    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      sdetweil @almightyyoshi
      @almightyyoshi ok, I don’t see the difference…
      A mumblebajM 2 Replies Last reply
      • A
        almightyyoshi @sdetweil
        Ha! I was replying to yours. @MMRIZE hadn’t popped up in my feed when I replied. I thought I refreshed when I got on, but possibly not.
        • mumblebajM
          @sdetweil month_09 (wrong i guess) and month_9 (correct i guess)
            sdetweil @mumblebaj
            @mumblebaj dang computers!!! so picky,!
            A 1 Reply Last reply
            • A
              What’s worse, I had an example right above it that I knew worked, and I still didn’t register that the 09 was the issue.
              O 1 Reply Last reply
              • O
                Ottosophie @almightyyoshi
                Hello, since the switch to Cal3, I no longer see any events in my calendar. I tried with the French holiday calendar, and it works, I added lots of events in mine, but nothing worked. Looks like it’s coming from my ICS file. An idea ? (translated with Google)
                  sdetweil @Ottosophie
                  @Ottosophie did u set a specific list of cals to read from in the cx3 config?
                  did u add a name field to the cal entry in the base calendar module,?
                  I’m guessing
                  I just installed cx3 multiple times without any issue.
                  • O
                    Ottosophie @sdetweil
                    @sdetweil Thank you for your answer, I only restarted my raspberry several times and all my events came back, weird.
                    • O
                      Ottosophie @Ottosophie
                      I have another question, is it possible for an event to be written on 2 lines so that we can see the end instead of the 3 small dots? Thanks
                      • O
                        onryanti
                        Is it possible to set this as a rolling calendar forward where only the current week is shown in the top. Dont need the historical days to be shown?
                        S M 2 Replies Last reply
                          sdetweil @onryanti
                          @onryanti set weeks in view=1
                          O O 2 Replies Last reply
                            MMRIZE @onryanti
                            @onryanti
                            // In the config of the module;
                              weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                              weeksInView: 3, // How many weeks will be shown from `weekIndex`
                            • O
                              onryanti @sdetweil
                              @sdetweil I managed to solve it to show the calendar how I wanted to. Thanks
                              • O
                                I’m already with weeksInView: 1, my screen is in portrait mode, so the boxes are not very wide. I would have liked an automatic lineup. I tried to decrease the font size, but it doesn’t show anything anymore. If anyone has a solution, thanks in advance.
                                M 1 Reply Last reply
                                  MMRIZE @Ottosophie
                                  @Ottosophie
                                    fontSize: '12px', // default would be 18px.
                                    eventHeight: '16px', // the height of the event block. default would be 22px. usually 4px greater than `fontSize` would be pretty to look.
                                    maxEventLines: 5, // How many events will be displayed in a day cell. The overflowed events will be hidden.
                                  I don’t recommend wrapup long text to the multi-lines in the cell instead of one-line clipped. Because it could make misalignments, it might look more complex to glance at the events and unpretty.
                                  What I suggest are;
                                  • Use with default calendar view or MMM-CalendarExt3Agenda to look for more detailed information for upcoming events. Do you really want the exact title of the events which will come 3 weeks later?
                                  • To distinguish events more clearly, instead of a long title, you can transform it into a shorter obvious form with the acronym, emoji, color…
                                    For example, you can shorten all OOO's birthday to 🎂 OOO. It would be a more intuitive form than lengthy text.
                                  eventTransformer: (ev) => {
                                    if (ev.title.search('birthday') > -1)  ev.title = '🎂' + ev.title.replace("'s birthday", ' ')
                                    return ev
                                  BKeyportB 1 Reply Last reply
                                  • BKeyportB
                                    BKeyport Module Developer @MMRIZE
                                    @Ottosophie to echo @MMRIZE here - I would also recommend CX3Agenda as well, over in it’s thread, https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/ MMRize and I have hashed out how to do all sorts of pretty things with it, including wrapping long events, etc. You actually may find that in CX3A’s current state, it would replace CX3 completely.
                                    • O
                                      Ottosophie @BKeyport
                                      @BKeyport thanks, I’m going to try it.
                                      • L
                                        Lilleberg
                                        Can anyone help me with theese issues. This is probably easy coding, but for a newbie as me, I need som help.
                                        I want the first letter in the weekdays to be capital. How to do that?
                                        I want to display a symbol in front of a specific calendar events. I have one calendar for all the birthdays during a year, and I want for example a cake as a symbol in front of all the events from this specific calendar. All the other calendars should be without a symbol.
                                        S M 3 Replies Last reply
                                          sdetweil @Lilleberg
                                          @Lilleberg ext3 gets the symbol info from the base calendar module. so create a custom event if u can to identify those entries and specify a symbol.
                                            MMRIZE @Lilleberg
                                            @Lilleberg
                                            By default, there is no transformation for the letter of weekday name. Your locale decides it. What are your language and locale?
                                            L 1 Reply Last reply
                                            • 34
                                            • 35
                                            • 7 / 35
