    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 19.8k Views 3 Watching
      sdetweil @Richard238
      @Richard238 not pm2 start all
      pm2 status
      will show u the defined apps
      pm2 start ??
      where ?? is the name of the number of the app
      (usually 0)
      pm2 stop all just is a shortcut
      pm2 --help shows u all the things it can do.
      but the black screen could be because of the module rebuild failure
      pm2 logs – lines=100 might show more info
      and then there’s this
      my upgrade tries to handle the ones we know about
        Richard238
        @Richard238 said in Updating did nothing but gave fatal error warning.:
        MMM-MysqlQuery
        MMM-MysqlQuery seems to be the issue, I’ve commented it out of config .js,
        Will that be ok if I try pm2 start again?
          @Richard238 yes
            Richard238
            OK that’s brought MM back to life, but my custom CSS seems to have been ignored.
            That, and I need new weather modules?!
              @Richard238 you need to change to the new combined weather module…(announced 2 releases ago)
              supposedly change the module name field to weather and change the appid field name to apiKey
              custom.css should still be there… I save and restore
                Richard238
                custom.css is still there, but the coloured icons I had beside calendar entries are no longer showing.
                  Richard238 @sdetweil
                  @sdetweil Weather module changes worked.
                  They needs adjusting, but it is now showing something so it’s a good start I can work from.
                    @Richard238 colored icons
                    maybe see this
                    https://forum.magicmirror.builders/topic/16591/mmm-homeassistant-sensors-no-icons-after-mm-upgrade-to-2-19-0
                    electron is enforcing reported server side (CORS) restrictions is didn’t before , people protecting their content
                      Richard238
                      Colour, with a u! I’m British using British English! ;-)
                      OK, CSS. It’s only using favicon codes, not images on a URL
                       #module_3_calendar .fa.fa-calendar-check-o {
                        color: #00d255 /* 55=Green FF=Blue*/
                       #module_4_calendar  .fa.fa-trash-o  {
                        color: #C97F7F; /* Brown */
                        #module_3_calendar
                        u are using ID(#) to select
                        probably changed locations in the config.js
                        see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486123
                          Richard238
                          .calendar .fa.fa-calendar-check-o {
                          .calendar  .fa.fa-trash-o  {
                          Makes no difference, the icons still don’t show.
                          • karsten13K Offline
                            karsten13 @Richard238
                            @Richard238
                            what did you define in the symbol: section in the config.js?
                            May these icons are outdated, you can search here for icons, only free icons will work.
                              Richard238
                              I have these, both of which were working perfectly well prior to this update
                              symbol: 'calendar-check-o ',
                              symbol: 'trash-o ',
                              And having configured the new weather module, those icons are responding to custom css just fine.
                              No idea why calendar icons won’t work.
                                @Richard238 the trailing space?
                                  Richard238
                                  This worked perfectly prior to the most recent update.
                                  Deleted said space, still no icons.
                                  Appropriate code below for reference:
                                  			module: 'calendar',
                                  			header: 'Calendar',
                                  			position: 'top_left',
                                                      maximumEntries: 6, // Total Maximum Entries
                                                      maximumNumberOfDays: 365,
                                                      displaySymbol: true,
                                                      defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                                      displayRepeatingCountTitle: false,
                                                      defaultRepeatingCountTitle: "",
                                                      maxTitleLength: 30,
                                                      fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                                      animationSpeed: 2000,
                                                      fade: true,
                                                      showEnd: false,
                                                      urgency: 0,
                                                      timeFormat: "absolute",
                                                      dateFormat: "ddd Do MMMM",
                                                      getRelative: 0,
                                                      fadePoint: 0.50, // Start on 1/4th of the list.
                                                      hidePrivate: false,
                                  						symbol: 'calendar-check-o',
                                  						url: 'https://calendar.google.com/calendar################
                                  			module: 'calendar',
                                  			header: 'Binday',
                                  			position: 'bottom_left',
                                                      maximumEntries: 4, // Total Maximum Entries
                                                      maxTitleLength: 30,
                                                      fade: true,
                                                      showEnd: false,
                                                      urgency: 0,
                                                      getRelative: 0,
                                                      hidePrivate: false,
                                  						symbol: 'trash-o',
                                  						url: 'https://calendar.google.com/calendar#######################
                                                  titleReplace: {
                                                  //	"'s birthday": "",
                                                  //	"Recycling": "Bins",
                                                      "Red Bin": "Red & Black Bins",
                                                      "Green Bin": "Green & Black Bins"
                                                  // Override start method.
                                                  start: function () {
                                                      Log.log("Starting module: " + this.name);
                                                      for (var c in this.config.calendars) {
                                                          var calendar = this.config.calendars[c];
                                                          calendar.url = calendar.url.replace("webcal://", "http://");
                                                          this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                                      this.calendarData = {};
                                                      this.loaded = false;
                                    yep, the class name changed
                                    see
                                    https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486164
                                      Richard238
                                      Bit familiar with the F12 console, but it’s not easy to select the exact spot.
                                      Change it to this?
                                      .calendar.module.calendar  .fa.fa-calendar-check-o {
                                      Or?
                                        @Richard238 in main.css comment out cursor:none
                                        /* cursor:none */
                                        reload the MM page
                                        select the elements tab
                                        select the arrow top left of the developers page
                                        navigate the mouse to the check icon in the calendar display
                                        click on the icon
                                        int he elements page is the html of the element selected
                                        and its class name is shown
                                        use that …
                                        thats what I did, copied your css, didn’t work (as u said)
                                        found the element , and its new class name
                                        changed the css
                                        refreshed the page and it worked.
                                        I want YOU to do it, so next time you know how/why
                                          Richard238
                                          I guess ‘elements’ is from another browser type, I’m in Firefox where it’s called Inspector.
                                          But anyway, I clicked where the calendar icon ought to be, where its name shows on the cursor hover, and got this
                                          Changed css
                                          .calendar .fas fa-fw fa-calendar-check-o {
                                          Still no icon though :-/
                                            css selectors are the problem
                                            https://www.w3schools.com/cssref/css_selectors.asp
                                            so, your definition says
                                            for the CLASS calendar
                                            find ALL elements that match (.fas fa-fw fa-calendar-check)
                                            and set their color (foreground text color style ) to …
                                            so, lets examine the
                                            in the element this is ALL inside the class= attribute
                                            class="fas fa-fw fa-calendar-check"
                                            so to SELECT based on CLASS the names need dots in front
                                            name = tagname (<p, <img, <table …
                                            .name = class name ( .calendar
                                            #name = id of element ( id=“fred” #fred
                                            no space between selectors means ALL
                                            Selects all elements with both name1 and name2 set within its class attribute
                                            space between selectors means ALL AND directly child/parent
                                            Selects all elements with name2 that is a descendant of an element with name1
                                            and there are other types > < ~ … which mean this ??? in children elements, etc,
                                            what your string says is
                                            under the calendar CLASS (.calendar)
                                            for CLASS of fas (.fas)
                                            AND
                                            element of fa-fw (<fa-fw)
                                            AND
                                            element of fa-calendar-check (<fa-calendar-check)
                                            but you dont have the two ‘elements’ cause they are used in the class attribute
                                            in your case you only need ONE (not all)
                                            and its a CLASS (so leading .)
                                            .calendar .fa-calendar-check{
