    Shutdown Magic Mirror with Home Assistant
    8 Posts 3 Posters 2.4k Views 3 Watching
      jordes
      I am trying to turn off my Magic Mirror from HomeAssistant. But somehow did not work.
      MQTT - does not work
      SHELL COMMAND + MMM-Remote-Control
      Can someone show me a simple solution, or an example me the above listed?
      • cowboysdudeC Offline
        cowboysdude Module Developer @jordes
        @jordes
        https://www.shellhacks.com/raspberry-pi-shutdown-reboot-safely-command/
        I used this and it worked… here’s an example:
        I use a Sonos smart plug through SmartThings to turn off the Pi and turn it back on.
        There are commands from the above link you can use. For instance I used commands to control my Vizio TV through Home Assistant.
        Here is my ‘script’ for my TV.
        - platform: command_line
          switches:
              living_room_tv:
                friendly_name: TV
                command_on: "/usr/bin/curl -k -H \"Content-Type: application/json\" -H \"AUTH: Zzbaa0sttq\" -X PUT -d '{\"KEYLIST\": [{\"CODESET\": 11,\"CODE\": 1,\"ACTION\":\"KEYPRESS\"}]}' https://192.168.1.20:7345/key_command/"
                command_off: "/usr/bin/curl -k -H \"Content-Type: application/json\" -H \"AUTH: Zzbaa0sttq\" -X PUT -d '{\"KEYLIST\": [{\"CODESET\": 11,\"CODE\": 0,\"ACTION\":\"KEYPRESS\"}]}' https://192.168.1.20:7345/key_command/"
                command_state: "/usr/bin/curl -k -H \"Content-Type: application/json\" -H \"AUTH: Zzbaa0sttq\" -X GET https://192.168.1.20:7345/state/device/power_mode"
                value_template: >
                  {% if value_json.ITEMS.0.VALUE == 1 %}
                    true
                  {% else %}
                    false
                  {% endif %}
        You can do the same to control the pi :)
          jordes @cowboysdude
          @cowboysdude thank you for your answer however i do not understand how to translate this for my problem
          hier is my solution that doesnt work for me:
          # Example configuration.yaml entry
          switch:
              switches:
                 magic_mirror_rpi:
                  command_on: "/usr/bin/curl -X GET http://192.168.178.45:8080/remote?action=SHUTDOWN"
                  friendly_name: magic_mirror
            DeanoNoire
            I’m using my old Broadlink wifi smart plug. It has integration in HA, so the setup is “next next finish” style.
            Automation turns it on at 6 AM and turns off at midnight.
              jordes @DeanoNoire
              @deanonoire nice but how do you turn off your raspberry pi safely before you turn off electricity?
                @jordes
                Look here
                https://community.home-assistant.io/t/ssh-and-raspberry-pi/240832/2
                  jordes @cowboysdude
                  hey i solve everything very simple with:
                  https://github.com/daviptrs/hass-unified-remote
                  https://www.crackedconsole.com/2019/04/08/installing-unified-remote-for-raspberry-pi/
                    DeanoNoire @jordes
                    @jordes First part of the automation is ssh call for shutdown.
                    Finding a working script took me a while, but it works like a charm without any excessive MM modules.
                    All you need is to setup passwordless ssh connection between HA and MM.
