    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 19.8k Views 3 Watching
      Richard238 @sdetweil
      @sdetweil And then rerun the script?
        sdetweil @Richard238
        @Richard238 yes
          Richard238
          pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
          No LSB modules are available.
          Minimum Node version: v16.9.1
          Installed Node version: v16.1.0
          Node should be upgraded.
          Node.js upgrade defered, doing test run
          Minimum npm version: V7.11.2
          Installed npm version: V7.11.2
          No npm upgrade necessary.
          saving custom.css
          upgrading from version 2.18.0 to 2.19.0
          fetching latest revisions
          there are 5 local files that are different than the master repo
             config/config.js.sample
             fonts/package-lock.json
             modules/default/newsfeed/newsfeed.js
             package-lock.json
             vendor/package-lock.json
          any *-lock.json files do not need to be saved
          do you want to save these files for later   (Y/n)?
          processing for module MMM-MysqlQuery please wait
          skipped processing for MMM-MysqlQuery, doing test run
          processing complete for module MMM-MysqlQuery
          restoring custom.css
          test run, restoring files stashed
          pi@magicmirror:~ $
            Richard238
            pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
            doing test run = false
            Installing Node.js ...
            gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
            Reading package lists... Done
            Building dependency tree
            nodejs is already the newest version (17.3.1-deb-1nodesource1).
            The following package was automatically installed and is no longer required:
              python-colorzero
            Use 'sudo apt autoremove' to remove it.
            0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded.
            node version is
            Node.js installation Done! version=v16.1.0
            saving custom.css
            there are 2 local files that are different than the master repo
            > magicmirror@2.19.0 install
            > " && cd vendor && npm install --loglevel=error
            changed 3 packages, and audited 10 packages in 22s
            found 0 vulnerabilities
            > magicmirror@2.19.0 postinstall
            > npm run install-fonts && echo "MagicMirror² installation finished successfully!
            > magicmirror@2.19.0 install-fonts
            > echo "Installing fonts ...
            > " && cd fonts && npm install --loglevel=error
            added 2 packages, removed 1 package, and audited 3 packages in 5s
            > magicmirror@2.19.0 prepare
            > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
            no husky installed.
            added 3 packages, removed 4 packages, changed 35 packages, and audited 266 packages in 2m
            20 packages are looking for funding
              run `npm fund` for details
            npm notice
            npm notice New major version of npm available! 7.11.2 -> 8.6.0
            npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.6.0>
            npm notice Run `npm install -g npm@8.6.0` to update!
            npm notice
            npm ERR! code ERESOLVE
            npm ERR! ERESOLVE unable to resolve dependency tree
            npm ERR!
            npm ERR! While resolving: mmm-mysqlquery@1.0.0
            npm ERR! Found: stylelint@8.4.0
            npm ERR! node_modules/stylelint
            npm ERR!   dev stylelint@"^8.3.0" from the root project
            npm ERR!
            npm ERR! Could not resolve dependency:
            npm ERR! peer stylelint@"14.x" from grunt-stylelint@0.18.0
            npm ERR! node_modules/grunt-stylelint
            npm ERR!   dev grunt-stylelint@"latest" from the root project
            npm ERR!
            npm ERR! Fix the upstream dependency conflict, or retry
            npm ERR! this command with --force, or --legacy-peer-deps
            npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
            npm ERR!
            npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
            npm ERR!     /home/pi/.npm/_logs/2022-04-08T13_34_50_165Z-debug.log
            we stashed a set of files that appear changed from the latest repo versions. you should review them
            see installers/stashed_files for the list
            you can use git checkout stash@{0} -- filename to extract one file from the stash
            or git stash pop to restore them all
            WARNING..
            WARNING.. either will overlay the file just installed by the update
            WARNING..
            pi@magicmirror:~ $
              Richard238
              Then did
              pm2 start all
              and now have a black screen on the Pi, and ‘Unable to connect’ on the desktop browser. :-(
                @Richard238 not pm2 start all
                pm2 status
                will show u the defined apps
                pm2 start ??
                where ?? is the name of the number of the app
                (usually 0)
                pm2 stop all just is a shortcut
                pm2 --help shows u all the things it can do.
                but the black screen could be because of the module rebuild failure
                pm2 logs – lines=100 might show more info
                and then there’s this
                my upgrade tries to handle the ones we know about
                  Richard238
                  @Richard238 said in Updating did nothing but gave fatal error warning.:
                  MMM-MysqlQuery
                  MMM-MysqlQuery seems to be the issue, I’ve commented it out of config .js,
                  Will that be ok if I try pm2 start again?
                    @Richard238 yes
                      Richard238
                      OK that’s brought MM back to life, but my custom CSS seems to have been ignored.
                      That, and I need new weather modules?!
                        @Richard238 you need to change to the new combined weather module…(announced 2 releases ago)
                        supposedly change the module name field to weather and change the appid field name to apiKey
                        custom.css should still be there… I save and restore
                          Richard238
                          custom.css is still there, but the coloured icons I had beside calendar entries are no longer showing.
                            @sdetweil Weather module changes worked.
                            They needs adjusting, but it is now showing something so it’s a good start I can work from.
                              @Richard238 colored icons
                              maybe see this
                              https://forum.magicmirror.builders/topic/16591/mmm-homeassistant-sensors-no-icons-after-mm-upgrade-to-2-19-0
                              electron is enforcing reported server side (CORS) restrictions is didn’t before , people protecting their content
                                Richard238
                                Colour, with a u! I’m British using British English! ;-)
                                OK, CSS. It’s only using favicon codes, not images on a URL
                                 #module_3_calendar .fa.fa-calendar-check-o {
                                  color: #00d255 /* 55=Green FF=Blue*/
                                 #module_4_calendar  .fa.fa-trash-o  {
                                  color: #C97F7F; /* Brown */
                                  #module_3_calendar
                                  u are using ID(#) to select
                                  probably changed locations in the config.js
                                  see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486123
                                    Richard238
                                    .calendar .fa.fa-calendar-check-o {
                                    .calendar  .fa.fa-trash-o  {
                                    Makes no difference, the icons still don’t show.
                                    • karsten13K Offline
                                      karsten13 @Richard238
                                      @Richard238
                                      what did you define in the symbol: section in the config.js?
                                      May these icons are outdated, you can search here for icons, only free icons will work.
                                        Richard238
                                        I have these, both of which were working perfectly well prior to this update
                                        symbol: 'calendar-check-o ',
                                        symbol: 'trash-o ',
                                        And having configured the new weather module, those icons are responding to custom css just fine.
                                        No idea why calendar icons won’t work.
                                          @Richard238 the trailing space?
                                            Richard238
                                            This worked perfectly prior to the most recent update.
                                            Deleted said space, still no icons.
                                            Appropriate code below for reference:
                                            			module: 'calendar',
                                            			header: 'Calendar',
                                            			position: 'top_left',
        maximumEntries: 6, // Total Maximum Entries
        maximumNumberOfDays: 365,
        displaySymbol: true,
        defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
        displayRepeatingCountTitle: false,
        defaultRepeatingCountTitle: "",
        maxTitleLength: 30,
        fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
        animationSpeed: 2000,
        fade: true,
        showEnd: false,
        urgency: 0,
        timeFormat: "absolute",
        dateFormat: "ddd Do MMMM",
        getRelative: 0,
        fadePoint: 0.50, // Start on 1/4th of the list.
        hidePrivate: false,
                                            						symbol: 'calendar-check-o',
                                            						url: 'https://calendar.google.com/calendar################
                                            			module: 'calendar',
                                            			header: 'Binday',
                                            			position: 'bottom_left',
        maximumEntries: 4, // Total Maximum Entries
        maxTitleLength: 30,
        fade: true,
        showEnd: false,
        urgency: 0,
        getRelative: 0,
        hidePrivate: false,
                                            						symbol: 'trash-o',
                                            						url: 'https://calendar.google.com/calendar#######################
                                                            titleReplace: {
                                                            //	"'s birthday": "",
                                                            //	"Recycling": "Bins",
        "Red Bin": "Red & Black Bins",
        "Green Bin": "Green & Black Bins"
                                                            // Override start method.
                                                            start: function () {
        Log.log("Starting module: " + this.name);
        for (var c in this.config.calendars) {
        var calendar = this.config.calendars[c];
        calendar.url = calendar.url.replace("webcal://", "http://");
        this.addCalendar(calendar.url, calendar.user, calendar.pass);
        this.calendarData = {};
        this.loaded = false;
