    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      sdetweil @Guest
      @Bugsounet use my script…
        A Former User
        @sdetweil : of course ! it’s planned ! ;)
          A Former User
          yeah, I receive my RPI, SD card but missing : RPI case, fan and power supply
          It’s the second order and it’s will be deliver tomorrow ;)
          Note: ahahah, I have no RPI for developping !!!
          • L
            Lasmazze
            Hi everyone!
            The module works very well. Good work!
            I just have a request:
            When I say “JARVIS” I would like the sound to be cut or lowered to the minimum if not the assistant records what it is broadcasting like the radio or a youtube video. When I finish talking to the assistant, I would like the sound to come back as it was before.
            Thank you in advance for your help!
              A Former User
              @jimmydew : i confirm there is a bug in my installer. (missing 2 library, I say “bravo !” in French)
              I correct it ;)
              in AMk2 directory retry with:
              npm run update
              and do all process
              It should work now
              • T
                triguyrn
                What microphone/speaker are you all using?
                Looking to add voice control to my mirror as well!
                  sdetweil @triguyrn
                  @triguyrn I use a Logitech C270 webcam, and also just added a PlayStation Eye webcam to one of them
                  • Cr4z33C
                    Cr4z33 @Guest
                    @Bugsounet I’ve turner on my MagicMirror after a stop of 6 months.
                    At first I ran sudo apt-get update && sudo apt-get upgrade, then I updated both MM and its modules.
                    Now MM it ends up with a black screen.
                    So I ran npm run update in MMM-AssistantMk2 folder and answered Yes to all the answers.
                    I still keep getting the black screen at the end of MM loading.
                    What shall I do next now? :smiling_face_with_open_mouth_cold_sweat:
                    Here’s what happening:
                    > magicmirror@2.11.0 start /home/pi/MagicMirror
                    [2020-05-22 08:14:49.750] [LOG]    Starting MagicMirror: v2.11.0
                    [2020-05-22 08:14:49.763] [LOG]    Loading config ...
                    [2020-05-22 08:14:49.776] [LOG]    Loading module helpers ...
                    [2020-05-22 08:14:49.792] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:49.794] [LOG]    Module helper loaded: MMM-WatchDog
                    [2020-05-22 08:14:49.926] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:49.927] [LOG]    Module helper loaded: MMM-Remote-Control
                    [2020-05-22 08:14:51.650] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:51.651] [LOG]    Module helper loaded: MMM-RTSPStream
                    [2020-05-22 08:14:51.652] [LOG]    No helper found for module: alert.
                    [2020-05-22 08:14:51.717] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:51.718] [LOG]    Module helper loaded: updatenotification
                    [2020-05-22 08:14:51.780] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:51.781] [LOG]    Module helper loaded: newsfeed
                    [2020-05-22 08:14:53.984] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:53.985] [LOG]    Module helper loaded: MMM-AssistantMk2
                    [2020-05-22 08:14:53.986] [LOG]    No helper found for module: clock.
                    [2020-05-22 08:14:54.001] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:54.002] [LOG]    Module helper loaded: MMM-Spotify
                    [2020-05-22 08:14:54.583] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:54.584] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                    [2020-05-22 08:14:55.464] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.465] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                    [2020-05-22 08:14:55.472] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
                    Require stack:
                    - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                    [2020-05-22 08:14:55.473] [LOG]    Loading module helpers ...
                    [2020-05-22 08:14:55.484] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.486] [LOG]    Module helper loaded: MMM-WatchDog
                    [2020-05-22 08:14:55.486] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.487] [LOG]    Module helper loaded: MMM-Remote-Control
                    [2020-05-22 08:14:55.488] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.489] [LOG]    Module helper loaded: MMM-RTSPStream
                    [2020-05-22 08:14:55.490] [LOG]    No helper found for module: alert.
                    [2020-05-22 08:14:55.491] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.492] [LOG]    Module helper loaded: updatenotification
                    [2020-05-22 08:14:55.493] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.494] [LOG]    Module helper loaded: newsfeed
                    [2020-05-22 08:14:55.497] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.500] [LOG]    Module helper loaded: MMM-AssistantMk2
                    [2020-05-22 08:14:55.502] [LOG]    No helper found for module: clock.
                    [2020-05-22 08:14:55.504] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.505] [LOG]    Module helper loaded: MMM-Spotify
                    [2020-05-22 08:14:55.507] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.509] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                    [2020-05-22 08:14:55.510] [LOG]    Initializing new module helper ...
                    [2020-05-22 08:14:55.512] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                    [2020-05-22 08:14:55.517] [ERROR]  App threw an error during load
                    [2020-05-22 08:14:55.519] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                    Require stack:
                        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                        at Module.require (internal/modules/cjs/loader.js:685:19)
                        at require (internal/modules/cjs/helpers.js:16:16)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                        at Module.load (internal/modules/cjs/loader.js:645:32)
                    [2020-05-22 08:14:55.522] [LOG]    Whoops! There was an uncaught exception...
                    [2020-05-22 08:14:55.523] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                    Require stack:
                        at Module.load (internal/modules/cjs/loader.js:645:32) {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: [
                        '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                        '/home/pi/MagicMirror/js/app.js',
                        '/home/pi/MagicMirror/js/electron.js',
                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                        undefined
                    [2020-05-22 08:14:55.542] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-05-22 08:14:55.546] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                    [2020-05-22 08:14:55.768] [LOG]    Launching application.
                      A Former User
                      @Cr4z33: just because this errror is not related to MMM-AssistantMk2 module ;)
                      • Cr4z33C
                        Cr4z33 @Guest
                        @Bugsounet oops sorry then! 😅
                        • A
                          acowx
                          I am trying to work out how I can use MMM-AssistantMk2 to voice control the MMM-CalendarExt2 module.
                          My basic needs are to use a voice command to notify MMM-CalendarExt2 to swap to another view.
                          eg, I say “[wakeword] scene monthly” and the Calendar Module will swap to a scene which shows my Monthly calendar view.
                          Or I say “[wakeword] scene weekly” and the Calendar Module will swap to a scene which shows my Weekly calendar view.
                          I have considered TelegramBot but I don’t think that is triggered by a voice command ?
                          Any ideas guys ?
                            sbonn13
                            AssistantMk2 works awesome also together with 2Display. I am in love with that :)
                            User request: I would like to open news as video like https://www.tagesschau.de/100sekunden/ or via youtube play list https://www.youtube.com/user/tagesschau (German public broadcasting service)
                            Problem: Searching Youtube + tagesschau is replied by Google assistant that the news function would not be available for this device yet.
                            Is there a workaround I could use/implement?
                            E.g. Specific search terms opens automatically a specified youtube link or a specific website?
                              sdetweil @acowx
                              @acowx the MMM-Assistant* modules have been terminated, please move to the new MMM-GoogleAssistant module
                                sbonn13
                                Thanks Sam. Sorry I was not aware of. Closed.
                                • A
                                  ahmedalkabir @sdetweil
                                  @sdetweil why the repository of MMM-AssistantMk2 deleted, is there something happened because I can’t find it anywhere>
                                  • A
                                    ahmedalkabir @Guest
                                    @Sean https://github.com/eouia/MMM-AssistantMk2
                                    it doesn’t work anymore, what’s the problem ?
                                      JohnBachini @ahmedalkabir
                                      @ahmedalkabir It’s been replaced with MMM-GoogleAssistant
                                      • A
                                        ahmedalkabir @JohnBachini
                                        @JohnBachini oh, so MMM-GoogleAssitant is better than the older one?
                                          JohnBachini
                                          @ahmedalkabir
                                          Yes it seems to be , Bugsounet took over MMM-Assistantmk2 and then did his magic and turned it into GoogleAssistant 👍
                                          • I
                                            Ivanov_d
                                            Well, now as @Bugsounet closed his modules for MM and @Sean deleted the AssistantMk2 repo the MM users are left without Voice control. Great!
                                            • 6 / 7
