    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • K Offline
      KD @sdetweil
      @sdetweil Thanks Sam - I now get Loading… than “error in the calendar module check log for more details” and finally no upcoming events… not sure how I have broken it as it was working yesterday… i also tried to replace the default calendar with
      git checkout modules/default/calendar/calendar.js
      As per one of your other posts in the forum but got "updated 0 (zero) paths from the index…
        sdetweil @KD
        @KD u have to be I the MagicMirror folder for the git checkout to work
        you should not have changed that file anyhow
        all config is done thru config.js
        can u show the output where u start mm?
        either npm start
        or if you use pm2, then
        pm2 logs --lines=50
        calendarext3, gets it’s info from the default calendar. so if it has problems, then u get nothing
        • K Offline
          KD @sdetweil
          @sdetweil here is an output from “npm start”
          kd@raspberrypi:~/MagicMirror $ npm start
          > magicmirror@2.20.0 start
          [11.09.2022 14:00.12.728] [LOG]   Starting MagicMirror: v2.20.0
          [11.09.2022 14:00.12.736] [LOG]   Loading config ...
          [11.09.2022 14:00.12.743] [LOG]   Loading module helpers ...
          [11.09.2022 14:00.12.745] [LOG]   No helper found for module: clock.
          [11.09.2022 14:00.12.747] [LOG]   No helper found for module: MMM-CalendarExt3.
          [11.09.2022 14:00.13.011] [LOG]   Initializing new module helper ...
          [11.09.2022 14:00.13.012] [LOG]   Module helper loaded: calendar
          [11.09.2022 14:00.13.013] [LOG]   No helper found for module: weather.
          [11.09.2022 14:00.13.554] [LOG]   Initializing new module helper ...
          [11.09.2022 14:00.13.556] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
          [11.09.2022 14:00.13.558] [LOG]   All module helpers loaded.
          [11.09.2022 14:00.13.725] [LOG]   Starting server on port 8080 ...
          [11.09.2022 14:00.13.745] [LOG]   Server started ...
          [11.09.2022 14:00.13.747] [LOG]   Connecting socket for: calendar
          [11.09.2022 14:00.13.748] [LOG]   Starting node helper for: calendar
          [11.09.2022 14:00.13.749] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
          [11.09.2022 14:00.13.750] [LOG]   Sockets connected & modules started ...
          [11.09.2022 14:00.14.038] [ERROR] Whoops! There was an uncaught exception...
          [11.09.2022 14:00.14.046] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
              at Server.setupListenHandle [as _listen2] (node:net:1372:16)
              at listenInCluster (node:net:1420:12)
              at GetAddrInfoReqWrap.doListen [as callback] (node:net:1559:7)
              at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) {
            code: 'EADDRINUSE',
            errno: -98,
            syscall: 'listen',
            address: '127.0.0.1',
            port: 8080
          [11.09.2022 14:00.14.048] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [11.09.2022 14:00.14.052] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [11.09.2022 14:00.14.099] [LOG]   Launching application.
          MESA-LOADER: failed to retrieve device information
          MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          failed to load driver: kms_swrast
          MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
          failed to load swrast driver
          [11.09.2022 14:00.17.129] [LOG]   Shutting down server...
          [11.09.2022 14:00.17.136] [LOG]   Stopping module helper: calendar
          [11.09.2022 14:00.17.137] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
            sdetweil @KD
            @KD yep, two copies running
            pm2 stop all
            then u can do npm start
            • K Offline
              KD @sdetweil
              @sdetweil Apologies yes i had a PM2 job in the background…
              Here is the fresh output:
              [11.09.2022 14:07.14.079] [LOG]   Starting MagicMirror: v2.20.0
              [11.09.2022 14:07.14.088] [LOG]   Loading config ...
              [11.09.2022 14:07.14.094] [LOG]   Loading module helpers ...
              [11.09.2022 14:07.14.097] [LOG]   No helper found for module: clock.
              [11.09.2022 14:07.14.099] [LOG]   No helper found for module: MMM-CalendarExt3.
              [11.09.2022 14:07.14.368] [LOG]   Initializing new module helper ...
              [11.09.2022 14:07.14.370] [LOG]   Module helper loaded: calendar
              [11.09.2022 14:07.14.371] [LOG]   No helper found for module: weather.
              [11.09.2022 14:07.14.976] [LOG]   Initializing new module helper ...
              [11.09.2022 14:07.14.978] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
              [11.09.2022 14:07.14.979] [LOG]   All module helpers loaded.
              [11.09.2022 14:07.15.149] [LOG]   Starting server on port 8080 ...
              [11.09.2022 14:07.15.168] [LOG]   Server started ...
              [11.09.2022 14:07.15.170] [LOG]   Connecting socket for: calendar
              [11.09.2022 14:07.15.172] [LOG]   Starting node helper for: calendar
              [11.09.2022 14:07.15.173] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
              [11.09.2022 14:07.15.174] [LOG]   Sockets connected & modules started ...
              [11.09.2022 14:07.15.516] [LOG]   Launching application.
              [11.09.2022 14:07.19.711] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ - Interval: 300000
              [11.09.2022 14:07.19.985] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/" for images.
              [11.09.2022 14:07.20.006] [INFO]  BACKGROUNDSLIDESHOW: 171 files found
              [11.09.2022 14:07.20.057] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
              [11.09.2022 14:07.20.058] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages//DSC_0038.JPG"
              [11.09.2022 14:07.20.493] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
              [11.09.2022 14:07.29.492] [LOG]   Shutting down server...
              [11.09.2022 14:07.29.493] [LOG]   Stopping module helper: calendar
              [11.09.2022 14:07.29.494] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
                sdetweil @KD
                @KD said in MMM-CalendarExt3:
                so, the calendar module didnt find any events…
                if you download the ICS file and look inside,
                see the BEGIN VCALENDAR
                BEGIN VEVENT
                END VEVENT
                END VCALENDAR
                we can turn on debug to get more detail
                change the config.js
                	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                to
                	logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                then start mm with
                npm start >somefile.txt
                wait til the cal message comes up
                then
                ctrl-c (in the terminal window where u did npm start, or ctrl-q (if u didn’t start with pm2, as pm2’s JOB is to keep MM running, so it will restart it after it shuts down unexpectedly
                • K Offline
                  KD @sdetweil
                  @sdetweil Added “Debug” to the config, and ran the npm start with the log file and waited for the calendar to say it was not able to find events - here is the output of the somefile.txt :
                  [11.09.2022 14:20.39.366] [LOG]   Starting MagicMirror: v2.20.0
                  [11.09.2022 14:20.39.373] [LOG]   Loading config ...
                  [11.09.2022 14:20.39.380] [LOG]   Loading module helpers ...
                  [11.09.2022 14:20.39.383] [LOG]   No helper found for module: clock.
                  [11.09.2022 14:20.39.384] [LOG]   No helper found for module: MMM-CalendarExt3.
                  [11.09.2022 14:20.39.628] [LOG]   Initializing new module helper ...
                  [11.09.2022 14:20.39.629] [LOG]   Module helper loaded: calendar
                  [11.09.2022 14:20.39.631] [LOG]   No helper found for module: weather.
                  [11.09.2022 14:20.40.066] [LOG]   Initializing new module helper ...
                  [11.09.2022 14:20.40.081] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
                  [11.09.2022 14:20.40.082] [LOG]   All module helpers loaded.
                  [11.09.2022 14:20.40.206] [LOG]   Starting server on port 8080 ...
                  [11.09.2022 14:20.40.224] [LOG]   Server started ...
                  [11.09.2022 14:20.40.226] [LOG]   Connecting socket for: calendar
                  [11.09.2022 14:20.40.228] [LOG]   Starting node helper for: calendar
                  [11.09.2022 14:20.40.229] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                  [11.09.2022 14:20.40.230] [LOG]   Sockets connected & modules started ...
                  [11.09.2022 14:20.40.667] [LOG]   Launching application.
                  [11.09.2022 14:20.44.986] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/embed?src=konstantin.denishev%40gmail.com&ctz=Europe%2FLondon - Interval: 300000
                  [11.09.2022 14:20.45.260] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/" for images.
                  [11.09.2022 14:20.45.273] [INFO]  BACKGROUNDSLIDESHOW: 171 files found
                  [11.09.2022 14:20.45.315] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
                  [11.09.2022 14:20.45.317] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages//20161126_135734.jpg"
                  [11.09.2022 14:20.46.043] [DEBUG] parsed data={"value":"void 0}})},f=function(){var g={};return g.v=g.next=g.head=g},h=0;return c});var ea=function(a,b){a instanceof String&&(a+=);var c=0,d=!1,e={next:function(){if(!d&&c<a.length){var f=c++;return{value:b(f,a[f]),done:!1}}d=!0;return{done:!0,value:void 0}}};e[Symbol.iterator]=function(){return e};return e};p(Array.prototype.entries,function(a){return a?a:function(){return ea(this,function(b,c){return[b,c]})}});p(Array.prototype.keys,function(a){return a?a:function(){return ea(this,function(b){return b})}});","spdx-license-identifier":[" Apache-2.0"," Apache-2.0"],"e":")};M.prototype.get=function(a,b){for(var c=a+=,d=(this.g.cookie||).split(;),e=0,f;e<d.length;e++){f=H(d[e]);if(0==f.lastIndexOf(c,0))return f.slice(c.length);if(f==a)return}return b};M.prototype.o=function(){for(var a=(this.g.cookie||).split(;),b=[],c=[],d,e,f=0;f<a.length;f++)e=H(a[f]),d=e.indexOf(=),-1==d?(b.push(),c.push(e)):(b.push(e.substring(0,d)),c.push(e.substring(d+1)));return c};var Pa=new M;var Qa=function(){this.H=this.H;this.g=this.g};Qa.prototype.H=!1;Qa.prototype.G=function(){if(this.g)for(;this.g.length;)this.g.shift()()};var N=function(a,b){this.type=a;this.g=this.target=b;this.defaultPrevented=!1};N.prototype.h=function(){this.defaultPrevented=!0};var Ra=function(){if(!t.addEventListener||!Object.defineProperty)return!1;var a=!1,b=Object.defineProperty({},passive,{get:function(){a=!0}});try{t.addEventListener(test,function(){},b),t.removeEventListener(test,function(){},b)}catch(c){}return a}();var Sa=function(a){Sa[ ](a);return a};Sa[ ]=function(){};var Ua=function(a){var b=Ta;return Object.prototype.hasOwnProperty.call(b,9)?b[9]:b[9]=a(9)};var Va=K(Opera),Wa=K(Trident)||K(MSIE),Xa=K(Edge),Ya=K(Gecko)&&!(-1!=J().toLowerCase().indexOf(webkit)&&!K(Edge))&&!(K(Trident)||K(MSIE))&&!K(Edge),Za=-1!=J().toLowerCase().indexOf(webkit)&&!K(Edge),$a;","a":"{var ab=,bb=function(){var a=J();if(Ya)return/rv:([^\\);]+)(\\)|;)/.exec(a);if(Xa)return/Edge\\/([\\d\\.]+)/.exec(a);if(Wa)return/\\b(?:MSIE|rv)[: ]([^\\);]+)(\\)|;)/.exec(a);if(Za)return/WebKit\\/(\\S+)/.exec(a);if(Va)return/(?:Version)[ \\/]?(\\S+)/.exec(a)}();bb&&(ab=bb?bb[1]:);if(Wa){var cb,db=t.document;cb=db?db.documentMode:void 0;if(null!=cb&&cb>parseFloat(ab)){$a=String(cb);break a}}$a=ab}","array":"e:null)),e=type_error:SafeUrl;else{b:if(na){try{e=new URL(d)}catch(k){e=https:;break b}e=e.protocol}else c:{e=document.createElement(a);try{e.href=d}catch(k){e=void 0;break c}e=e.protocol;e=:===e||===e?https::e}javascript:===e?(oa(d),e=void 0):e=d}void 0!==e&&(b.href=e)}})};var Q=Object.create(null);function R(a,b){Q[a]||(Q[a]=b)};var S=function(){w.apply(this,arguments)};u(S,w);S.prototype.h=function(){var a=this.g.querySelector(#playCaptchaButton),b=this.g.querySelector(#captchaAudio),c=this.g.querySelector(input[name=ca]);a&&b&&c&&a.addEventListener(click,function(d){d.preventDefault();b.readyState===HTMLMediaElement.HAVE_NOTHING?b.load():b.paused&&b.play();c.value=;c.focus()})};var T=function(){w.apply(this,arguments)};u(T,w);T.prototype.h=function(){var a=this.g;void 0!==a.dataset.hasDomainSuffix&&(sa(a),ta(a))};var ta=function(a){a.addEventListener(keyup,function(){sa(a)})},sa=function(a){0<a.getElementsByTagName(INPUT.toString()).item(0).value.indexOf(@)?a.dataset.hasAtSign=:delete a.dataset.hasAtSign};var U=function(){w.apply(this,arguments)};u(U,w);U.prototype.h=function(){var a=this.g;void 0!==a.dataset.hasDomainSuffix&&(ua(a),va(a))};var va=function(a){a.addEventListener(keyup,function(){ua(a)})},ua=function(a){0<a.getElementsByTagName(INPUT.toString()).item(0).value.indexOf(@)?a.dataset.hasAtSign=:delete a.dataset.hasAtSign};R(CaptchaInput,S);R(Card,A);R(EmailInput,T);R(Footer,P);R(IdentifierInput,U);var wa=[],V,W=[].slice.call(document.querySelectorAll([data-auto-init])),xa=undefined!=typeof Symbol&&Symbol.iterator&&W[Symbol.iterator],X;xa?X=xa.call(W):X={next:h(W)};V=X;for(var Y=V.next();!Y.done;Y=V.next()){var Z=Y.value,ya=Z.getAttribute(data-auto-init);if(!ya)throw Error(auto-init attribute requires a value.);var za=new Q[ya](Z);wa.push(za);Z.removeAttribute(data-auto-init)};}).call(this);"}
                  [11.09.2022 14:20.46.045] [DEBUG] There are 5 calendar entries.
                  [11.09.2022 14:20.46.048] [DEBUG] Processing entry...
                  [11.09.2022 14:20.46.053] [DEBUG] Processing entry...
                  [11.09.2022 14:20.46.055] [DEBUG] Processing entry...
                  [11.09.2022 14:20.46.057] [DEBUG] Processing entry...
                  [11.09.2022 14:20.46.058] [DEBUG] Processing entry...
                  [11.09.2022 14:20.46.061] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                  This is the output from the terminal @almightyyoshi
                  kd@raspberrypi:~/MagicMirror $ npm start >somefile.txt
                  There is definitely events in the calendar…
                    sdetweil @KD
                    @KD wrong link… u used the embed link (make the full calendar SHOW in the client,…)
                    we want the ICal link
                    • K Offline
                      KD @sdetweil
                      @sdetweil Huge apologies Sam! just noticed I had the wrong link in my clipboard when i copy and pasted it!:man_facepalming:
                      Thank you so much for your help with this and apologies to have wasted your time with such trivial mistake…
                        sdetweil @KD
                        @KD np… dang computers do what we tell them, exactly…
                        u will want to remove the “DEBUG”
                        as it generates a lot of content
                        • K Offline
                          KD @sdetweil
                          @sdetweil Yes thank you - all removed.
                            sdetweil @KD
                            @KD and the position: for the default calendar… don’t need to display it if using ext3
                            • K Offline
                              KD @sdetweil
                              @sdetweil Thank you Sam - removed it as well.
                                almightyyoshi
                                I’m having a bit of css trouble. I’m trying to display an image in the background of specific cells. It was working in July (in both CX2 and CX3) but has since stopped displaying in either.
                                .CX3 .month_09.date_22 { /*first day of fall*/
                                        opacity:50%;
                                        background-position:center;
                                        background-repeat:no-repeat;
                                        background-image: url('../modules/MMM-CalendarExt3/images/Fall-Tree-small.png');
                                S M 2 Replies Last reply Reply Quote 1
                                  sdetweil @almightyyoshi
                                  @almightyyoshi said in MMM-CalendarExt3:
                                  .month_09.date_22
                                  do u need a space between those?
                                  also see how to use developers window to determine element classes to address for styles
                                  https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1663003753793
                                    MMRIZE @almightyyoshi
                                    opacity:50%;
                                    background-image: url(‘…/modules/MMM-CalendarExt3/images/Fall-Tree-small.png’);
                                    .CX3 .month_9.date_22 {
                                      almightyyoshi @sdetweil
                                      Nope. Stupid mistake. Needed to be month_9.date_22.
                                        @almightyyoshi ok, I don’t see the difference…
                                        A mumblebajM 2 Replies Last reply Reply Quote 0
                                          Ha! I was replying to yours. @MMRIZE hadn’t popped up in my feed when I replied. I thought I refreshed when I got on, but possibly not.
                                          • mumblebajM Offline
                                            @sdetweil month_09 (wrong i guess) and month_9 (correct i guess)
                                            • 34
                                            • 35
                                            • 7 / 35
