    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • K
      KD @sdetweil
      @sdetweil Yes thank you - all removed.
        sdetweil @KD
        @KD and the position: for the default calendar… don’t need to display it if using ext3
        • K
          KD @sdetweil
          @sdetweil Thank you Sam - removed it as well.
          • A
            almightyyoshi
            I’m having a bit of css trouble. I’m trying to display an image in the background of specific cells. It was working in July (in both CX2 and CX3) but has since stopped displaying in either.
            .CX3 .month_09.date_22 { /*first day of fall*/
                    opacity:50%;
                    background-position:center;
                    background-repeat:no-repeat;
                    background-image: url('../modules/MMM-CalendarExt3/images/Fall-Tree-small.png');
            S M 2 Replies Last reply Reply Quote 1
              sdetweil @almightyyoshi
              @almightyyoshi said in MMM-CalendarExt3:
              .month_09.date_22
              do u need a space between those?
              also see how to use developers window to determine element classes to address for styles
              https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1663003753793
                MMRIZE @almightyyoshi
                opacity:50%;
                background-image: url(‘…/modules/MMM-CalendarExt3/images/Fall-Tree-small.png’);
                .CX3 .month_9.date_22 {
                • A
                  almightyyoshi @sdetweil
                  Nope. Stupid mistake. Needed to be month_9.date_22.
                    @almightyyoshi ok, I don’t see the difference…
                    A mumblebajM 2 Replies Last reply Reply Quote 0
                    • A
                      Ha! I was replying to yours. @MMRIZE hadn’t popped up in my feed when I replied. I thought I refreshed when I got on, but possibly not.
                      • mumblebajM
                        @sdetweil month_09 (wrong i guess) and month_9 (correct i guess)
                          sdetweil @mumblebaj
                          @mumblebaj dang computers!!! so picky,!
                          • A
                            What’s worse, I had an example right above it that I knew worked, and I still didn’t register that the 09 was the issue.
                            • O
                              Ottosophie @almightyyoshi
                              Hello, since the switch to Cal3, I no longer see any events in my calendar. I tried with the French holiday calendar, and it works, I added lots of events in mine, but nothing worked. Looks like it’s coming from my ICS file. An idea ? (translated with Google)
                                sdetweil @Ottosophie
                                @Ottosophie did u set a specific list of cals to read from in the cx3 config?
                                did u add a name field to the cal entry in the base calendar module,?
                                I’m guessing
                                I just installed cx3 multiple times without any issue.
                                • O
                                  Ottosophie @sdetweil
                                  @sdetweil Thank you for your answer, I only restarted my raspberry several times and all my events came back, weird.
                                  O 1 Reply Last reply Reply Quote 1
                                  • O
                                    Ottosophie @Ottosophie
                                    I have another question, is it possible for an event to be written on 2 lines so that we can see the end instead of the 3 small dots? Thanks
                                    • O
                                      onryanti
                                      Is it possible to set this as a rolling calendar forward where only the current week is shown in the top. Dont need the historical days to be shown?
                                        sdetweil @onryanti
                                        @onryanti set weeks in view=1
                                        O O 2 Replies Last reply Reply Quote 0
                                          MMRIZE @onryanti
                                          @onryanti
                                          // In the config of the module;
                                            weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                                            weeksInView: 3, // How many weeks will be shown from `weekIndex`
                                          • O
                                            onryanti @sdetweil
                                            @sdetweil I managed to solve it to show the calendar how I wanted to. Thanks
                                            • 34
                                            • 35
                                            • 7 / 35
