    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 19.4k Views 3 Watching
      Richard238
      OK that’s brought MM back to life, but my custom CSS seems to have been ignored.
      That, and I need new weather modules?!
        sdetweil @Richard238
        @Richard238 you need to change to the new combined weather module…(announced 2 releases ago)
        supposedly change the module name field to weather and change the appid field name to apiKey
        custom.css should still be there… I save and restore
          Richard238
          custom.css is still there, but the coloured icons I had beside calendar entries are no longer showing.
            Richard238 @sdetweil
            @sdetweil Weather module changes worked.
            They needs adjusting, but it is now showing something so it’s a good start I can work from.
              @Richard238 colored icons
              maybe see this
              https://forum.magicmirror.builders/topic/16591/mmm-homeassistant-sensors-no-icons-after-mm-upgrade-to-2-19-0
              electron is enforcing reported server side (CORS) restrictions is didn’t before , people protecting their content
                Richard238
                Colour, with a u! I’m British using British English! ;-)
                OK, CSS. It’s only using favicon codes, not images on a URL
                 #module_3_calendar .fa.fa-calendar-check-o {
                  color: #00d255 /* 55=Green FF=Blue*/
                 #module_4_calendar  .fa.fa-trash-o  {
                  color: #C97F7F; /* Brown */
                  @Richard238 said in Updating did nothing but gave fatal error warning.:
                  #module_3_calendar
                  u are using ID(#) to select
                  probably changed locations in the config.js
                  see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486123
                    Richard238
                    .calendar .fa.fa-calendar-check-o {
                    .calendar  .fa.fa-trash-o  {
                    Makes no difference, the icons still don’t show.
                    • karsten13K Offline
                      karsten13 @Richard238
                      @Richard238
                      what did you define in the symbol: section in the config.js?
                      May these icons are outdated, you can search here for icons, only free icons will work.
                        Richard238
                        I have these, both of which were working perfectly well prior to this update
                        symbol: 'calendar-check-o ',
                        symbol: 'trash-o ',
                        And having configured the new weather module, those icons are responding to custom css just fine.
                        No idea why calendar icons won’t work.
                          @Richard238 the trailing space?
                            Richard238
                            This worked perfectly prior to the most recent update.
                            Deleted said space, still no icons.
                            Appropriate code below for reference:
                            			module: 'calendar',
                            			header: 'Calendar',
                            			position: 'top_left',
                                                maximumEntries: 6, // Total Maximum Entries
                                                maximumNumberOfDays: 365,
                                                displaySymbol: true,
                                                defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                                displayRepeatingCountTitle: false,
                                                defaultRepeatingCountTitle: "",
                                                maxTitleLength: 30,
                                                fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                                animationSpeed: 2000,
                                                fade: true,
                                                showEnd: false,
                                                urgency: 0,
                                                timeFormat: "absolute",
                                                dateFormat: "ddd Do MMMM",
                                                getRelative: 0,
                                                fadePoint: 0.50, // Start on 1/4th of the list.
                                                hidePrivate: false,
                            						symbol: 'calendar-check-o',
                            						url: 'https://calendar.google.com/calendar################
                            			module: 'calendar',
                            			header: 'Binday',
                            			position: 'bottom_left',
                                                maximumEntries: 4, // Total Maximum Entries
                                                maxTitleLength: 30,
                                                fade: true,
                                                showEnd: false,
                                                urgency: 0,
                                                getRelative: 0,
                                                hidePrivate: false,
                            						symbol: 'trash-o',
                            						url: 'https://calendar.google.com/calendar#######################
                                            titleReplace: {
                                            //	"'s birthday": "",
                                            //	"Recycling": "Bins",
                                                "Red Bin": "Red & Black Bins",
                                                "Green Bin": "Green & Black Bins"
                                            // Override start method.
                                            start: function () {
                                                Log.log("Starting module: " + this.name);
                                                for (var c in this.config.calendars) {
                                                    var calendar = this.config.calendars[c];
                                                    calendar.url = calendar.url.replace("webcal://", "http://");
                                                    this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                                this.calendarData = {};
                                                this.loaded = false;
                              yep, the class name changed
                              see
                              https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486164
                                Richard238
                                Bit familiar with the F12 console, but it’s not easy to select the exact spot.
                                Change it to this?
                                .calendar.module.calendar  .fa.fa-calendar-check-o {
                                Or?
                                  @Richard238 in main.css comment out cursor:none
                                  /* cursor:none */
                                  reload the MM page
                                  select the elements tab
                                  select the arrow top left of the developers page
                                  navigate the mouse to the check icon in the calendar display
                                  click on the icon
                                  int he elements page is the html of the element selected
                                  and its class name is shown
                                  use that …
                                  thats what I did, copied your css, didn’t work (as u said)
                                  found the element , and its new class name
                                  changed the css
                                  refreshed the page and it worked.
                                  I want YOU to do it, so next time you know how/why
                                    Richard238
                                    I guess ‘elements’ is from another browser type, I’m in Firefox where it’s called Inspector.
                                    But anyway, I clicked where the calendar icon ought to be, where its name shows on the cursor hover, and got this
                                    Changed css
                                    .calendar .fas fa-fw fa-calendar-check-o {
                                    Still no icon though :-/
                                      css selectors are the problem
                                      https://www.w3schools.com/cssref/css_selectors.asp
                                      so, your definition says
                                      for the CLASS calendar
                                      find ALL elements that match (.fas fa-fw fa-calendar-check)
                                      and set their color (foreground text color style ) to …
                                      so, lets examine the
                                      in the element this is ALL inside the class= attribute
                                      class="fas fa-fw fa-calendar-check"
                                      so to SELECT based on CLASS the names need dots in front
                                      name = tagname (<p, <img, <table …
                                      .name = class name ( .calendar
                                      #name = id of element ( id=“fred” #fred
                                      no space between selectors means ALL
                                      Selects all elements with both name1 and name2 set within its class attribute
                                      space between selectors means ALL AND directly child/parent
                                      Selects all elements with name2 that is a descendant of an element with name1
                                      and there are other types > < ~ … which mean this ??? in children elements, etc,
                                      what your string says is
                                      under the calendar CLASS (.calendar)
                                      for CLASS of fas (.fas)
                                      AND
                                      element of fa-fw (<fa-fw)
                                      AND
                                      element of fa-calendar-check (<fa-calendar-check)
                                      but you dont have the two ‘elements’ cause they are used in the class attribute
                                      in your case you only need ONE (not all)
                                      and its a CLASS (so leading .)
                                      .calendar .fa-calendar-check{
                                        Richard238
                                        Goodness, that’s complicated! Well, it kinda makes sense but, I’ll read it again when not so tired.
                                        Sadly, still nothing. (Commented second one out in case it was the cause, but no luck there.)
                                         .calendar .fa-calendar-check-o {
                                          color: #00d255 /* 55=Green FF=Blue */
                                        .calendar .fa-trash-o  {
                                        Also tried a known working fa icon from the weather module, but again, nothing.
                                          @Richard238 it worked with the change (oops)
                                          note that the selector is NOT -o
                                          I used your text in the message, not the ACTUAL class on the element… my bad…
                                          thats why we LOOK IT UP!..
                                            Richard238
                                            Even though the icon is fa-calendar-check-o
                                            https://fontawesome.com/v4/icon/calendar-check-o
                                            we omit the -o ?
                                            • 2 / 3
