    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      jimmydew @sdetweil
      oke thank you but I dont now how I load a diffrent Os
        sdetweil @jimmydew
        @jimmydew flash the SD card with a different is version
          jimmydew @sdetweil
          @sdetweil i have done now ive installed MM again and it gives me this on startup,
          [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
          [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
          Require stack:
          - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
          - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
          - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
              at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              at Function.Module._load (internal/modules/cjs/loader.js:531:27)
              at Module.require (internal/modules/cjs/loader.js:685:19)
              at require (internal/modules/cjs/helpers.js:16:16)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
              at Module._compile (internal/modules/cjs/loader.js:786:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
              at Module.load (internal/modules/cjs/loader.js:645:32) {
            code: 'MODULE_NOT_FOUND',
            requireStack: [
              '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
              '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
              '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
              '/home/pi/MagicMirror/js/app.js',
              '/home/pi/MagicMirror/js/electron.js',
              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
              undefined
          [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
          [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
          [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
          [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
          [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
          [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
          [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
          pi@raspberrypi:~/MagicMirror $
          it still not detects my voice, only when i click on the assistant
            sdetweil @jimmydew
            @jimmydew @Bugsounet will be by to help…
              A Former User
              I ordered an RPI4, I await the end of delivery for tomorrow.
              So I’m going to do a new installation on it.
              I come back to you once done
                sdetweil @Guest
                @Bugsounet use my script…
                  A Former User
                  @sdetweil : of course ! it’s planned ! ;)
                    A Former User
                    yeah, I receive my RPI, SD card but missing : RPI case, fan and power supply
                    It’s the second order and it’s will be deliver tomorrow ;)
                    Note: ahahah, I have no RPI for developping !!!
                    • L
                      Lasmazze
                      Hi everyone!
                      The module works very well. Good work!
                      I just have a request:
                      When I say “JARVIS” I would like the sound to be cut or lowered to the minimum if not the assistant records what it is broadcasting like the radio or a youtube video. When I finish talking to the assistant, I would like the sound to come back as it was before.
                      Thank you in advance for your help!
                        A Former User
                        @jimmydew : i confirm there is a bug in my installer. (missing 2 library, I say “bravo !” in French)
                        I correct it ;)
                        in AMk2 directory retry with:
                        npm run update
                        and do all process
                        It should work now
                        • T
                          triguyrn
                          What microphone/speaker are you all using?
                          Looking to add voice control to my mirror as well!
                            sdetweil @triguyrn
                            @triguyrn I use a Logitech C270 webcam, and also just added a PlayStation Eye webcam to one of them
                            • Cr4z33C
                              Cr4z33 @Guest
                              @Bugsounet I’ve turner on my MagicMirror after a stop of 6 months.
                              At first I ran sudo apt-get update && sudo apt-get upgrade, then I updated both MM and its modules.
                              Now MM it ends up with a black screen.
                              So I ran npm run update in MMM-AssistantMk2 folder and answered Yes to all the answers.
                              I still keep getting the black screen at the end of MM loading.
                              What shall I do next now? :smiling_face_with_open_mouth_cold_sweat:
                              Here’s what happening:
                              > magicmirror@2.11.0 start /home/pi/MagicMirror
                              [2020-05-22 08:14:49.750] [LOG]    Starting MagicMirror: v2.11.0
                              [2020-05-22 08:14:49.763] [LOG]    Loading config ...
                              [2020-05-22 08:14:49.776] [LOG]    Loading module helpers ...
                              [2020-05-22 08:14:49.792] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:49.794] [LOG]    Module helper loaded: MMM-WatchDog
                              [2020-05-22 08:14:49.926] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:49.927] [LOG]    Module helper loaded: MMM-Remote-Control
                              [2020-05-22 08:14:51.650] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:51.651] [LOG]    Module helper loaded: MMM-RTSPStream
                              [2020-05-22 08:14:51.652] [LOG]    No helper found for module: alert.
                              [2020-05-22 08:14:51.717] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:51.718] [LOG]    Module helper loaded: updatenotification
                              [2020-05-22 08:14:51.780] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:51.781] [LOG]    Module helper loaded: newsfeed
                              [2020-05-22 08:14:53.984] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:53.985] [LOG]    Module helper loaded: MMM-AssistantMk2
                              [2020-05-22 08:14:53.986] [LOG]    No helper found for module: clock.
                              [2020-05-22 08:14:54.001] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:54.002] [LOG]    Module helper loaded: MMM-Spotify
                              [2020-05-22 08:14:54.583] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:54.584] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                              [2020-05-22 08:14:55.464] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.465] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                              [2020-05-22 08:14:55.472] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
                              Require stack:
                              - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                              [2020-05-22 08:14:55.473] [LOG]    Loading module helpers ...
                              [2020-05-22 08:14:55.484] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.486] [LOG]    Module helper loaded: MMM-WatchDog
                              [2020-05-22 08:14:55.486] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.487] [LOG]    Module helper loaded: MMM-Remote-Control
                              [2020-05-22 08:14:55.488] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.489] [LOG]    Module helper loaded: MMM-RTSPStream
                              [2020-05-22 08:14:55.490] [LOG]    No helper found for module: alert.
                              [2020-05-22 08:14:55.491] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.492] [LOG]    Module helper loaded: updatenotification
                              [2020-05-22 08:14:55.493] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.494] [LOG]    Module helper loaded: newsfeed
                              [2020-05-22 08:14:55.497] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.500] [LOG]    Module helper loaded: MMM-AssistantMk2
                              [2020-05-22 08:14:55.502] [LOG]    No helper found for module: clock.
                              [2020-05-22 08:14:55.504] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.505] [LOG]    Module helper loaded: MMM-Spotify
                              [2020-05-22 08:14:55.507] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.509] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                              [2020-05-22 08:14:55.510] [LOG]    Initializing new module helper ...
                              [2020-05-22 08:14:55.512] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                              [2020-05-22 08:14:55.517] [ERROR]  App threw an error during load
                              [2020-05-22 08:14:55.519] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                              Require stack:
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
                              [2020-05-22 08:14:55.522] [LOG]    Whoops! There was an uncaught exception...
                              [2020-05-22 08:14:55.523] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                              Require stack:
                                requireStack: [
                                  '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                                  undefined
                              [2020-05-22 08:14:55.542] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [2020-05-22 08:14:55.546] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                              [2020-05-22 08:14:55.768] [LOG]    Launching application.
                                A Former User
                                @Cr4z33: just because this errror is not related to MMM-AssistantMk2 module ;)
                                • Cr4z33C
                                  Cr4z33 @Guest
                                  @Bugsounet oops sorry then! 😅
                                  • A
                                    acowx
                                    I am trying to work out how I can use MMM-AssistantMk2 to voice control the MMM-CalendarExt2 module.
                                    My basic needs are to use a voice command to notify MMM-CalendarExt2 to swap to another view.
                                    eg, I say “[wakeword] scene monthly” and the Calendar Module will swap to a scene which shows my Monthly calendar view.
                                    Or I say “[wakeword] scene weekly” and the Calendar Module will swap to a scene which shows my Weekly calendar view.
                                    I have considered TelegramBot but I don’t think that is triggered by a voice command ?
                                    Any ideas guys ?
                                      sbonn13
                                      AssistantMk2 works awesome also together with 2Display. I am in love with that :)
                                      User request: I would like to open news as video like https://www.tagesschau.de/100sekunden/ or via youtube play list https://www.youtube.com/user/tagesschau (German public broadcasting service)
                                      Problem: Searching Youtube + tagesschau is replied by Google assistant that the news function would not be available for this device yet.
                                      Is there a workaround I could use/implement?
                                      E.g. Specific search terms opens automatically a specified youtube link or a specific website?
                                        sdetweil @acowx
                                        @acowx the MMM-Assistant* modules have been terminated, please move to the new MMM-GoogleAssistant module
                                          sbonn13
                                          Thanks Sam. Sorry I was not aware of. Closed.
                                          • A
                                            ahmedalkabir @sdetweil
                                            @sdetweil why the repository of MMM-AssistantMk2 deleted, is there something happened because I can’t find it anywhere>
                                            • 6 / 7
