    MMM-Fitbit2 PythonShell is not a constructor
    14 Posts 6 Posters 5.6k Views 6 Watching
    • TipponT Offline
      Tippon
      I set up MMM-Fitbit2 recently, and have gone through the setup and authorisation. It seemed to go ok, but now it stops at loading. There’s a PythonShell error in the logs, which seems to be affecting a few other modules.
      I’ve tried to use the fixes for some of the other modules, but I don’t know enough to get them to work.
      I’ve attached the error below. Does anyone know how to fix it please?
      [05.04.2021 01:04.45.169] [ERROR] Whoops! There was an uncaught exception...
      [05.04.2021 01:04.45.169] [ERROR] SyntaxError: Unexpected end of JSON input
          at JSON.parse (<anonymous>)
          at /home/pi/MagicMirror2/modules/MMM-Remote-Control/node_helper.js:1018:33
          at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
      [05.04.2021 01:04.45.169] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [05.04.2021 01:04.45.169] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [05.04.2021 01:07.33.662] [ERROR] Whoops! There was an uncaught exception...
      [05.04.2021 01:07.33.662] [ERROR] TypeError: PythonShell is not a constructor
          at Class.getData (/home/pi/MagicMirror2/modules/MMM-Fitbit2/node_helper.js:54:25)
          at Class.socketNotificationReceived (/home/pi/MagicMirror2/modules/MMM-Fitbit2/node_helper.js:17:9)
          at Socket.<anonymous> (/home/pi/MagicMirror2/js/node_helper.js:112:11)
          at Socket.emit (events.js:198:13)
          at process.nextTick (/home/pi/MagicMirror2/node_modules/socket.io/dist/socket.js:435:32)
          at process._tickCallback (internal/process/next_tick.js:61:11)
      [05.04.2021 01:07.33.662] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [05.04.2021 01:07.33.662] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Please forgive me if I’m slow to reply, I’m currently experiencing memory issues, and sometimes forget that I’ve asked a question >.<
        sdetweil @Tippon
        @tippon as I recall the node_helper.js code has to change the require statement to look like this
        const {PythonShell} = require( 'python-shell');
        just add the braces around the word
        PythonShell
        TipponT 1 Reply Last reply Reply Quote 1
        • TipponT Offline
          Tippon @sdetweil
          @sdetweil Once again, you are a superstar. It’s working, thank you :)
          I thought I’d tried that the other night, but for some reason it didn’t work. I don’t know if I typed it in wrong, or if I messed it up when I tried to do it remotely through my phone. Either way, it’s working now, and I’m a happy bunny :D
          • V Offline
            Vizulize Module Developer
            Hi - I have just committed this fix: https://github.com/m-roberts/MMM-Fitbit2/commit/e958665dcf63900d38f5405961a1a176d5ba2fcf
            TipponT 1 Reply Last reply Reply Quote 0
            • TipponT Offline
              Tippon @Vizulize
              @vizulize That’s great, thank you :)
              • F Offline
                frosty_snow
                @Tippon
                Hello - just wanted to inquire about this problem as I’m encountering the same thing but even with the mentioned change to the require statement it is continuing to occur.
                Did you need to make any other changes or corrections to any of the files?
                Thank you!
                  sdetweil @frosty_snow
                  @frosty_snow can us do , from the module folder
                  grep version   node_modules/python_shell/package.json
                  • F Offline
                    frosty_snow @sdetweil
                    Looks like I’m on 3.0.0
                      dmolony
                      @frosty_snow Not sure if helpful but I’m using python-shell 0.5.0 and removing the brackets around PythonShell fixed the same error for me.
                      • StoffbeuteluweS Offline
                        Stoffbeuteluwe Project Sponsor
                        var NodeHelper = require("node_helper");
                        const PythonShell = require("python-shell");
                        this is working for me
                        • V Offline
                          I have updated the module: https://github.com/m-roberts/MMM-Fitbit2/commit/27706ea0a9ab13b8d12a020f7234adf361d108ae
                            sdetweil @Vizulize
                            @vizulize i think it depends on what version of python-shell you are running…
                            https://github.com/extrabacon/python-shell/issues/154
                            your package.json says
                            "python-shell": "^0.5.0"
                            which means 0.5.0 OR ABOVE (technically ‘at minimum’)
                            if u want ONLY 0.5.0, take the ^ off the front…
                            else sometimes u will get 1.x
                            • V Offline
                              Vizulize Module Developer @sdetweil
                              @sdetweil It is defined as 0.5.0 in the dependencies.
                              To be honest, the Python should be rewritten in JS anyway. Perhaps I will get around to doing that in the near future :thinking_face:
                              Then this issue goes away!
                                sdetweil @Vizulize
                                @vizulize yeh, i don’t know whay there is a python_shell lib… as exec and spawn are so easy…
