    Updating did nothing but gave fatal error warning.
    41 Posts 4 Posters 18.5k Views 3 Watching
      Richard238
      MM reports being 119 commits behind. OK!
      Went to https://docs.magicmirror.builders/getting-started/upgrade-guide.html
      Did the suggested backups OK
      Went to :~/MagicMirror $ entered git pull && npm install --only=prod --omit=dev
      Got this: fatal: Unable to read current working directory: No such file or directory
      Looked at sdetweil’s script, not sure from the instructions if it need to be
      run from :~/MagicMirror $ or elsewhere?
      Thank you.
      mumblebajM S 2 Replies Last reply Reply Quote 0
        Richard238
        I now have coloured icons in the calendar:
        Code now looks like this:
        /* Calendar: config.js set to  symbol: 'fa-light fa-calendar', */
        .calendar .fa-calendar-day {
          color: #00d255 /* 55=Green FF=Blue */
        /* Calendar: config.js set to  symbol: 'fa-light fa-trash-can', */
        .calendar .fa-trash  {
          color: #C97F7F /* Brown */
        • mumblebajM Offline
          mumblebaj Module Developer @Richard238
          @Richard238 You can run Sam’s script from pretty much anywhere. I usually run it from the MagicMirror folder.
            sdetweil @Richard238
            @Richard238 my script is made to run from anywhere… it 'assume’s you are NOT in the MagicMirror folder
            so, its simple… open a command prompt and paste…
            note that upgrade is a 2 part process… (You wouldn’t want me destroying your work for something u forgot about, right?)
            so, 1st run TESTS the ability to apply the update, but makes NO changes to anything running.
            it reports… files changed but might be overlayed… etc…
            if all is good and u feel comfortable,
            then you run it a second time with the ‘apply’ parameter
            to actually DO the upgrade process
              Richard238
              Tried the script, and got this node error:
              pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
              No LSB modules are available.
              Minimum Node version: v16.9.1
              Installed Node version: v16.1.0
              Node should be upgraded.
              A Node process is currently running. Can't upgrade.
              Please quit all Node processes and restart the update.
              running process(s) are
              pi 15102 15101 0 Jan08 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
              pi@magicmirror:~ $
                @Richard238 right. MagicMirror is running. you have to stop it before u can update
                as it appears we need to upgrade node and npm as well…
                pm2 stop all
                  Richard238 @sdetweil
                  @sdetweil And then rerun the script?
                    @Richard238 yes
                      Richard238
                      Node.js upgrade defered, doing test run
                      Minimum npm version: V7.11.2
                      Installed npm version: V7.11.2
                      No npm upgrade necessary.
                      saving custom.css
                      upgrading from version 2.18.0 to 2.19.0
                      fetching latest revisions
                      there are 5 local files that are different than the master repo
                         config/config.js.sample
                         fonts/package-lock.json
                         modules/default/newsfeed/newsfeed.js
                         package-lock.json
                         vendor/package-lock.json
                      any *-lock.json files do not need to be saved
                      do you want to save these files for later   (Y/n)?
                      processing for module MMM-MysqlQuery please wait
                      skipped processing for MMM-MysqlQuery, doing test run
                      processing complete for module MMM-MysqlQuery
                      restoring custom.css
                      test run, restoring files stashed
                      pi@magicmirror:~ $
                        Richard238
                        pi@magicmirror:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                        doing test run = false
                        Installing Node.js ...
                        gpg: WARNING: unsafe ownership on homedir '/home/pi/.gnupg'
                        Reading package lists... Done
                        Building dependency tree
                        nodejs is already the newest version (17.3.1-deb-1nodesource1).
                        The following package was automatically installed and is no longer required:
                          python-colorzero
                        Use 'sudo apt autoremove' to remove it.
                        0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded.
                        node version is
                        Node.js installation Done! version=v16.1.0
                        saving custom.css
                        there are 2 local files that are different than the master repo
                        > magicmirror@2.19.0 install
                        > " && cd vendor && npm install --loglevel=error
                        changed 3 packages, and audited 10 packages in 22s
                        found 0 vulnerabilities
                        > magicmirror@2.19.0 postinstall
                        > npm run install-fonts && echo "MagicMirror² installation finished successfully!
                        > magicmirror@2.19.0 install-fonts
                        > echo "Installing fonts ...
                        > " && cd fonts && npm install --loglevel=error
                        added 2 packages, removed 1 package, and audited 3 packages in 5s
                        > magicmirror@2.19.0 prepare
                        > [ -f node_modules/.bin/husky ] && husky install || echo no husky installed.
                        no husky installed.
                        added 3 packages, removed 4 packages, changed 35 packages, and audited 266 packages in 2m
                        20 packages are looking for funding
                          run `npm fund` for details
                        npm notice
                        npm notice New major version of npm available! 7.11.2 -> 8.6.0
                        npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.6.0>
                        npm notice Run `npm install -g npm@8.6.0` to update!
                        npm notice
                        npm ERR! code ERESOLVE
                        npm ERR! ERESOLVE unable to resolve dependency tree
                        npm ERR!
                        npm ERR! While resolving: mmm-mysqlquery@1.0.0
                        npm ERR! Found: stylelint@8.4.0
                        npm ERR! node_modules/stylelint
                        npm ERR!   dev stylelint@"^8.3.0" from the root project
                        npm ERR!
                        npm ERR! Could not resolve dependency:
                        npm ERR! peer stylelint@"14.x" from grunt-stylelint@0.18.0
                        npm ERR! node_modules/grunt-stylelint
                        npm ERR!   dev grunt-stylelint@"latest" from the root project
                        npm ERR!
                        npm ERR! Fix the upstream dependency conflict, or retry
                        npm ERR! this command with --force, or --legacy-peer-deps
                        npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                        npm ERR!
                        npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
                        npm ERR!     /home/pi/.npm/_logs/2022-04-08T13_34_50_165Z-debug.log
                        we stashed a set of files that appear changed from the latest repo versions. you should review them
                        see installers/stashed_files for the list
                        you can use git checkout stash@{0} -- filename to extract one file from the stash
                        or git stash pop to restore them all
                        WARNING..
                        WARNING.. either will overlay the file just installed by the update
                        WARNING..
                        pi@magicmirror:~ $
                          Richard238
                          Then did
                          pm2 start all
                          and now have a black screen on the Pi, and ‘Unable to connect’ on the desktop browser. :-(
                            @Richard238 not pm2 start all
                            pm2 status
                            will show u the defined apps
                            pm2 start ??
                            where ?? is the name of the number of the app
                            (usually 0)
                            pm2 stop all just is a shortcut
                            pm2 --help shows u all the things it can do.
                            but the black screen could be because of the module rebuild failure
                            pm2 logs – lines=100 might show more info
                            and then there’s this
                            my upgrade tries to handle the ones we know about
                              Richard238
                              @Richard238 said in Updating did nothing but gave fatal error warning.:
                              MMM-MysqlQuery
                              MMM-MysqlQuery seems to be the issue, I’ve commented it out of config .js,
                              Will that be ok if I try pm2 start again?
                                @Richard238 yes
                                  Richard238
                                  OK that’s brought MM back to life, but my custom CSS seems to have been ignored.
                                  That, and I need new weather modules?!
                                    @Richard238 you need to change to the new combined weather module…(announced 2 releases ago)
                                    supposedly change the module name field to weather and change the appid field name to apiKey
                                    custom.css should still be there… I save and restore
                                      Richard238
                                      custom.css is still there, but the coloured icons I had beside calendar entries are no longer showing.
                                        @sdetweil Weather module changes worked.
                                        They needs adjusting, but it is now showing something so it’s a good start I can work from.
                                          @Richard238 colored icons
                                          maybe see this
                                          https://forum.magicmirror.builders/topic/16591/mmm-homeassistant-sensors-no-icons-after-mm-upgrade-to-2-19-0
                                          electron is enforcing reported server side (CORS) restrictions is didn’t before , people protecting their content
                                            Richard238
                                            Colour, with a u! I’m British using British English! ;-)
                                            OK, CSS. It’s only using favicon codes, not images on a URL
                                             #module_3_calendar .fa.fa-calendar-check-o {
                                              color: #00d255 /* 55=Green FF=Blue*/
                                             #module_4_calendar  .fa.fa-trash-o  {
                                              color: #C97F7F; /* Brown */
                                              #module_3_calendar
                                              u are using ID(#) to select
                                              probably changed locations in the config.js
                                              see https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1649371486123
