    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      sbonn13
      Thanks Sam. Sorry I was not aware of. Closed.
      • A
        ahmedalkabir @sdetweil
        @sdetweil why the repository of MMM-AssistantMk2 deleted, is there something happened because I can’t find it anywhere>
        • A
          ahmedalkabir @Guest
          @Sean https://github.com/eouia/MMM-AssistantMk2
          it doesn’t work anymore, what’s the problem ?
            JohnBachini @ahmedalkabir
            @ahmedalkabir It’s been replaced with MMM-GoogleAssistant
            • A
              ahmedalkabir @JohnBachini
              @JohnBachini oh, so MMM-GoogleAssitant is better than the older one?
                JohnBachini
                @ahmedalkabir
                Yes it seems to be , Bugsounet took over MMM-Assistantmk2 and then did his magic and turned it into GoogleAssistant 👍
                • I
                  Ivanov_d
                  Well, now as @Bugsounet closed his modules for MM and @Sean deleted the AssistantMk2 repo the MM users are left without Voice control. Great!
                    A Former User
                    no one ask to you use my modules… try to code your own ;)
                    BUT If I close something … It’s for Made better !!!
                    SO wait and see (in a couple of day)
                    OR don’t use it ;)
                    IN ALL CASE: AMK2 have been totaly recoded (only sound)… and jsut after… deprecied.
                    If you like only deprecied module or not maintened modules let make your choise in 3rd party module ! 90% of modules have not been maintened since +/- 2 years ;)
                    @Ivanov_d : for you information :
                    It’s my module…
                      sonicgoose @Guest
                      @Bugsounet How very childish.
                        A Former User
                        And ? If you think that… you have right so ;)
                        • I
                          Ivanov_d
                          @Bugsounet thanks for the information. When should we expect your fork of the project to be ready?
                            jhbirdchoi
                            Hi
                            I installed MMM-AssistantMk2.
                            But hotword doesn’t work.
                            (mmm-hotword was not installed.)
                            So, after clicking the google logo with the mouse, I am using it after changing it into a mic shape.
                            Is it possible to always receive mic input by default?
                            I want mic to work like the picture attached after booting.
                            Thank you!
                              jhbirdchoi @Guest
                              @Sean said in MMM-AssistantMk2 (v3):
                              Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it.
                              Hi
                              Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it. -> I need this.
                              Can I easily use this function in MMM-AssistantMk2?
                              thanks
                                A Former User @jhbirdchoi
                                @jhbirdchoi Hi, AMk2 is actually deprecied and archived.
                                You can use GoogleAssistant. See in my repository for more information
                                  jhbirdchoi
                                  @Bugsounet
                                  Thanks for the answer.
                                  I already have installed GoogleAssistant.
                                  The mic and speaker also work well.
                                  I also installed token.json and credentials.json files.
                                  But it doesn’t respond to “ok google” and “hey google”.
                                  (Because of this problem, I tested again with MMM-AssistantMk2.)
                                  I only installed magicmirror and MMM-GoogleAssistant.
                                  I used the config.js config below.
                                  https://github.com/peanutmoose/Smart-mirror-config.
                                  Which part should I check?
                                  thanks
                                    JohnBachini
                                    @jhbirdchoi
                                    Hi
                                    you have config set up to use jarvis as wake word.
                                    snowboy: {
                                    		      audioGain: 2.0,
                                    		      Frontend: true,
                                    		      Model: "jarvis",
                                    		      Sensitivity: null
                                    try saying Jarvis or change model.
                                      sdetweil @JohnBachini
                                      @JohnBachini there are limited choices… I don’t know what the list is…
                                        JohnBachini
                                        @jhbirdchoi
                                        model choice:
                                        Available: “smart_mirror”, “jarvis”, “computer”, “snowboy”, “subex”, “neo_ya”, “hey_extreme”, “view_glass” and “alexa”
                                        or create your own, it says how to in wiki !
                                          jhbirdchoi @Guest
                                          @Bugsounet Hi
                                          Finally it works.
                                          There were various difficulties.
                                          Not easy to install magicnmirror + googleassistant.
                                          Below is a test video.
                                          https://youtu.be/vrC0EgWTRYI
                                          Next, I will post the installation guide.
                                          thanks
                                            jhbirdchoi @JohnBachini
                                            @JohnBachini Hi
                                            Finally it works.
                                            There were various difficulties. Additional modifications were required.
                                            thanks
                                            • 7 / 7
