    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 104.0k Views 25 Watching
      jimmydew @Guest
      @Bugsounet
      pi@raspberrypi:~/MagicMirror $ gcc --version
      gcc (Raspbian 7.3.0-19) 7.3.0
      Copyright (C) 2017 Free Software Foundation, Inc.
      This is free software; see the source for copying conditions.  There is NO
      warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
      • E Offline
        electros Project Sponsor @Guest
        @Bugsounet Hi, again. I managed to make my radio station list and everything works fine, just I don’t know how to stop the radio. Can you please explain me how to add a stop radio command?
        Thank you
          A Former User
           @jimmydew can you do this command for more informations, please ?
          cat /etc/*release
          @electros :
          Good job !
          For stop radio (and other A2D module), i create a feature in AMk2 (A2D Server part)
          You can define your prefered stop command
          by default it’s stop but … it’s depend of your language !
          for exemple in french language, when i say stop, google transcript stoppe
          you have an exemple in AMk2 structure sample
          E J 2 Replies Last reply Reply Quote 0
          • E Offline
            @Bugsounet OK I understand that but if I configure that “stop” in english for example just I must say " jarvis stop" or “jarvis stop radio” ?
              A Former User
              It’s depend what’s google return in transcription
              for verify what it return
              You have 2 solutions:
              1. turn Fullscreen ui , activate jarvis and say stop.
                AMk2 will display in real time what it understand, so if it display stop, it’s ok
                en french it display stoppe then i have to modify A2DStopCommand: "stoppe",
              2. in console and debug mode actived
                you will see the transcription of google
                transcription: { transcription: 'stoppe', done: true },
              notes:
              • if you say stop and method 1 or 2 result is stop too
                no A2DStopCommand configuration require
              • stop command defined in A2DStopCommand stops all process of A2D : weblinks, cast, youtube, radio, photos (and MMM-FreeboxTV for french user)
              Use:
              just say jarvis (for activating) … stop (or your prefered A2DStopCommand)
              • E Offline
                @Bugsounet OK, thank you
                  jimmydew @Guest
                  @Bugsounet
                  sure:
                  pi@raspberrypi:~/MagicMirror $ cat /etc/*release
                  PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                  NAME="Raspbian GNU/Linux"
                  VERSION_ID="10"
                  VERSION="10 (buster)"
                  VERSION_CODENAME=buster
                  ID=raspbian
                  ID_LIKE=debian
                  HOME_URL="http://www.raspbian.org/"
                  SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                  BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                    A Former User
                    gyp ERR! System Linux 5.4.35-v7l+
                    in the raspbian web site i see this:
                    Raspbian Buster with desktop
                    Image with desktop based on Debian Buster
                    Version:February 2020
                    Release date:2020-02-13
                    Kernel version:4.19
                    i don’t know why you are the 5.4.x kernel version and it seams the problem
                    I don’t try to compile it with it so … sorry, i can’t help
                    retry with 4.19.x kernel version
                      jimmydew @Guest
                      @Bugsounet
                      hmm okay, is there a way to change my kernel version??
                        sdetweil @jimmydew
                        @jimmydew load a different version of the OS
                          jimmydew @sdetweil
                          oke thank you but I dont now how I load a diffrent Os
                            sdetweil @jimmydew
                            @jimmydew flash the SD card with a different is version
                              jimmydew @sdetweil
                              @sdetweil i have done now ive installed MM again and it gives me this on startup,
                              [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
                              [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                              Require stack:
                              - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
                              - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
                              - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                                  at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                  at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                  at Module.require (internal/modules/cjs/loader.js:685:19)
                                  at require (internal/modules/cjs/helpers.js:16:16)
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                                  at Module._compile (internal/modules/cjs/loader.js:786:30)
                                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                  at Module.load (internal/modules/cjs/loader.js:645:32) {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: [
                                  '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
                                  '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
                                  '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
                                  '/home/pi/MagicMirror/js/app.js',
                                  '/home/pi/MagicMirror/js/electron.js',
                                  '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                  undefined
                              [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                              [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                              [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
                              [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
                              [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
                              [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
                              [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
                              [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
                              [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
                              it still not detects my voice, only when i click on the assistant
                                sdetweil @jimmydew
                                @jimmydew @Bugsounet will be by to help…
                                  A Former User
                                  I ordered an RPI4, I await the end of delivery for tomorrow.
                                  So I’m going to do a new installation on it.
                                  I come back to you once done
                                    sdetweil @Guest
                                    @Bugsounet use my script…
                                      A Former User
                                      @sdetweil : of course ! it’s planned ! ;)
                                        A Former User
                                        yeah, I receive my RPI, SD card but missing : RPI case, fan and power supply
                                        It’s the second order and it’s will be deliver tomorrow ;)
                                        Note: ahahah, I have no RPI for developping !!!
                                        • L Offline
                                          Lasmazze
                                          Hi everyone!
                                          The module works very well. Good work!
                                          I just have a request:
                                          When I say “JARVIS” I would like the sound to be cut or lowered to the minimum if not the assistant records what it is broadcasting like the radio or a youtube video. When I finish talking to the assistant, I would like the sound to come back as it was before.
                                          Thank you in advance for your help!
                                            A Former User
                                            @jimmydew : i confirm there is a bug in my installer. (missing 2 library, I say “bravo !” in French)
                                            I correct it ;)
                                            in AMk2 directory retry with:
                                            npm run update
                                            and do all process
                                            It should work now
                                            • 5 / 7
