    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 104.0k Views 25 Watching
      sdetweil @jimmydew
      @jimmydew in the future please use the markdown for code
      select the text and hit the </> icon above the editor
        jimmydew @Guest
        @Bugsounet
        i got quite a few errors on the rebuild:
        ✖ Rebuild Failed
        An unhandled error occurred inside electron-rebuild
        make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
          CXX(target) Release/obj.target/snowboy/lib/snowboy.o
        In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
                         from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
                         from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                         from ../../../nan/nan.h:56,
                         from ../lib/snowboy.cc:1:
        /home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
           declarator __attribute__((deprecated(message)))
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
           V8_DEPRECATE_SOON("Use *WithData version.",
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
        In file included from ../lib/snowboy.cc:1:
        ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        ../lib/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
        ../lib/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
           } catch (std::runtime_error e) {
        In file included from ../../../nan/nan.h:56,
        ../lib/snowboy.cc: At global scope:
        /home/pi/.electron-gyp/6.1.7/include/node/node.h:572:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
               (node::addon_register_func) (regfunc),                          \
        /home/pi/.electron-gyp/6.1.7/include/node/node.h:606:3: note: in expansion of macro ‘NODE_MODULE_X’
           NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
        ../lib/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
         NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
        In file included from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
        /home/pi/.electron-gyp/6.1.7/include/node/node_object_wrap.h:84:78:   required from here
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                        reinterpret_cast<Callback>(callback), type);
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
        ../../../nan/nan_object_wrap.h:65:61:   required from here
        /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
          SOLINK_MODULE(target) Release/obj.target/snowboy.node
        /usr/bin/ld: cannot find -lcblas
        collect2: error: ld returned 1 exit status
        make: *** [snowboy.target.mk:143: Release/obj.target/snowboy.node] Error 1
        make: Leaving directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
        gyp ERR! System Linux 5.4.35-v7l+
        gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm" "--remote_path=./snowboy/v1.4.7/Release/" "--package_name=snowboy-v1.4.7-electron-v6.1-linux-arm.tar.gz" "--host=https://github.com/bugsounet/snowboy"
        gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
        gyp ERR! node -v v10.20.1
        gyp ERR! node-gyp -v v6.1.0
        gyp ERR! not ok
        Failed with exit code: 1
        Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
        gyp ERR! not ok
            at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:267:84)
            at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:205:16)
            at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:156:26)
            at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
            at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
            at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
            at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
            at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:242:65)
            at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:143:22)
        > @bugsounet/snowboy@1.4.7 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
        > tsc -p tsconfig.json
        + @bugsounet/snowboy@1.4.7
        added 20 packages from 25 contributors and audited 315 packages in 38.481s
        3 packages are looking for funding
          run `npm fund` for details
        found 6 low severity vulnerabilities
          run `npm audit fix` to fix them, or `npm audit` for details
        @bugsounet/snowboy library installed
          A Former User
          @jimmydew said in MMM-AssistantMk2 (v3):
          Linux 5.4.35-v7l+
          ah …
          and what version of gcc do you use ?
          try gcc --version in console
            jimmydew @Guest
            @Bugsounet
            pi@raspberrypi:~/MagicMirror $ gcc --version
            gcc (Raspbian 7.3.0-19) 7.3.0
            Copyright (C) 2017 Free Software Foundation, Inc.
            This is free software; see the source for copying conditions.  There is NO
            warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
            • E Offline
              electros Project Sponsor @Guest
              @Bugsounet Hi, again. I managed to make my radio station list and everything works fine, just I don’t know how to stop the radio. Can you please explain me how to add a stop radio command?
              Thank you
                A Former User
                 @jimmydew can you do this command for more informations, please ?
                cat /etc/*release
                @electros :
                Good job !
                For stop radio (and other A2D module), i create a feature in AMk2 (A2D Server part)
                You can define your prefered stop command
                by default it’s stop but … it’s depend of your language !
                for exemple in french language, when i say stop, google transcript stoppe
                you have an exemple in AMk2 structure sample
                E J 2 Replies Last reply Reply Quote 0
                • E Offline
                  @Bugsounet OK I understand that but if I configure that “stop” in english for example just I must say " jarvis stop" or “jarvis stop radio” ?
                    A Former User
                    It’s depend what’s google return in transcription
                    for verify what it return
                    You have 2 solutions:
                    1. turn Fullscreen ui , activate jarvis and say stop.
                      AMk2 will display in real time what it understand, so if it display stop, it’s ok
                      en french it display stoppe then i have to modify A2DStopCommand: "stoppe",
                    2. in console and debug mode actived
                      you will see the transcription of google
                      transcription: { transcription: 'stoppe', done: true },
                    notes:
                    • if you say stop and method 1 or 2 result is stop too
                      no A2DStopCommand configuration require
                    • stop command defined in A2DStopCommand stops all process of A2D : weblinks, cast, youtube, radio, photos (and MMM-FreeboxTV for french user)
                    Use:
                    just say jarvis (for activating) … stop (or your prefered A2DStopCommand)
                    • E Offline
                      @Bugsounet OK, thank you
                        jimmydew @Guest
                        @Bugsounet
                        sure:
                        pi@raspberrypi:~/MagicMirror $ cat /etc/*release
                        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                        NAME="Raspbian GNU/Linux"
                        VERSION_ID="10"
                        VERSION="10 (buster)"
                        VERSION_CODENAME=buster
                        ID=raspbian
                        ID_LIKE=debian
                        HOME_URL="http://www.raspbian.org/"
                        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                          A Former User
                          in the raspbian web site i see this:
                          Raspbian Buster with desktop
                          Image with desktop based on Debian Buster
                          Version:February 2020
                          Release date:2020-02-13
                          Kernel version:4.19
                          i don’t know why you are the 5.4.x kernel version and it seams the problem
                          I don’t try to compile it with it so … sorry, i can’t help
                          retry with 4.19.x kernel version
                            jimmydew @Guest
                            @Bugsounet
                            hmm okay, is there a way to change my kernel version??
                              sdetweil @jimmydew
                              @jimmydew load a different version of the OS
                                jimmydew @sdetweil
                                oke thank you but I dont now how I load a diffrent Os
                                  sdetweil @jimmydew
                                  @jimmydew flash the SD card with a different is version
                                    jimmydew @sdetweil
                                    @sdetweil i have done now ive installed MM again and it gives me this on startup,
                                    [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
                                    [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                    Require stack:
                                    - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
                                    - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
                                    - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                                        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                        at Module.require (internal/modules/cjs/loader.js:685:19)
                                        at require (internal/modules/cjs/helpers.js:16:16)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                        at Module.load (internal/modules/cjs/loader.js:645:32) {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: [
                                        '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
                                        '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
                                        '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
                                        '/home/pi/MagicMirror/js/app.js',
                                        '/home/pi/MagicMirror/js/electron.js',
                                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                        undefined
                                    [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
                                    [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
                                    [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
                                    [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
                                    [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
                                    [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
                                    [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
                                    it still not detects my voice, only when i click on the assistant
                                      sdetweil @jimmydew
                                      @jimmydew @Bugsounet will be by to help…
                                        A Former User
                                        I ordered an RPI4, I await the end of delivery for tomorrow.
                                        So I’m going to do a new installation on it.
                                        I come back to you once done
                                          sdetweil @Guest
                                          @Bugsounet use my script…
                                            A Former User
                                            @sdetweil : of course ! it’s planned ! ;)
                                            • 5 / 7
