    MMM-Weather
    17 Posts 10 Posters 6.8k Views 9 Watching
      A Former User
      @banbutcher : sure you can ;)
      the api key is the same as the default weather module
        banbutcher
        great, have it working now, looks great! :)
        thank you
          MC
          i like this modul very much. Thanks for that !!
          one question:
          is there a possibility to change the icons? maybe animated ?
          Thanks !
            A Former User
            actually, it’s not possible, i fetch officials icon of OpenWeather
            It’s restricted by OpenWeather.
            They don’t want to change it.
            Sorry guys, when i do a module I query owner of api what can i do :)
            (After, if you don’t publish it, fork it and do your own)
              CanbiZ
              Hello!
              I use your plugin. But I always get wrong values (I think in Fahrenheit) in the config.js of MM but “metric” is given, but I can’t get it pulled for your plugin…
              Do you have an idea?
                A Former User
                hi, can you give your module config?
                Don’t forget to replace your key by ‘XXXX’
                  CanbiZ @Guest
                  @Bugsounet
                  			/* 2. Modul - Page 1  */
                  			module: "MMM-Weather",
                  			configDeepMerge: true,
                  				debug: false,
                  				updateInterval: "15m", // 15 minutes
                  				updateFadeSpeed: 500,
                  				api: {
                  				  key: "XXXX",
                  				  latitude: "51.XXX",
                                                    longitude: "12.XXX",
                  				display: {
                  				  CurrentConditions: true,
                  				  ExtraCurrentConditions: true,
                  				  Summary: true,
                  				  ForecastTableColumnHeaderIcons: true,
                  				  HourlyForecast: true,
                  				  DailyForecast: true,
                  				  Precipitation: true,
                  				  Wind: true,
                  				  InlineIcons: true,
                  				  Feels: true,
                  				  SunCondition: true,
                  				  Humidity: true,
                  				  UV: true,
                  				  Beaufort: true
                  				personalize: {
                  				  hourlyForecastInterval: 3,
                  				  maxHourliesToShow: 3,
                  				  maxDailiesToShow: 3,
                  				  concise: false,
                  				  colored : true,
                  				  forecastLayout: "table",
                  				  forecastHeaderText: ""
                  				labels: {
                  				  high: "H",
                  				  low: "L",
                  				  timeFormat: "kk[h]"
                    CharlieScott @Cr4z33
                    @Cr4z33 I’ve heard good things about Climacell as well, especially about the IoT technology. Is their free API data option really free? I read somewhere that it is free for up to 30 days. How is your experience so far?
                      sil3ntstorm @CharlieScott
                      I only see the sunset, how can I also display the sunrise (I mean the time)?
                      In addition, on days when the sun is shining, I would also have the sun displayed in yellow and not orange.
                      https://docs.magicmirror.builders/modules/customcss.html
                      here it is written that I have the entry
                      .wi-day-sunny {
                      color: #ffff00;
                      in custom css-file in css/custom.css, I did that, restarted Pi afterwards, but the sun is still displayed orange to me. Did I miss something? Can someone help me? My English is not that good, I hope you understand what I want to say :-)
                        sdetweil @sil3ntstorm
                        @sil3ntstorm I do not know. but I would use the developers window to see what style was applied
                        see
                        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1676128321280
