    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 109.5k Views 25 Watching
      jhbirdchoi @Guest
      @Sean said in MMM-AssistantMk2 (v3):
      Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it.
      Hi
      Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it. -> I need this.
      Can I easily use this function in MMM-AssistantMk2?
      thanks
      ? 1 Reply Last reply
        A Former User @jhbirdchoi
        @jhbirdchoi Hi, AMk2 is actually deprecied and archived.
        You can use GoogleAssistant. See in my repository for more information
        J 1 Reply Last reply
          jhbirdchoi
          @Bugsounet
          Thanks for the answer.
          I already have installed GoogleAssistant.
          The mic and speaker also work well.
          I also installed token.json and credentials.json files.
          But it doesn’t respond to “ok google” and “hey google”.
          (Because of this problem, I tested again with MMM-AssistantMk2.)
          I only installed magicmirror and MMM-GoogleAssistant.
          I used the config.js config below.
          https://github.com/peanutmoose/Smart-mirror-config.
          Which part should I check?
          thanks
            JohnBachini
            @jhbirdchoi
            Hi
            you have config set up to use jarvis as wake word.
            snowboy: {
            		      audioGain: 2.0,
            		      Frontend: true,
            		      Model: "jarvis",
            		      Sensitivity: null
            try saying Jarvis or change model.
              sdetweil @JohnBachini
              @JohnBachini there are limited choices… I don’t know what the list is…
                JohnBachini
                @jhbirdchoi
                model choice:
                Available: “smart_mirror”, “jarvis”, “computer”, “snowboy”, “subex”, “neo_ya”, “hey_extreme”, “view_glass” and “alexa”
                or create your own, it says how to in wiki !
                  jhbirdchoi @Guest
                  @Bugsounet Hi
                  Finally it works.
                  There were various difficulties.
                  Not easy to install magicnmirror + googleassistant.
                  Below is a test video.
                  https://youtu.be/vrC0EgWTRYI
                  Next, I will post the installation guide.
                  thanks
                    jhbirdchoi @JohnBachini
                    @JohnBachini Hi
                    Finally it works.
                    There were various difficulties. Additional modifications were required.
                    thanks
                      berne @Guest
                      @sean i just boot up my old mm. Its about 2yers old. dont know what V i have on assistans but can i make an update? to V3?
                        sdetweil @berne
                        @berne u will have to install a new module, this one had been replaced
                        MMM-GoogleAssistant
                        also it requires 2.14 or above
                        • bugsounetB
                          bugsounet Banned
                          and v3 of GA is under coding… with “ok google”, “hey google” feature :)
                          oupss… I have not to say it there !
                          sorry :/
                          • 7 / 7
