    Calendar module fetching errors since 2.15
    3 Posts 2 Posters 1.0k Views 2 Watching
    • lavolp3L
      lavolp3 Module Developer
      The calendar module throws out errors and does not start anymore for me due to following error:
      Two public calendars give:
       [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/xxxxxxxxx%40group.calendar.google.com/public/basic.ics
      Cannot read property 'guess' of undefined
      My private calendar has the issue:
      Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/ical/xx.xxx%40gmail.com/private-xxxxxxxxxxxxxxxxb/basic.ics
      moment.tz is not a function
      I THINK the moment.tz error has been there before and i solved that locally but have overwritten the solution in the meantime.
      Anyone else have these problems or any suggestions?
      Anyone
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      lavolp3L 1 Reply Last reply
      • lavolp3L
        lavolp3 Module Developer @lavolp3
        OK some of the errors have apparently been solved by usings sam’s upgrade script. I was a bit to fast with the reporting.
        The latter one not.
        For moment().tz I see one needs to include moment-timezone when using node.js. Which is not being done in calendarutils.js.
        Why am I the only one experiencing this issue?
          sdetweil @lavolp3
          @lavolp3 hm… if u turn on debug ( add “DEBUG” to the logLevel variable array in config.js
          can u identify the calendar entry causing trouble… and be willing to share with me…
          (chat is good)
