    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 20.4k Views 3 Watching
      sdetweil @Richard238
      @Richard238 my script is made to run from anywhere… it 'assume’s you are NOT in the MagicMirror folder
      so, its simple… open a command prompt and paste…
      note that upgrade is a 2 part process… (You wouldn’t want me destroying your work for something u forgot about, right?)
      so, 1st run TESTS the ability to apply the update, but makes NO changes to anything running.
      it reports… files changed but might be overlayed… etc…
      if all is good and u feel comfortable,
      then you run it a second time with the ‘apply’ parameter
      to actually DO the upgrade process
        Richard238
        Tried the script, and got this node error:
        pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
        No LSB modules are available.
        Minimum Node version: v16.9.1
        Installed Node version: v16.1.0
        Node should be upgraded.
        A Node process is currently running. Can't upgrade.
        Please quit all Node processes and restart the update.
        running process(s) are
        pi 15102 15101 0 Jan08 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
        pi@magicmirror:~ $
          @Richard238 right. MagicMirror is running. you have to stop it before u can update
          as it appears we need to upgrade node and npm as well…
          pm2 stop all
          R 1 Reply Last reply
            Richard238 @sdetweil
            @sdetweil And then rerun the script?
              @Richard238 yes
                Richard238
                Node.js upgrade defered, doing test run
                Minimum npm version: V7.11.2
                Installed npm version: V7.11.2
                No npm upgrade necessary.
                saving custom.css
                upgrading from version 2.18.0 to 2.19.0
                fetching latest revisions
                there are 5 local files that are different than the master repo
                   config/config.js.sample
                   fonts/package-lock.json
                   modules/default/newsfeed/newsfeed.js
                   package-lock.json
                   vendor/package-lock.json
                any *-lock.json files do not need to be saved
                do you want to save these files for later   (Y/n)?
                processing for module MMM-MysqlQuery please wait
                skipped processing for MMM-MysqlQuery, doing test run
                processing complete for module MMM-MysqlQuery
                restoring custom.css
                test run, restoring files stashed
                pi@magicmirror:~ $
                  Richard238
                  pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                  doing test run = false
                  Installing Node.js ...
                  gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                  Reading package lists... Done
                  Building dependency tree
                  nodejs is already the newest version (17.3.1-deb-1nodesource1).
                  The following package was automatically installed and is no longer required:
                    python-colorzero
                  Use 'sudo apt autoremove' to remove it.
                  0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded.
                  node version is
                  Node.js installation Done! version=v16.1.0
                  saving custom.css
                  there are 2 local files that are different than the master repo
                  > magicmirror@2.19.0 install
                  > " && cd vendor && npm install --loglevel=error
                  changed 3 packages, and audited 10 packages in 22s
                  found 0 vulnerabilities
                  > magicmirror@2.19.0 postinstall
                  > npm run install-fonts && echo "MagicMirror² installation finished successfully!
                  > magicmirror@2.19.0 install-fonts
                  > echo "Installing fonts ...
                  > " && cd fonts && npm install --loglevel=error
                  added 2 packages, removed 1 package, and audited 3 packages in 5s
                  > magicmirror@2.19.0 prepare
                  > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                  no husky installed.
                  added 3 packages, removed 4 packages, changed 35 packages, and audited 266 packages in 2m
                  20 packages are looking for funding
                    run `npm fund` for details
                  npm notice
                  npm notice New major version of npm available! 7.11.2 -> 8.6.0
                  npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.6.0>
                  npm notice Run `npm install -g npm@8.6.0` to update!
                  npm notice
                  npm ERR! code ERESOLVE
                  npm ERR! ERESOLVE unable to resolve dependency tree
                  npm ERR!
                  npm ERR! While resolving: mmm-mysqlquery@1.0.0
                  npm ERR! Found: stylelint@8.4.0
                  npm ERR! node_modules/stylelint
                  npm ERR!   dev stylelint@"^8.3.0" from the root project
                  npm ERR!
                  npm ERR! Could not resolve dependency:
                  npm ERR! peer stylelint@"14.x" from grunt-stylelint@0.18.0
                  npm ERR! node_modules/grunt-stylelint
                  npm ERR!   dev grunt-stylelint@"latest" from the root project
                  npm ERR!
                  npm ERR! Fix the upstream dependency conflict, or retry
                  npm ERR! this command with --force, or --legacy-peer-deps
                  npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                  npm ERR!
                  npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
                  npm ERR!     /home/pi/.npm/_logs/2022-04-08T13_34_50_165Z-debug.log
                  we stashed a set of files that appear changed from the latest repo versions. you should review them
                  see installers/stashed_files for the list
                  you can use git checkout stash@{0} -- filename to extract one file from the stash
                  or git stash pop to restore them all
                  WARNING..
                  WARNING.. either will overlay the file just installed by the update
                  WARNING..
                  pi@magicmirror:~ $
                    Richard238
                    Then did
                    pm2 start all
                    and now have a black screen on the Pi, and ‘Unable to connect’ on the desktop browser. :-(
                      @Richard238 not pm2 start all
                      pm2 status
                      will show u the defined apps
                      pm2 start ??
                      where ?? is the name of the number of the app
                      (usually 0)
                      pm2 stop all just is a shortcut
                      pm2 --help shows u all the things it can do.
                      but the black screen could be because of the module rebuild failure
                      pm2 logs – lines=100 might show more info
                      and then there’s this
                      my upgrade tries to handle the ones we know about
                        Richard238
                        @Richard238 said in Updating did nothing but gave fatal error warning.:
                        MMM-MysqlQuery
                        MMM-MysqlQuery seems to be the issue, I’ve commented it out of config .js,
                        Will that be ok if I try pm2 start again?
                          @Richard238 yes
                            Richard238
                            OK that’s brought MM back to life, but my custom CSS seems to have been ignored.
                            That, and I need new weather modules?!
                              @Richard238 you need to change to the new combined weather module…(announced 2 releases ago)
                              supposedly change the module name field to weather and change the appid field name to apiKey
                              custom.css should still be there… I save and restore
                                Richard238
                                custom.css is still there, but the coloured icons I had beside calendar entries are no longer showing.
                                  @sdetweil Weather module changes worked.
                                  They needs adjusting, but it is now showing something so it’s a good start I can work from.
                                    @Richard238 colored icons
                                    maybe see this
                                    https://forum.magicmirror.builders/topic/16591/mmm-homeassistant-sensors-no-icons-after-mm-upgrade-to-2-19-0
                                    electron is enforcing reported server side (CORS) restrictions is didn’t before , people protecting their content
                                      Richard238
                                      Colour, with a u! I’m British using British English! ;-)
                                      OK, CSS. It’s only using favicon codes, not images on a URL
                                       #module_3_calendar .fa.fa-calendar-check-o {
                                        color: #00d255 /* 55=Green FF=Blue*/
                                       #module_4_calendar  .fa.fa-trash-o  {
                                        color: #C97F7F; /* Brown */
                                        #module_3_calendar
                                        u are using ID(#) to select
                                        probably changed locations in the config.js
                                        see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486123
                                          Richard238
                                          .calendar .fa.fa-calendar-check-o {
                                          .calendar  .fa.fa-trash-o  {
                                          Makes no difference, the icons still don’t show.
                                          karsten13K 1 Reply Last reply
                                          • karsten13K
                                            karsten13 @Richard238
                                            @Richard238
                                            what did you define in the symbol: section in the config.js?
                                            May these icons are outdated, you can search here for icons, only free icons will work.
