    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      sdetweil @KD
      @KD and the position: for the default calendar… don’t need to display it if using ext3
      K 1 Reply Last reply
      • K
        KD @sdetweil
        @sdetweil Thank you Sam - removed it as well.
        • A
          almightyyoshi
          I’m having a bit of css trouble. I’m trying to display an image in the background of specific cells. It was working in July (in both CX2 and CX3) but has since stopped displaying in either.
          .CX3 .month_09.date_22 { /*first day of fall*/
                  opacity:50%;
                  background-position:center;
                  background-repeat:no-repeat;
                  background-image: url('../modules/MMM-CalendarExt3/images/Fall-Tree-small.png');
          S M 2 Replies Last reply
            sdetweil @almightyyoshi
            @almightyyoshi said in MMM-CalendarExt3:
            .month_09.date_22
            do u need a space between those?
            also see how to use developers window to determine element classes to address for styles
            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1663003753793
            A 1 Reply Last reply
              MMRIZE @almightyyoshi
              opacity:50%;
              background-image: url(‘…/modules/MMM-CalendarExt3/images/Fall-Tree-small.png’);
              .CX3 .month_9.date_22 {
              • A
                almightyyoshi @sdetweil
                Nope. Stupid mistake. Needed to be month_9.date_22.
                  @almightyyoshi ok, I don’t see the difference…
                  A mumblebajM 2 Replies Last reply
                  • A
                    Ha! I was replying to yours. @MMRIZE hadn’t popped up in my feed when I replied. I thought I refreshed when I got on, but possibly not.
                    • mumblebajM
                      @sdetweil month_09 (wrong i guess) and month_9 (correct i guess)
                        sdetweil @mumblebaj
                        @mumblebaj dang computers!!! so picky,!
                        • A
                          What’s worse, I had an example right above it that I knew worked, and I still didn’t register that the 09 was the issue.
                          O 1 Reply Last reply
                          • O
                            Ottosophie @almightyyoshi
                            Hello, since the switch to Cal3, I no longer see any events in my calendar. I tried with the French holiday calendar, and it works, I added lots of events in mine, but nothing worked. Looks like it’s coming from my ICS file. An idea ? (translated with Google)
                              sdetweil @Ottosophie
                              @Ottosophie did u set a specific list of cals to read from in the cx3 config?
                              did u add a name field to the cal entry in the base calendar module,?
                              I’m guessing
                              I just installed cx3 multiple times without any issue.
                              • O
                                Ottosophie @sdetweil
                                @sdetweil Thank you for your answer, I only restarted my raspberry several times and all my events came back, weird.
                                • O
                                  Ottosophie @Ottosophie
                                  I have another question, is it possible for an event to be written on 2 lines so that we can see the end instead of the 3 small dots? Thanks
                                  • O
                                    onryanti
                                    Is it possible to set this as a rolling calendar forward where only the current week is shown in the top. Dont need the historical days to be shown?
                                      sdetweil @onryanti
                                      @onryanti set weeks in view=1
                                      O O 2 Replies Last reply
                                        MMRIZE @onryanti
                                        @onryanti
                                        // In the config of the module;
                                          weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                                          weeksInView: 3, // How many weeks will be shown from `weekIndex`
                                        • O
                                          onryanti @sdetweil
                                          @sdetweil I managed to solve it to show the calendar how I wanted to. Thanks
                                          • O
                                            I’m already with weeksInView: 1, my screen is in portrait mode, so the boxes are not very wide. I would have liked an automatic lineup. I tried to decrease the font size, but it doesn’t show anything anymore. If anyone has a solution, thanks in advance.
                                            M 1 Reply Last reply
                                            • 34
                                            • 35
                                            • 7 / 35
