    [MMM-RTSP] Module is only showing half of the stream?
    2 Posts 2 Posters 1.4k Views 2 Watching
    • H
      htilly
      Hi!
      First of, thanks for a great module. I finally got it running with VLC.
      However, I have one issue that I just can´t solve.
      The module is only showing half of the picture/stream.
      When viewing the stream thru VLC it looks ok and from the info I can verify that the size is:
      640 x 360. And the stream thru VLC looks just fine.
      No matter how I try to tweak the config, this module has decided that it should be enough to show me the left part of the stream. I,e. 50% of the picture is gone?!
      Config as follow:
      module: "MMM-RTSPStream",
                             position: "middle_center",
                             header: "CAM",
                                                 autoStart: true,
                                                 rotateStreams: false,
                                                 rotateStreamTimeout: 10,
                                                 moduleWidth: 640,
                                                 moduleHeight: 360,
                                                 localPlayer: 'vlc',
                                                 remotePlayer: 'none',
                                                 showSnapWhenPaused: false,
                                                 remoteSnaps: false,
                                                 shutdownDelay: 12,
                                                     stream1: {
        url: 'rtsp://USER:PASSWD@IP:10554/udp/av0_1',
        frameRate: 'undefined',
        //    hdUrl: 'rtsp://USER:PASSWD@IP:10554/udp/av0_1',
        width: 'undefined',
        height: 'undefined',
      I have tried setting the width and height in “stream1” to the same pixel… Same result… have also tried to doubble the width… Same issue…
      What am I missing?!
      Ping: @shbatm
      BR
      Tilly
        Richard_Fish
        Hello everybody,
        i have the same problem. The stream works, but the right quarter of the picture is black. I´ve got problem is only when i rotate the display vertical.
        Is there anybody, who had solved such a problem?
        Best regards
        Richard_Fish
