    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
    • O Offline
      Ottosophie @almightyyoshi
      Hello, since the switch to Cal3, I no longer see any events in my calendar. I tried with the French holiday calendar, and it works, I added lots of events in mine, but nothing worked. Looks like it’s coming from my ICS file. An idea ? (translated with Google)
        sdetweil @Ottosophie
        @Ottosophie did u set a specific list of cals to read from in the cx3 config?
        did u add a name field to the cal entry in the base calendar module,?
        I’m guessing
        I just installed cx3 multiple times without any issue.
        • O Offline
          Ottosophie @sdetweil
          @sdetweil Thank you for your answer, I only restarted my raspberry several times and all my events came back, weird.
          O 1 Reply Last reply Reply Quote 1
          • O Offline
            Ottosophie @Ottosophie
            I have another question, is it possible for an event to be written on 2 lines so that we can see the end instead of the 3 small dots? Thanks
            • O Offline
              onryanti
              Is it possible to set this as a rolling calendar forward where only the current week is shown in the top. Dont need the historical days to be shown?
                sdetweil @onryanti
                @onryanti set weeks in view=1
                O O 2 Replies Last reply Reply Quote 0
                  MMRIZE @onryanti
                  @onryanti
                  // In the config of the module;
                    weekIndex: 0, // From which week the view starts; -1 : last week, 0: this week 2: 2 weeks later, ...
                    weeksInView: 3, // How many weeks will be shown from `weekIndex`
                  • O Offline
                    onryanti @sdetweil
                    @sdetweil I managed to solve it to show the calendar how I wanted to. Thanks
                    • O Offline
                      I’m already with weeksInView: 1, my screen is in portrait mode, so the boxes are not very wide. I would have liked an automatic lineup. I tried to decrease the font size, but it doesn’t show anything anymore. If anyone has a solution, thanks in advance.
                        MMRIZE @Ottosophie
                        @Ottosophie
                          fontSize: '12px', // default would be 18px.
                          eventHeight: '16px', // the height of the event block. default would be 22px. usually 4px greater than `fontSize` would be pretty to look.
                          maxEventLines: 5, // How many events will be displayed in a day cell. The overflowed events will be hidden.
                        I don’t recommend wrapup long text to the multi-lines in the cell instead of one-line clipped. Because it could make misalignments, it might look more complex to glance at the events and unpretty.
                        What I suggest are;
                        • Use with default calendar view or MMM-CalendarExt3Agenda to look for more detailed information for upcoming events. Do you really want the exact title of the events which will come 3 weeks later?
                        • To distinguish events more clearly, instead of a long title, you can transform it into a shorter obvious form with the acronym, emoji, color…
                          For example, you can shorten all OOO's birthday to 🎂 OOO. It would be a more intuitive form than lengthy text.
                        eventTransformer: (ev) => {
                          if (ev.title.search('birthday') > -1)  ev.title = '🎂' + ev.title.replace("'s birthday", ' ')
                          return ev
                        • BKeyportB Offline
                          BKeyport Module Developer @MMRIZE
                          @Ottosophie to echo @MMRIZE here - I would also recommend CX3Agenda as well, over in it’s thread, https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/ MMRize and I have hashed out how to do all sorts of pretty things with it, including wrapping long events, etc. You actually may find that in CX3A’s current state, it would replace CX3 completely.
                          • O Offline
                            Ottosophie @BKeyport
                            @BKeyport thanks, I’m going to try it.
                            • L Offline
                              Lilleberg
                              Can anyone help me with theese issues. This is probably easy coding, but for a newbie as me, I need som help.
                              I want the first letter in the weekdays to be capital. How to do that?
                              I want to display a symbol in front of a specific calendar events. I have one calendar for all the birthdays during a year, and I want for example a cake as a symbol in front of all the events from this specific calendar. All the other calendars should be without a symbol.
                              S M 3 Replies Last reply Reply Quote 0
                                sdetweil @Lilleberg
                                @Lilleberg ext3 gets the symbol info from the base calendar module. so create a custom event if u can to identify those entries and specify a symbol.
                                  MMRIZE @Lilleberg
                                  @Lilleberg
                                  By default, there is no transformation for the letter of weekday name. Your locale decides it. What are your language and locale?
                                    MMRIZE @Lilleberg
                                    @Lilleberg said in MMM-CalendarExt3:
                                    You can assign a symbol to the specific calendar on the default calendar module’s configuration, not MMM-CalendarExt3’s.
                                    Or you can transform data of event itself by eventTransformer property, like this;
                                    I recommend prior.
                                    L 1 Reply Last reply Reply Quote -1
                                    • F Offline
                                      fedale
                                      How do i add the week number in a own colum, not in first monday. As this is taking up space in colum for monday.
                                      Would like to have in it´s own colum. As i understand i will need to do something in custom.css but unsure how to resolve this.
                                      Any one have a solution for this?
                                        sdetweil @fedale
                                        @fedale it only shows in the header of the 1st day of the week.
                                        you cannot use CSS to create another column,
                                        one would have to change the code
                                        • F Offline
                                          fedale
                                          Okay so it´s not in the css. Thought i had something todo with the weeks mark one. As this can change colour and other things if i don´t recall wrong.
                                          I saw it like this before https://imgur.com/mwwPwEl
                                          Thats why i though this was possible.
                                          I have it 1st day of the week now. And if displayed more than 3-4 items in the 1st day of the week. Then not all items will show. due to the week number takes up a slot there.
                                          As i am showing 3 weeks at time i have a amount of space at liberty.
                                          But i really like the week number ;)
                                            sdetweil @fedale
                                            @fedale i only see the wn 42 in the header of the 1st day of the week cell, same as the examples in the doc
                                            • 10
                                            • 34
                                            • 35
                                            • 8 / 35
