    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 104.0k Views 25 Watching
    • Cr4z33C Offline
      Cr4z33 @Guest
      @Bugsounet I’ve turner on my MagicMirror after a stop of 6 months.
      At first I ran sudo apt-get update && sudo apt-get upgrade, then I updated both MM and its modules.
      Now MM it ends up with a black screen.
      So I ran npm run update in MMM-AssistantMk2 folder and answered Yes to all the answers.
      I still keep getting the black screen at the end of MM loading.
      What shall I do next now? :smiling_face_with_open_mouth_cold_sweat:
      Here’s what happening:
      > magicmirror@2.11.0 start /home/pi/MagicMirror
      [2020-05-22 08:14:49.750] [LOG]    Starting MagicMirror: v2.11.0
      [2020-05-22 08:14:49.763] [LOG]    Loading config ...
      [2020-05-22 08:14:49.776] [LOG]    Loading module helpers ...
      [2020-05-22 08:14:49.792] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:49.794] [LOG]    Module helper loaded: MMM-WatchDog
      [2020-05-22 08:14:49.926] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:49.927] [LOG]    Module helper loaded: MMM-Remote-Control
      [2020-05-22 08:14:51.650] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:51.651] [LOG]    Module helper loaded: MMM-RTSPStream
      [2020-05-22 08:14:51.652] [LOG]    No helper found for module: alert.
      [2020-05-22 08:14:51.717] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:51.718] [LOG]    Module helper loaded: updatenotification
      [2020-05-22 08:14:51.780] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:51.781] [LOG]    Module helper loaded: newsfeed
      [2020-05-22 08:14:53.984] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:53.985] [LOG]    Module helper loaded: MMM-AssistantMk2
      [2020-05-22 08:14:53.986] [LOG]    No helper found for module: clock.
      [2020-05-22 08:14:54.001] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:54.002] [LOG]    Module helper loaded: MMM-Spotify
      [2020-05-22 08:14:54.583] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:54.584] [LOG]    Module helper loaded: MMM-DarkSkyForecast
      [2020-05-22 08:14:55.464] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.465] [LOG]    Module helper loaded: MMM-PushBulletNotifications
      [2020-05-22 08:14:55.472] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
      Require stack:
      - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
      [2020-05-22 08:14:55.473] [LOG]    Loading module helpers ...
      [2020-05-22 08:14:55.484] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.486] [LOG]    Module helper loaded: MMM-WatchDog
      [2020-05-22 08:14:55.486] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.487] [LOG]    Module helper loaded: MMM-Remote-Control
      [2020-05-22 08:14:55.488] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.489] [LOG]    Module helper loaded: MMM-RTSPStream
      [2020-05-22 08:14:55.490] [LOG]    No helper found for module: alert.
      [2020-05-22 08:14:55.491] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.492] [LOG]    Module helper loaded: updatenotification
      [2020-05-22 08:14:55.493] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.494] [LOG]    Module helper loaded: newsfeed
      [2020-05-22 08:14:55.497] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.500] [LOG]    Module helper loaded: MMM-AssistantMk2
      [2020-05-22 08:14:55.502] [LOG]    No helper found for module: clock.
      [2020-05-22 08:14:55.504] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.505] [LOG]    Module helper loaded: MMM-Spotify
      [2020-05-22 08:14:55.507] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.509] [LOG]    Module helper loaded: MMM-DarkSkyForecast
      [2020-05-22 08:14:55.510] [LOG]    Initializing new module helper ...
      [2020-05-22 08:14:55.512] [LOG]    Module helper loaded: MMM-PushBulletNotifications
      [2020-05-22 08:14:55.517] [ERROR]  App threw an error during load
      [2020-05-22 08:14:55.519] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
      Require stack:
          at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Function.Module._load (internal/modules/cjs/loader.js:531:27)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
          at Module._compile (internal/modules/cjs/loader.js:786:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
      [2020-05-22 08:14:55.522] [LOG]    Whoops! There was an uncaught exception...
      [2020-05-22 08:14:55.523] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
      Require stack:
          at Module.load (internal/modules/cjs/loader.js:645:32) {
        code: 'MODULE_NOT_FOUND',
        requireStack: [
          '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
          '/home/pi/MagicMirror/js/app.js',
          '/home/pi/MagicMirror/js/electron.js',
          '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
          undefined
      [2020-05-22 08:14:55.542] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2020-05-22 08:14:55.546] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
      [2020-05-22 08:14:55.768] [LOG]    Launching application.
        A Former User
        @Cr4z33: just because this errror is not related to MMM-AssistantMk2 module ;)
        • Cr4z33C Offline
          Cr4z33 @Guest
          @Bugsounet oops sorry then! 😅
            acowx
            I am trying to work out how I can use MMM-AssistantMk2 to voice control the MMM-CalendarExt2 module.
            My basic needs are to use a voice command to notify MMM-CalendarExt2 to swap to another view.
            eg, I say “[wakeword] scene monthly” and the Calendar Module will swap to a scene which shows my Monthly calendar view.
            Or I say “[wakeword] scene weekly” and the Calendar Module will swap to a scene which shows my Weekly calendar view.
            I have considered TelegramBot but I don’t think that is triggered by a voice command ?
            Any ideas guys ?
              sbonn13
              AssistantMk2 works awesome also together with 2Display. I am in love with that :)
              User request: I would like to open news as video like https://www.tagesschau.de/100sekunden/ or via youtube play list https://www.youtube.com/user/tagesschau (German public broadcasting service)
              Problem: Searching Youtube + tagesschau is replied by Google assistant that the news function would not be available for this device yet.
              Is there a workaround I could use/implement?
              E.g. Specific search terms opens automatically a specified youtube link or a specific website?
                sdetweil @acowx
                @acowx the MMM-Assistant* modules have been terminated, please move to the new MMM-GoogleAssistant module
                  sbonn13
                  Thanks Sam. Sorry I was not aware of. Closed.
                    ahmedalkabir @sdetweil
                    @sdetweil why the repository of MMM-AssistantMk2 deleted, is there something happened because I can’t find it anywhere>
                      ahmedalkabir @Guest
                      @Sean https://github.com/eouia/MMM-AssistantMk2
                      it doesn’t work anymore, what’s the problem ?
                        JohnBachini @ahmedalkabir
                        @ahmedalkabir It’s been replaced with MMM-GoogleAssistant
                          ahmedalkabir @JohnBachini
                          @JohnBachini oh, so MMM-GoogleAssitant is better than the older one?
                            JohnBachini
                            @ahmedalkabir
                            Yes it seems to be , Bugsounet took over MMM-Assistantmk2 and then did his magic and turned it into GoogleAssistant 👍
                            • I Offline
                              Ivanov_d
                              Well, now as @Bugsounet closed his modules for MM and @Sean deleted the AssistantMk2 repo the MM users are left without Voice control. Great!
                                A Former User
                                no one ask to you use my modules… try to code your own ;)
                                BUT If I close something … It’s for Made better !!!
                                SO wait and see (in a couple of day)
                                OR don’t use it ;)
                                IN ALL CASE: AMK2 have been totaly recoded (only sound)… and jsut after… deprecied.
                                If you like only deprecied module or not maintened modules let make your choise in 3rd party module ! 90% of modules have not been maintened since +/- 2 years ;)
                                @Ivanov_d : for you information :
                                It’s my module…
                                  sonicgoose @Guest
                                  @Bugsounet How very childish.
                                    A Former User
                                    And ? If you think that… you have right so ;)
                                    • I Offline
                                      Ivanov_d
                                      @Bugsounet thanks for the information. When should we expect your fork of the project to be ready?
                                        jhbirdchoi
                                        Hi
                                        I installed MMM-AssistantMk2.
                                        But hotword doesn’t work.
                                        (mmm-hotword was not installed.)
                                        So, after clicking the google logo with the mouse, I am using it after changing it into a mic shape.
                                        Is it possible to always receive mic input by default?
                                        I want mic to work like the picture attached after booting.
                                        Thank you!
                                          jhbirdchoi @Guest
                                          @Sean said in MMM-AssistantMk2 (v3):
                                          Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it.
                                          Hi
                                          Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it. -> I need this.
                                          Can I easily use this function in MMM-AssistantMk2?
                                          thanks
                                            A Former User @jhbirdchoi
                                            @jhbirdchoi Hi, AMk2 is actually deprecied and archived.
                                            You can use GoogleAssistant. See in my repository for more information
                                            • 6 / 7
