    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      sonicgoose @Guest
      @Bugsounet How very childish.
        A Former User
        And ? If you think that… you have right so ;)
        • I
          Ivanov_d
          @Bugsounet thanks for the information. When should we expect your fork of the project to be ready?
            jhbirdchoi
            Hi
            I installed MMM-AssistantMk2.
            But hotword doesn’t work.
            (mmm-hotword was not installed.)
            So, after clicking the google logo with the mouse, I am using it after changing it into a mic shape.
            Is it possible to always receive mic input by default?
            I want mic to work like the picture attached after booting.
            Thank you!
              jhbirdchoi @Guest
              @Sean said in MMM-AssistantMk2 (v3):
              Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it.
              Hi
              Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it. -> I need this.
              Can I easily use this function in MMM-AssistantMk2?
              thanks
              ? 1 Reply Last reply
                A Former User @jhbirdchoi
                @jhbirdchoi Hi, AMk2 is actually deprecied and archived.
                You can use GoogleAssistant. See in my repository for more information
                J 1 Reply Last reply
                  jhbirdchoi
                  @Bugsounet
                  Thanks for the answer.
                  I already have installed GoogleAssistant.
                  The mic and speaker also work well.
                  I also installed token.json and credentials.json files.
                  But it doesn’t respond to “ok google” and “hey google”.
                  (Because of this problem, I tested again with MMM-AssistantMk2.)
                  I only installed magicmirror and MMM-GoogleAssistant.
                  I used the config.js config below.
                  https://github.com/peanutmoose/Smart-mirror-config.
                  Which part should I check?
                  thanks
                    JohnBachini
                    @jhbirdchoi
                    Hi
                    you have config set up to use jarvis as wake word.
                    snowboy: {
                    		      audioGain: 2.0,
                    		      Frontend: true,
                    		      Model: "jarvis",
                    		      Sensitivity: null
                    try saying Jarvis or change model.
                      sdetweil @JohnBachini
                      @JohnBachini there are limited choices… I don’t know what the list is…
                        JohnBachini
                        @jhbirdchoi
                        model choice:
                        Available: “smart_mirror”, “jarvis”, “computer”, “snowboy”, “subex”, “neo_ya”, “hey_extreme”, “view_glass” and “alexa”
                        or create your own, it says how to in wiki !
                          jhbirdchoi @Guest
                          @Bugsounet Hi
                          Finally it works.
                          There were various difficulties.
                          Not easy to install magicnmirror + googleassistant.
                          Below is a test video.
                          https://youtu.be/vrC0EgWTRYI
                          Next, I will post the installation guide.
                          thanks
                            jhbirdchoi @JohnBachini
                            @JohnBachini Hi
                            Finally it works.
                            There were various difficulties. Additional modifications were required.
                            thanks
                              berne @Guest
                              @sean i just boot up my old mm. Its about 2yers old. dont know what V i have on assistans but can i make an update? to V3?
                                sdetweil @berne
                                @berne u will have to install a new module, this one had been replaced
                                MMM-GoogleAssistant
                                also it requires 2.14 or above
                                • bugsounetB
                                  bugsounet Banned
                                  and v3 of GA is under coding… with “ok google”, “hey google” feature :)
                                  oupss… I have not to say it there !
                                  sorry :/
                                  • 7 / 7
