    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 85.3k Views 25 Watching
    • E Offline
      electros Project Sponsor @Serge
      @Serge Thank you for the link i was looking for a solution like that.
        jimmydew
        Hey everyone, I have a problem with the MMM-assistantMk2:
        The Icon is showing on the mirror, when i click on it in VNC it activates,and works. but it doesnt activate by my voice on the mirror.
        any ideas? these are my configs:
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			     // false, default for all  NON-armv6l devices
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check",
        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        			module: "weatherforecast",
        			header: "Weather Forecast",
        				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: true,
        				broadcastNewsUpdates: true
          module: "MMM-AssistantMk2",
            debug: false,
            ui: "Classic", // Classic2, Classic or Simple
            // if you want Google Nest ui style
            // set Fullscreen ui AND fullscreen_above position
            assistantConfig: {
              projectId: "", // Required to use gaction.
              modelId: "", // (OPTIONAL for gaction)
              instanceId: "", // (OPTIONAL for gaction)
              latitude: 52.0955919,
              longitude: 4.4711253,
            responseConfig: {
              useHTML5: true, // sound render by HTML5
              useScreenOutput: true,
              useAudioOutput: true,
              useChime: true,
              timer: 5000,
              myMagicWord: true,
              //Your prefer sound play program.
              //By example, if you are running this on OSX, `afplay` could be available.
              //by default mpg321 play program is enabled
              //if audio output cutting try with mpg123 or cvlc program
              playProgram: "mpg321",
              chime: {
                beep: "beep.mp3",
                error: "error.mp3",
                continue: "continue.mp3",
                open: "Google_beep_open.mp3",
                close: "Google_beep_close.mp3",
              // false - animated icons, 'standby' - static icons only for standby state, true - all static icons
              useStaticIcons: false
            micConfig: { // put there configuration generated by auto-installer
              recorder: "arecord",
              device: "plughw:1",
            customActionConfig: {
              autoMakeAction: false,
              autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
              actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
            recipes: [ "with-MMM-TelegramBot.js" ],
            profiles: {
              "default": {
                profileFile: "default.json",
                lang: "en-US"
            useA2D: false,
            A2DStopCommand: "stop",
            useSnowboy: true,
            snowboy: {
              audioGain: 2.0,
              Frontend: true,
              Model: "jarvis",
              Sensitivity: null
        (it’s running on raspberry pi 4b)
          A Former User
          useSnowboy: true,
          if you use this feature, you need to update AMk2
          npm run update
          try this in AMk2 directory
          and enable snowboy library (and electron rebuild for snowboy)
            sdetweil @jimmydew
            @jimmydew in the future please use the markdown for code
            select the text and hit the </> icon above the editor
              jimmydew @Guest
              @Bugsounet
              i got quite a few errors on the rebuild:
              ✖ Rebuild Failed
              An unhandled error occurred inside electron-rebuild
              make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                CXX(target) Release/obj.target/snowboy/lib/snowboy.o
              In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
                               from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
                               from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                               from ../../../nan/nan.h:56,
                               from ../lib/snowboy.cc:1:
              /home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
                 declarator __attribute__((deprecated(message)))
              /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                 V8_DEPRECATE_SOON("Use *WithData version.",
              /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
              In file included from ../lib/snowboy.cc:1:
              ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
              ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                   , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
              ../lib/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
              ../lib/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
                 } catch (std::runtime_error e) {
              In file included from ../../../nan/nan.h:56,
              ../lib/snowboy.cc: At global scope:
              /home/pi/.electron-gyp/6.1.7/include/node/node.h:572:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                     (node::addon_register_func) (regfunc),                          \
              /home/pi/.electron-gyp/6.1.7/include/node/node.h:606:3: note: in expansion of macro ‘NODE_MODULE_X’
                 NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
              ../lib/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
               NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
              In file included from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
              /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
              /home/pi/.electron-gyp/6.1.7/include/node/node_object_wrap.h:84:78:   required from here
              /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                              reinterpret_cast<Callback>(callback), type);
              /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
              ../../../nan/nan_object_wrap.h:65:61:   required from here
              /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                SOLINK_MODULE(target) Release/obj.target/snowboy.node
              /usr/bin/ld: cannot find -lcblas
              collect2: error: ld returned 1 exit status
              make: *** [snowboy.target.mk:143: Release/obj.target/snowboy.node] Error 1
              make: Leaving directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
              gyp ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:194:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
              gyp ERR! System Linux 5.4.35-v7l+
              gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm" "--remote_path=./snowboy/v1.4.7/Release/" "--package_name=snowboy-v1.4.7-electron-v6.1-linux-arm.tar.gz" "--host=https://github.com/bugsounet/snowboy"
              gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
              gyp ERR! node -v v10.20.1
              gyp ERR! node-gyp -v v6.1.0
              gyp ERR! not ok
              Failed with exit code: 1
              Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
              gyp ERR! not ok
                  at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:267:84)
                  at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:205:16)
                  at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:156:26)
                  at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                  at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                  at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                  at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                  at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:242:65)
                  at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:143:22)
              > @bugsounet/snowboy@1.4.7 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
              > tsc -p tsconfig.json
              + @bugsounet/snowboy@1.4.7
              added 20 packages from 25 contributors and audited 315 packages in 38.481s
              3 packages are looking for funding
                run `npm fund` for details
              found 6 low severity vulnerabilities
                run `npm audit fix` to fix them, or `npm audit` for details
              @bugsounet/snowboy library installed
                A Former User
                @jimmydew said in MMM-AssistantMk2 (v3):
                Linux 5.4.35-v7l+
                ah …
                and what version of gcc do you use ?
                try gcc --version in console
                  jimmydew @Guest
                  @Bugsounet
                  pi@raspberrypi:~/MagicMirror $ gcc --version
                  gcc (Raspbian 7.3.0-19) 7.3.0
                  Copyright (C) 2017 Free Software Foundation, Inc.
                  This is free software; see the source for copying conditions.  There is NO
                  warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                  • E Offline
                    electros Project Sponsor @Guest
                    @Bugsounet Hi, again. I managed to make my radio station list and everything works fine, just I don’t know how to stop the radio. Can you please explain me how to add a stop radio command?
                    Thank you
                      A Former User
                      @jimmydew can you do this command for more informations, please ?
                      cat /etc/*release
                      @electros :
                      Good job !
                      For stop radio (and other A2D module), i create a feature in AMk2 (A2D Server part)
                      You can define your prefered stop command
                      by default it’s stop but … it’s depend of your language !
                      for exemple in french language, when i say stop, google transcript stoppe
                      you have an exemple in AMk2 structure sample
                      E J 2 Replies Last reply Reply Quote 0
                      • E Offline
                        @Bugsounet OK I understand that but if I configure that “stop” in english for example just I must say " jarvis stop" or “jarvis stop radio” ?
                          A Former User
                          It’s depend what’s google return in transcription
                          for verify what it return
                          You have 2 solutions:
                          1. turn Fullscreen ui , activate jarvis and say stop.
                            AMk2 will display in real time what it understand, so if it display stop, it’s ok
                            en french it display stoppe then i have to modify A2DStopCommand: "stoppe",
                          2. in console and debug mode actived
                            you will see the transcription of google
                            transcription: { transcription: 'stoppe', done: true },
                          notes:
                          • if you say stop and method 1 or 2 result is stop too
                            no A2DStopCommand configuration require
                          • stop command defined in A2DStopCommand stops all process of A2D : weblinks, cast, youtube, radio, photos (and MMM-FreeboxTV for french user)
                          Use:
                          just say jarvis (for activating) … stop (or your prefered A2DStopCommand)
                          • E Offline
                            @Bugsounet OK, thank you
                              jimmydew @Guest
                              @Bugsounet
                              sure:
                              pi@raspberrypi:~/MagicMirror $ cat /etc/*release
                              PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                              NAME="Raspbian GNU/Linux"
                              VERSION_ID="10"
                              VERSION="10 (buster)"
                              VERSION_CODENAME=buster
                              ID=raspbian
                              ID_LIKE=debian
                              HOME_URL="http://www.raspbian.org/"
                              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                A Former User
                                in the raspbian web site i see this:
                                Raspbian Buster with desktop
                                Image with desktop based on Debian Buster
                                Version:February 2020
                                Release date:2020-02-13
                                Kernel version:4.19
                                i don’t know why you are the 5.4.x kernel version and it seams the problem
                                I don’t try to compile it with it so … sorry, i can’t help
                                retry with 4.19.x kernel version
                                  jimmydew @Guest
                                  @Bugsounet
                                  hmm okay, is there a way to change my kernel version??
                                    sdetweil @jimmydew
                                    @jimmydew load a different version of the OS
                                      jimmydew @sdetweil
                                      oke thank you but I dont now how I load a diffrent Os
                                        sdetweil @jimmydew
                                        @jimmydew flash the SD card with a different is version
                                          jimmydew @sdetweil
                                          @sdetweil i have done now ive installed MM again and it gives me this on startup,
                                          [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
                                          [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                                          Require stack:
                                          - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
                                          - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
                                          - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                                              at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                              at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                              at Module.require (internal/modules/cjs/loader.js:685:19)
                                              at require (internal/modules/cjs/helpers.js:16:16)
                                              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                                              at Module._compile (internal/modules/cjs/loader.js:786:30)
                                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                              at Module.load (internal/modules/cjs/loader.js:645:32) {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: [
                                              '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
                                              '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
                                              '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
                                              '/home/pi/MagicMirror/js/app.js',
                                              '/home/pi/MagicMirror/js/electron.js',
                                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                              undefined
                                          [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
                                          [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
                                          [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
                                          [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
                                          [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
                                          [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
                                          [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
                                          it still not detects my voice, only when i click on the assistant
                                            sdetweil @jimmydew
                                            @jimmydew @Bugsounet will be by to help…
                                            • 5 / 7
