    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 19.4k Views 3 Watching
      Richard238 @sdetweil
      @sdetweil Weather module changes worked.
      They needs adjusting, but it is now showing something so it’s a good start I can work from.
        sdetweil @Richard238
        @Richard238 colored icons
        maybe see this
        https://forum.magicmirror.builders/topic/16591/mmm-homeassistant-sensors-no-icons-after-mm-upgrade-to-2-19-0
        electron is enforcing reported server side (CORS) restrictions is didn’t before , people protecting their content
          Richard238
          Colour, with a u! I’m British using British English! ;-)
          OK, CSS. It’s only using favicon codes, not images on a URL
           #module_3_calendar .fa.fa-calendar-check-o {
            color: #00d255 /* 55=Green FF=Blue*/
           #module_4_calendar  .fa.fa-trash-o  {
            color: #C97F7F; /* Brown */
            @Richard238 said in Updating did nothing but gave fatal error warning.:
            #module_3_calendar
            u are using ID(#) to select
            probably changed locations in the config.js
            see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486123
              Richard238
              .calendar .fa.fa-calendar-check-o {
              .calendar  .fa.fa-trash-o  {
              Makes no difference, the icons still don’t show.
              • karsten13K Offline
                karsten13 @Richard238
                @Richard238
                what did you define in the symbol: section in the config.js?
                May these icons are outdated, you can search here for icons, only free icons will work.
                  Richard238
                  I have these, both of which were working perfectly well prior to this update
                  symbol: 'calendar-check-o ',
                  symbol: 'trash-o ',
                  And having configured the new weather module, those icons are responding to custom css just fine.
                  No idea why calendar icons won’t work.
                    @Richard238 the trailing space?
                      Richard238
                      This worked perfectly prior to the most recent update.
                      Deleted said space, still no icons.
                      Appropriate code below for reference:
                      			module: 'calendar',
                      			header: 'Calendar',
                      			position: 'top_left',
                                          maximumEntries: 6, // Total Maximum Entries
                                          maximumNumberOfDays: 365,
                                          displaySymbol: true,
                                          defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                          displayRepeatingCountTitle: false,
                                          defaultRepeatingCountTitle: "",
                                          maxTitleLength: 30,
                                          fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                          animationSpeed: 2000,
                                          fade: true,
                                          showEnd: false,
                                          urgency: 0,
                                          timeFormat: "absolute",
                                          dateFormat: "ddd Do MMMM",
                                          getRelative: 0,
                                          fadePoint: 0.50, // Start on 1/4th of the list.
                                          hidePrivate: false,
                      						symbol: 'calendar-check-o',
                      						url: 'https://calendar.google.com/calendar################
                      			module: 'calendar',
                      			header: 'Binday',
                      			position: 'bottom_left',
                                          maximumEntries: 4, // Total Maximum Entries
                                          maxTitleLength: 30,
                                          fade: true,
                                          showEnd: false,
                                          urgency: 0,
                                          getRelative: 0,
                                          hidePrivate: false,
                      						symbol: 'trash-o',
                      						url: 'https://calendar.google.com/calendar#######################
                                      titleReplace: {
                                      //	"'s birthday": "",
                                      //	"Recycling": "Bins",
                                          "Red Bin": "Red & Black Bins",
                                          "Green Bin": "Green & Black Bins"
                                      // Override start method.
                                      start: function () {
                                          Log.log("Starting module: " + this.name);
                                          for (var c in this.config.calendars) {
                                              var calendar = this.config.calendars[c];
                                              calendar.url = calendar.url.replace("webcal://", "http://");
                                              this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                          this.calendarData = {};
                                          this.loaded = false;
                        yep, the class name changed
                        see
                        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486164
                          Richard238
                          Bit familiar with the F12 console, but it’s not easy to select the exact spot.
                          Change it to this?
                          .calendar.module.calendar  .fa.fa-calendar-check-o {
                          Or?
                            @Richard238 in main.css comment out cursor:none
                            /* cursor:none */
                            reload the MM page
                            select the elements tab
                            select the arrow top left of the developers page
                            navigate the mouse to the check icon in the calendar display
                            click on the icon
                            int he elements page is the html of the element selected
                            and its class name is shown
                            use that …
                            thats what I did, copied your css, didn’t work (as u said)
                            found the element , and its new class name
                            changed the css
                            refreshed the page and it worked.
                            I want YOU to do it, so next time you know how/why
                              Richard238
                              I guess ‘elements’ is from another browser type, I’m in Firefox where it’s called Inspector.
                              But anyway, I clicked where the calendar icon ought to be, where its name shows on the cursor hover, and got this
                              Changed css
                              .calendar .fas fa-fw fa-calendar-check-o {
                              Still no icon though :-/
                                css selectors are the problem
                                https://www.w3schools.com/cssref/css_selectors.asp
                                so, your definition says
                                for the CLASS calendar
                                find ALL elements that match (.fas fa-fw fa-calendar-check)
                                and set their color (foreground text color style ) to …
                                so, lets examine the
                                in the element this is ALL inside the class= attribute
                                class="fas fa-fw fa-calendar-check"
                                so to SELECT based on CLASS the names need dots in front
                                name = tagname (<p, <img, <table …
                                .name = class name ( .calendar
                                #name = id of element ( id=“fred” #fred
                                no space between selectors means ALL
                                Selects all elements with both name1 and name2 set within its class attribute
                                space between selectors means ALL AND directly child/parent
                                Selects all elements with name2 that is a descendant of an element with name1
                                and there are other types > < ~ … which mean this ??? in children elements, etc,
                                what your string says is
                                under the calendar CLASS (.calendar)
                                for CLASS of fas (.fas)
                                AND
                                element of fa-fw (<fa-fw)
                                AND
                                element of fa-calendar-check (<fa-calendar-check)
                                but you dont have the two ‘elements’ cause they are used in the class attribute
                                in your case you only need ONE (not all)
                                and its a CLASS (so leading .)
                                .calendar .fa-calendar-check{
                                  Richard238
                                  Goodness, that’s complicated! Well, it kinda makes sense but, I’ll read it again when not so tired.
                                  Sadly, still nothing. (Commented second one out in case it was the cause, but no luck there.)
                                   .calendar .fa-calendar-check-o {
                                    color: #00d255 /* 55=Green FF=Blue */
                                  .calendar .fa-trash-o  {
                                  Also tried a known working fa icon from the weather module, but again, nothing.
                                    @Richard238 it worked with the change (oops)
                                    note that the selector is NOT -o
                                    I used your text in the message, not the ACTUAL class on the element… my bad…
                                    thats why we LOOK IT UP!..
                                      Richard238
                                      Even though the icon is fa-calendar-check-o
                                      https://fontawesome.com/v4/icon/calendar-check-o
                                      we omit the -o ?
                                        @Richard238 see the exact class used on the element, we use the ACTUAL info, not whatever ‘config’ says
                                        oh, using on MY machine, using the default calendar config …
                                          Richard238
                                          class? element? I try, but I’m not much of a coder. I’m hopelessly lost, as I’m sure you can tell.
                                          I appreciate your efforts but sadly this is way beyond my skills. :(
                                          I’ll live without the icon for now and perhaps revisit another day.
                                            @Richard238 and I look at the fontawesome 6 lib and calendar-check-o is no more
                                            I set calendar-check-o in my config and get nothing, look at the elements and see fa-calendar-check-o
                                            but it doesn’t exist
                                            https://fontawesome.com/icons
                                            • 2 / 3
