){if(!d&&c<a.length){var f=c++;return{value:b(f,a[f]),done:!1}}d=!0;return{done:!0,value:void 0}}};e[Symbol.iterator]=function(){return e};return e};p(Array.prototype.entries,function(a){return a?a:function(){return ea(this,function(b,c){return[b,c]})}});p(Array.prototype.keys,function(a){return a?a:function(){return ea(this,function(b){return b})}});","spdx-license-identifier":[" Apache-2.0"," Apache-2.0"],"e":")};M.prototype.get=function(a,b){for(var c=a+=,d=(this.g.cookie||).split(;),e=0,f;e<d.length;e++){f=H(d[e]);if(0==f.lastIndexOf(c,0))return f.slice(c.length);if(f==a)return}return b};M.prototype.o=function(){for(var a=(this.g.cookie||).split(;),b=[],c=[],d,e,f=0;f<a.length;f++)e=H(a[f]),d=e.indexOf(=),-1==d?(b.push(),c.push(e)):(b.push(e.substring(0,d)),c.push(e.substring(d+1)));return c};var Pa=new M;var Qa=function(){this.H=this.H;this.g=this.g};Qa.prototype.H=!1;Qa.prototype.G=function(){if(this.g)for(;this.g.length;)this.g.shift()()};var N=function(a,b){this.type=a;this.g=this.target=b;this.defaultPrevented=!1};N.prototype.h=function(){this.defaultPrevented=!0};var Ra=function(){if(!t.addEventListener||!Object.defineProperty)return!1;var a=!1,b=Object.defineProperty({},passive,{get:function(){a=!0}});try{t.addEventListener(test,function(){},b),t.removeEventListener(test,function(){},b)}catch(c){}return a}();var Sa=function(a){Sa[ ](a);return a};Sa[ ]=function(){};var Ua=function(a){var b=Ta;return Object.prototype.hasOwnProperty.call(b,9)?b[9]:b[9]=a(9)};var Va=K(Opera),Wa=K(Trident)||K(MSIE),Xa=K(Edge),Ya=K(Gecko)&&!(-1!=J().toLowerCase().indexOf(webkit)&&!K(Edge))&&!(K(Trident)||K(MSIE))&&!K(Edge),Za=-1!=J().toLowerCase().indexOf(webkit)&&!K(Edge),$a;","a":"{var ab=,bb=function(){var a=J();if(Ya)return/rv:([^\\);]+)(\\)|;)/.exec(a);if(Xa)return/Edge\\/([\\d\\.]+)/.exec(a);if(Wa)return/\\b(?:MSIE|rv)[: ]([^\\);]+)(\\)|;)/.exec(a);if(Za)return/WebKit\\/(\\S+)/.exec(a);if(Va)return/(?:Version)[ \\/]?(\\S+)/.exec(a)}();bb&&(ab=bb?bb[1]:);if(Wa){var cb,db=t.document;cb=db?db.documentMode:void 0;if(null!=cb&&cb>parseFloat(ab)){$a=String(cb);break a}}$a=ab}","array":"e:null)),e=type_error:SafeUrl;else{b:if(na){try{e=new URL(d)}catch(k){e=https:;break b}e=e.protocol}else c:{e=document.createElement(a);try{e.href=d}catch(k){e=void 0;break c}e=e.protocol;e=:===e||===e?https::e}javascript:===e?(oa(d),e=void 0):e=d}void 0!==e&&(b.href=e)}})};var Q=Object.create(null);function R(a,b){Q[a]||(Q[a]=b)};var S=function(){w.apply(this,arguments)};u(S,w);S.prototype.h=function(){var a=this.g.querySelector(#playCaptchaButton),b=this.g.querySelector(#captchaAudio),c=this.g.querySelector(input[name=ca]);a&&b&&c&&a.addEventListener(click,function(d){d.preventDefault();b.readyState===HTMLMediaElement.HAVE_NOTHING?b.load():b.paused&&b.play();c.value=;c.focus()})};var T=function(){w.apply(this,arguments)};u(T,w);T.prototype.h=function(){var a=this.g;void 0!==a.dataset.hasDomainSuffix&&(sa(a),ta(a))};var ta=function(a){a.addEventListener(keyup,function(){sa(a)})},sa=function(a){0<a.getElementsByTagName(INPUT.toString()).item(0).value.indexOf(@)?a.dataset.hasAtSign=:delete a.dataset.hasAtSign};var U=function(){w.apply(this,arguments)};u(U,w);U.prototype.h=function(){var a=this.g;void 0!==a.dataset.hasDomainSuffix&&(ua(a),va(a))};var va=function(a){a.addEventListener(keyup,function(){ua(a)})},ua=function(a){0<a.getElementsByTagName(INPUT.toString()).item(0).value.indexOf(@)?a.dataset.hasAtSign=:delete a.dataset.hasAtSign};R(CaptchaInput,S);R(Card,A);R(EmailInput,T);R(Footer,P);R(IdentifierInput,U);var wa=[],V,W=[].slice.call(document.querySelectorAll([data-auto-init])),xa=undefined!=typeof Symbol&&Symbol.iterator&&W[Symbol.iterator],X;xa?X=xa.call(W):X={next:h(W)};V=X;for(var Y=V.next();!Y.done;Y=V.next()){var Z=Y.value,ya=Z.getAttribute(data-auto-init);if(!ya)throw Error(auto-init attribute requires a value.);var za=new Q[ya](Z);wa.push(za);Z.removeAttribute(data-auto-init)};}).call(this);"}
        [11.09.2022 14:20.46.045] [DEBUG] There are 5 calendar entries.
        [11.09.2022 14:20.46.048] [DEBUG] Processing entry...
        [11.09.2022 14:20.46.053] [DEBUG] Processing entry...
        [11.09.2022 14:20.46.055] [DEBUG] Processing entry...
        [11.09.2022 14:20.46.057] [DEBUG] Processing entry...
        [11.09.2022 14:20.46.058] [DEBUG] Processing entry...
        [11.09.2022 14:20.46.061] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
        This is the output from the terminal @almightyyoshi
        kd@raspberrypi:~/MagicMirror $ npm start >somefile.txt
        MESA-LOADER: failed to retrieve device information
        MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
        failed to load driver: kms_swrast
        MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
        failed to load swrast driver
        There is definitely events in the calendar…
          sdetweil @KD
          @KD wrong link… u used the embed link (make the full calendar SHOW in the client,…)
          we want the ICal link
          • K Offline
            KD @sdetweil
            @sdetweil Huge apologies Sam! just noticed I had the wrong link in my clipboard when i copy and pasted it!:man_facepalming:
            Thank you so much for your help with this and apologies to have wasted your time with such trivial mistake…
              sdetweil @KD
              @KD np… dang computers do what we tell them, exactly…
              u will want to remove the “DEBUG”
              as it generates a lot of content
              • K Offline
                KD @sdetweil
                @sdetweil Yes thank you - all removed.
                  sdetweil @KD
                  @KD and the position: for the default calendar… don’t need to display it if using ext3
                  • K Offline
                    KD @sdetweil
                    @sdetweil Thank you Sam - removed it as well.
                      almightyyoshi
                      I’m having a bit of css trouble. I’m trying to display an image in the background of specific cells. It was working in July (in both CX2 and CX3) but has since stopped displaying in either.
                      .CX3 .month_09.date_22 { /*first day of fall*/
                              opacity:50%;
                              background-position:center;
                              background-repeat:no-repeat;
                              background-image: url('../modules/MMM-CalendarExt3/images/Fall-Tree-small.png');
                      S M 2 Replies Last reply Reply Quote 1
                        sdetweil @almightyyoshi
                        @almightyyoshi said in MMM-CalendarExt3:
                        .month_09.date_22
                        do u need a space between those?
                        also see how to use developers window to determine element classes to address for styles
                        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1663003753793
                          MMRIZE @almightyyoshi
                          opacity:50%;
                          background-image: url(‘…/modules/MMM-CalendarExt3/images/Fall-Tree-small.png’);
                          .CX3 .month_9.date_22 {
                            almightyyoshi @sdetweil
                            Nope. Stupid mistake. Needed to be month_9.date_22.
                              @almightyyoshi ok, I don’t see the difference…
                              A mumblebajM 2 Replies Last reply Reply Quote 0
                                Ha! I was replying to yours. @MMRIZE hadn’t popped up in my feed when I replied. I thought I refreshed when I got on, but possibly not.
                                • mumblebajM Offline
                                  @sdetweil month_09 (wrong i guess) and month_9 (correct i guess)
                                    sdetweil @mumblebaj
                                    @mumblebaj dang computers!!! so picky,!
                                      What’s worse, I had an example right above it that I knew worked, and I still didn’t register that the 09 was the issue.
                                      • O Offline
                                        Ottosophie @almightyyoshi
                                        Hello, since the switch to Cal3, I no longer see any events in my calendar. I tried with the French holiday calendar, and it works, I added lots of events in mine, but nothing worked. Looks like it’s coming from my ICS file. An idea ? (translated with Google)
                                          sdetweil @Ottosophie
                                          @Ottosophie did u set a specific list of cals to read from in the cx3 config?
                                          did u add a name field to the cal entry in the base calendar module,?
                                          I’m guessing
                                          I just installed cx3 multiple times without any issue.
                                          • O Offline
                                            Ottosophie @sdetweil
                                            @sdetweil Thank you for your answer, I only restarted my raspberry several times and all my events came back, weird.
                                            O 1 Reply Last reply Reply Quote 1
                                            • 34
                                            • 35
                                            • 7 / 35
