    MMM-CalendarExt3
    689 Posts 82 Posters 3.1m Views 86 Watching
    • BKeyportB Offline
      BKeyport Module Developer @MMRIZE
      @Ottosophie to echo @MMRIZE here - I would also recommend CX3Agenda as well, over in it’s thread, https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/ MMRize and I have hashed out how to do all sorts of pretty things with it, including wrapping long events, etc. You actually may find that in CX3A’s current state, it would replace CX3 completely.
      • O Offline
        Ottosophie @BKeyport
        @BKeyport thanks, I’m going to try it.
        • L Offline
          Lilleberg
          Can anyone help me with theese issues. This is probably easy coding, but for a newbie as me, I need som help.
          I want the first letter in the weekdays to be capital. How to do that?
          I want to display a symbol in front of a specific calendar events. I have one calendar for all the birthdays during a year, and I want for example a cake as a symbol in front of all the events from this specific calendar. All the other calendars should be without a symbol.
          S M 3 Replies Last reply Reply Quote 0
            sdetweil @Lilleberg
            @Lilleberg ext3 gets the symbol info from the base calendar module. so create a custom event if u can to identify those entries and specify a symbol.
              MMRIZE @Lilleberg
              @Lilleberg
              By default, there is no transformation for the letter of weekday name. Your locale decides it. What are your language and locale?
                MMRIZE @Lilleberg
                @Lilleberg said in MMM-CalendarExt3:
                You can assign a symbol to the specific calendar on the default calendar module’s configuration, not MMM-CalendarExt3’s.
                Or you can transform data of event itself by eventTransformer property, like this;
                I recommend prior.
                L 1 Reply Last reply Reply Quote -1
                • F Offline
                  fedale
                  How do i add the week number in a own colum, not in first monday. As this is taking up space in colum for monday.
                  Would like to have in it´s own colum. As i understand i will need to do something in custom.css but unsure how to resolve this.
                  Any one have a solution for this?
                    sdetweil @fedale
                    @fedale it only shows in the header of the 1st day of the week.
                    you cannot use CSS to create another column,
                    one would have to change the code
                    • F Offline
                      fedale
                      Okay so it´s not in the css. Thought i had something todo with the weeks mark one. As this can change colour and other things if i don´t recall wrong.
                      I saw it like this before https://imgur.com/mwwPwEl
                      Thats why i though this was possible.
                      I have it 1st day of the week now. And if displayed more than 3-4 items in the 1st day of the week. Then not all items will show. due to the week number takes up a slot there.
                      As i am showing 3 weeks at time i have a amount of space at liberty.
                      But i really like the week number ;)
                        sdetweil @fedale
                        @fedale i only see the wn 42 in the header of the 1st day of the week cell, same as the examples in the doc
                        • N Offline
                          nearmiss
                          New to MMM-CalendarExt3 so perhaps just missing the obvious… how do I get event locations to show up? In Ext2 there was a hidden div that could be shown via CSS if I recal, but I don’t see that with Ext3?
                          Other question is, is it possible to wrap longer event title names? I see the default calendar module has options around this, but they don’t seem to impact what Ext3 is doing, which I suppose makes sense.
                            MMRIZE @fedale
                            @fedale
                            For CX2, I thought it was not pretty to have the week number column separately, and it is a bit of waste to occupy the expensive real estate of the MM screen, so in CX3, I put the week number into the cell as small as possible.
                            Conclusively, a separated week number column is not possible in CX3 atm, And I think it would be undesirable, so I’ll not consider it.
                            • F Offline
                              fedale
                              Ok thanks for the feedback.
                              I have another question
                              The new calendarExt3 and the i cant seem to get this transform fuction to work anymore. I had the transform in the config.js file and the custom.css with different words to get different color on each work, as we have family calendar.
                              Tried to change it to cx3 without any luck. (/* */ is only to stop the code here.)
                              Example
                              transform: function(event) {
                              if (event.title.search(“Jobb”) > -1) {
                              event.icon = “ic:outline-work-outline”;
                              event.className = “Jobb”;
                              In the custom.css:
                              .CX3 .Jobb.fullday {
                              background-color:rgba(0,128,128);
                              color:#000;
                              .CX3 .Jobb {
                              color:#000;
                                MMRIZE @fedale
                                @fedale
                                ‘eventTransformer’
                                  MMRIZE
                                  Updated 1.2.5 (2022-11-04)
                                  • Added Display legend of the calendar (displayLegend: true and when you set the calendar name on the calendar module)
                                  • Fixed Some CSS fixture
                                  • L Offline
                                    Lilleberg @MMRIZE
                                    @MMRIZE I’m trying to update the module but it seems like the update doesn’t work. Maybe I’m doing it wrong? I have copied in the commands I’m using in the terminal. According to that it looks like the update is working fine. But when I start the MagicMirror there is still a notification at the top that the CalendarExt3 module is “2 commits behind the main grenen”.
                                    Also I can’t display the legend when I insert this under the config in the CalendarExt3 module.
                                    lilleberg@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-CalendarExt3
                                    lilleberg@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt3 $ git pull
                                    Updating 04883bc..ecd6b7a
                                    error: Your local changes to the following files would be overwritten by merge:
                                    	MMM-CalendarExt3.css
                                    	MMM-CalendarExt3.js
                                    Please commit your changes or stash them before you merge.
                                    Aborting
                                    lilleberg@raspberrypi:~/MagicMirror/modules/MMM-CalendarExt3 $ npm install
                                    up to date, audited 1 package in 598ms
                                    found 0 vulnerabilities
                                    • L Offline
                                      Lilleberg @MMRIZE
                                      @MMRIZE My language and locale are Norwegian. Using nb in the config file.
                                      • L Offline
                                        Lilleberg @MMRIZE
                                        @MMRIZE Thanks!
                                          sdetweil @Lilleberg
                                          MMM-CalendarExt3.js
                                          looks like u modified the module code, and updated cannot be applied til you fix that.
                                          generally you never edit the source files of a module.all config goes in config.js and all css updates go is custom.css
                                            bicolorbore586 @MMRIZE
                                            Is there an option to hide the week numbers? I’ve managed to remove the ‘cw’ using custom.css (albeit a bit untidy)
                                            • 10
                                            • 34
                                            • 35
                                            • 8 / 35
