    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 20.4k Views 3 Watching
      sdetweil @Richard238
      @Richard238 said in Updating did nothing but gave fatal error warning.:
      #module_3_calendar
      u are using ID(#) to select
      probably changed locations in the config.js
      see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486123
        Richard238
        .calendar .fa.fa-calendar-check-o {
          color: #00d255 /* 55=Green FF=Blue*/
        .calendar  .fa.fa-trash-o  {
          color: #C97F7F; /* Brown */
        Makes no difference, the icons still don’t show.
        • karsten13K
          karsten13 @Richard238
          @Richard238
          what did you define in the symbol: section in the config.js?
          May these icons are outdated, you can search here for icons, only free icons will work.
            Richard238
            I have these, both of which were working perfectly well prior to this update
            symbol: 'calendar-check-o ',
            symbol: 'trash-o ',
            And having configured the new weather module, those icons are responding to custom css just fine.
            No idea why calendar icons won’t work.
              @Richard238 the trailing space?
                Richard238
                This worked perfectly prior to the most recent update.
                Deleted said space, still no icons.
                Appropriate code below for reference:
                			module: 'calendar',
                			header: 'Calendar',
                			position: 'top_left',
                                    maximumEntries: 6, // Total Maximum Entries
                                    maximumNumberOfDays: 365,
                                    displaySymbol: true,
                                    defaultSymbol: "calendar", // Fontawesome Symbol see http://fontawesome.io/cheatsheet/
                                    displayRepeatingCountTitle: false,
                                    defaultRepeatingCountTitle: "",
                                    maxTitleLength: 30,
                                    fetchInterval: 5 * 60 * 1000, // Update every 5 minutes.
                                    animationSpeed: 2000,
                                    fade: true,
                                    showEnd: false,
                                    urgency: 0,
                                    timeFormat: "absolute",
                                    dateFormat: "ddd Do MMMM",
                                    getRelative: 0,
                                    fadePoint: 0.50, // Start on 1/4th of the list.
                                    hidePrivate: false,
                						symbol: 'calendar-check-o',
                						url: 'https://calendar.google.com/calendar################
                			module: 'calendar',
                			header: 'Binday',
                			position: 'bottom_left',
                                    maximumEntries: 4, // Total Maximum Entries
                                    maxTitleLength: 30,
                                    fade: true,
                                    showEnd: false,
                                    urgency: 0,
                                    getRelative: 0,
                                    hidePrivate: false,
                						symbol: 'trash-o',
                						url: 'https://calendar.google.com/calendar#######################
                                titleReplace: {
                                //	"'s birthday": "",
                                //	"Recycling": "Bins",
                                    "Red Bin": "Red & Black Bins",
                                    "Green Bin": "Green & Black Bins"
                                // Override start method.
                                start: function () {
                                    Log.log("Starting module: " + this.name);
                                    for (var c in this.config.calendars) {
                                        var calendar = this.config.calendars[c];
                                        calendar.url = calendar.url.replace("webcal://", "http://");
                                        this.addCalendar(calendar.url, calendar.user, calendar.pass);
                                    this.calendarData = {};
                                    this.loaded = false;
                  yep, the class name changed
                  see
                  https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486164
                    Richard238
                    Bit familiar with the F12 console, but it’s not easy to select the exact spot.
                    Change it to this?
                    .calendar.module.calendar  .fa.fa-calendar-check-o {
                    Or?
                      @Richard238 in main.css comment out cursor:none
                      /* cursor:none */
                      reload the MM page
                      select the elements tab
                      select the arrow top left of the developers page
                      navigate the mouse to the check icon in the calendar display
                      click on the icon
                      int he elements page is the html of the element selected
                      and its class name is shown
                      use that …
                      thats what I did, copied your css, didn’t work (as u said)
                      found the element , and its new class name
                      changed the css
                      refreshed the page and it worked.
                      I want YOU to do it, so next time you know how/why
                        Richard238
                        I guess ‘elements’ is from another browser type, I’m in Firefox where it’s called Inspector.
                        But anyway, I clicked where the calendar icon ought to be, where its name shows on the cursor hover, and got this
                        Changed css
                        .calendar .fas fa-fw fa-calendar-check-o {
                        Still no icon though :-/
                          css selectors are the problem
                          https://www.w3schools.com/cssref/css_selectors.asp
                          so, your definition says
                          for the CLASS calendar
                          find ALL elements that match (.fas fa-fw fa-calendar-check)
                          and set their color (foreground text color style ) to …
                          so, lets examine the
                          in the element this is ALL inside the class= attribute
                          class="fas fa-fw fa-calendar-check"
                          so to SELECT based on CLASS the names need dots in front
                          name = tagname (<p, <img, <table …
                          .name = class name ( .calendar
                          #name = id of element ( id=“fred” #fred
                          no space between selectors means ALL
                          Selects all elements with both name1 and name2 set within its class attribute
                          space between selectors means ALL AND directly child/parent
                          Selects all elements with name2 that is a descendant of an element with name1
                          and there are other types > < ~ … which mean this ??? in children elements, etc,
                          what your string says is
                          under the calendar CLASS (.calendar)
                          for CLASS of fas (.fas)
                          AND
                          element of fa-fw (<fa-fw)
                          AND
                          element of fa-calendar-check (<fa-calendar-check)
                          but you dont have the two ‘elements’ cause they are used in the class attribute
                          in your case you only need ONE (not all)
                          and its a CLASS (so leading .)
                          .calendar .fa-calendar-check{
                            Richard238
                            Goodness, that’s complicated! Well, it kinda makes sense but, I’ll read it again when not so tired.
                            Sadly, still nothing. (Commented second one out in case it was the cause, but no luck there.)
                             .calendar .fa-calendar-check-o {
                              color: #00d255 /* 55=Green FF=Blue */
                            .calendar .fa-trash-o  {
                            Also tried a known working fa icon from the weather module, but again, nothing.
                              @Richard238 it worked with the change (oops)
                              note that the selector is NOT -o
                              I used your text in the message, not the ACTUAL class on the element… my bad…
                              thats why we LOOK IT UP!..
                                Richard238
                                Even though the icon is fa-calendar-check-o
                                https://fontawesome.com/v4/icon/calendar-check-o
                                we omit the -o ?
                                  @Richard238 see the exact class used on the element, we use the ACTUAL info, not whatever ‘config’ says
                                  oh, using on MY machine, using the default calendar config …
                                    Richard238
                                    class? element? I try, but I’m not much of a coder. I’m hopelessly lost, as I’m sure you can tell.
                                    I appreciate your efforts but sadly this is way beyond my skills. :(
                                    I’ll live without the icon for now and perhaps revisit another day.
                                      @Richard238 and I look at the fontawesome 6 lib and calendar-check-o is no more
                                      I set calendar-check-o in my config and get nothing, look at the elements and see fa-calendar-check-o
                                      but it doesn’t exist
                                      https://fontawesome.com/icons
                                        Richard238
                                        Not coloured (even changing solid to light), but it’s an icon :)
                                        .calendar .fa-solid fa-calendar {
                                        .calendar .fa-light fa-trash-can  {
                                        The other icons used to work, pre update.
                                        Did MM change which fa library they use?
                                        The fa libraries ought to be backwards compatible, no?
                                        More tomorrow, I need sleep. :sleeping_face:
                                          @Richard238 yes, libs should be backward compatible… but nobody cares much for that anymore…
                                            Richard238
                                            I now have coloured icons in the calendar:
                                            Code now looks like this:
                                            /* Calendar: config.js set to  symbol: 'fa-light fa-calendar', */
                                            .calendar .fa-calendar-day {
                                            /* Calendar: config.js set to  symbol: 'fa-light fa-trash-can', */
                                            .calendar .fa-trash  {
                                              color: #C97F7F /* Brown */
                                            • 2 / 3
