    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 109.3k Views 25 Watching
      A Former User
      @electros said in MMM-AssistantMk2 (v3):
      it hides the modules on the screen apart of calendarext
      it’s a know bug of calendarext
      I tried to use that file “with-radio_fr.js” but when I say “cheriefm”
      ah … “cheriefm” is the name of the block (like a landmark)
      the think to say is “mets chérie fm” in the sample.
      you can try to change it for your language with pattern value
      exemple: if you change pattern value to radio test
      if you say : radio test it will reconize the cheriefm command and execute it (send to A2D mp3 link of the radio and img)
      E 2 Replies Last reply
      • E
        electros Project Sponsor @Guest
        @Bugsounet said in MMM-AssistantMk2 (v3):
        okay but couldn’t remain all the modules on the screen behind the assistant window?
        Well I need to practice more with this. for a start I think I should look for another microphone, the assistant doesn’t really understand what I’m saying.
        Do you think a respeaker board with 2 microphones would be better than a USB microphone?
        SergeS 1 Reply Last reply
        • SergeS
          Serge @electros
          One possible solution for mic
          Working on getting a good hardware solution for MMM-AssistantMK2
          E 1 Reply Last reply
          • E
            electros Project Sponsor @Serge
            @Serge Thank you for the link i was looking for a solution like that.
              jimmydew
              Hey everyone, I have a problem with the MMM-assistantMk2:
              The Icon is showing on the mirror, when i click on it in VNC it activates,and works. but it doesnt activate by my voice on the mirror.
              any ideas? these are my configs:
              var config = {
              	port: 8080,
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			     // false, default for all  NON-armv6l devices
              			module: "clock",
              			position: "top_left"
              			header: "US Holidays",
              						symbol: "calendar-check",
              						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
              			module: "compliments",
              			position: "lower_third"
              			module: "currentweather",
              				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			module: "weatherforecast",
              			header: "Weather Forecast",
              				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true,
              				broadcastNewsFeeds: true,
              				broadcastNewsUpdates: true
                module: "MMM-AssistantMk2",
                  debug: false,
                  ui: "Classic", // Classic2, Classic or Simple
                  // if you want Google Nest ui style
                  // set Fullscreen ui AND fullscreen_above position
                  assistantConfig: {
                    projectId: "", // Required to use gaction.
                    modelId: "", // (OPTIONAL for gaction)
                    instanceId: "", // (OPTIONAL for gaction)
                    latitude: 52.0955919,
                    longitude: 4.4711253,
                  responseConfig: {
                    useHTML5: true, // sound render by HTML5
                    useScreenOutput: true,
                    useAudioOutput: true,
                    useChime: true,
                    timer: 5000,
                    myMagicWord: true,
                    //Your prefer sound play program.
                    //By example, if you are running this on OSX, `afplay` could be available.
                    //by default mpg321 play program is enabled
                    //if audio output cutting try with mpg123 or cvlc program
                    playProgram: "mpg321",
                    chime: {
                      beep: "beep.mp3",
                      error: "error.mp3",
                      continue: "continue.mp3",
                      open: "Google_beep_open.mp3",
                      close: "Google_beep_close.mp3",
                    // false - animated icons, 'standby' - static icons only for standby state, true - all static icons
                    useStaticIcons: false
                  micConfig: { // put there configuration generated by auto-installer
                    recorder: "arecord",
                    device: "plughw:1",
                  customActionConfig: {
                    autoMakeAction: false,
                    autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                    actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                  recipes: [ "with-MMM-TelegramBot.js" ],
                  profiles: {
                    "default": {
                      profileFile: "default.json",
                      lang: "en-US"
                  useA2D: false,
                  A2DStopCommand: "stop",
                  useSnowboy: true,
                  snowboy: {
                    audioGain: 2.0,
                    Frontend: true,
                    Model: "jarvis",
                    Sensitivity: null
              (it’s running on raspberry pi 4b)
                A Former User
                useSnowboy: true,
                if you use this feature, you need to update AMk2
                npm run update
                try this in AMk2 directory
                and enable snowboy library (and electron rebuild for snowboy)
                J 1 Reply Last reply
                  sdetweil @jimmydew
                  @jimmydew in the future please use the markdown for code
                  select the text and hit the </> icon above the editor
                    jimmydew @Guest
                    @Bugsounet
                    i got quite a few errors on the rebuild:
                    ✖ Rebuild Failed
                    An unhandled error occurred inside electron-rebuild
                    make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                      CXX(target) Release/obj.target/snowboy/lib/snowboy.o
                    In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
                                     from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
                                     from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                                     from ../../../nan/nan.h:56,
                                     from ../lib/snowboy.cc:1:
                    /home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
                       declarator __attribute__((deprecated(message)))
                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                       V8_DEPRECATE_SOON("Use *WithData version.",
                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
                    In file included from ../lib/snowboy.cc:1:
                    ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
                    ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
                    ../lib/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
                    ../lib/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
                       } catch (std::runtime_error e) {
                    In file included from ../../../nan/nan.h:56,
                    ../lib/snowboy.cc: At global scope:
                    /home/pi/.electron-gyp/6.1.7/include/node/node.h:572:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                           (node::addon_register_func) (regfunc),                          \
                    /home/pi/.electron-gyp/6.1.7/include/node/node.h:606:3: note: in expansion of macro ‘NODE_MODULE_X’
                       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                    ../lib/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
                     NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
                    In file included from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
                    /home/pi/.electron-gyp/6.1.7/include/node/node_object_wrap.h:84:78:   required from here
                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                                    reinterpret_cast<Callback>(callback), type);
                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
                    ../../../nan/nan_object_wrap.h:65:61:   required from here
                    /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                      SOLINK_MODULE(target) Release/obj.target/snowboy.node
                    /usr/bin/ld: cannot find -lcblas
                    collect2: error: ld returned 1 exit status
                    make: *** [snowboy.target.mk:143: Release/obj.target/snowboy.node] Error 1
                    make: Leaving directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                    gyp ERR! build error
                    gyp ERR! stack Error: `make` failed with exit code: 2
                    gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:194:23)
                    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
                    gyp ERR! System Linux 5.4.35-v7l+
                    gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm" "--remote_path=./snowboy/v1.4.7/Release/" "--package_name=snowboy-v1.4.7-electron-v6.1-linux-arm.tar.gz" "--host=https://github.com/bugsounet/snowboy"
                    gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
                    gyp ERR! node -v v10.20.1
                    gyp ERR! node-gyp -v v6.1.0
                    gyp ERR! not ok
                    Failed with exit code: 1
                    Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
                    gyp ERR! not ok
                        at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:267:84)
                        at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:205:16)
                        at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:156:26)
                        at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                        at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                        at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
                        at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
                        at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:242:65)
                        at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:143:22)
                    > @bugsounet/snowboy@1.4.7 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
                    > tsc -p tsconfig.json
                    + @bugsounet/snowboy@1.4.7
                    added 20 packages from 25 contributors and audited 315 packages in 38.481s
                    3 packages are looking for funding
                      run `npm fund` for details
                    found 6 low severity vulnerabilities
                      run `npm audit fix` to fix them, or `npm audit` for details
                    @bugsounet/snowboy library installed
                      A Former User
                      @jimmydew said in MMM-AssistantMk2 (v3):
                      Linux 5.4.35-v7l+
                      ah …
                      and what version of gcc do you use ?
                      try gcc --version in console
                        jimmydew @Guest
                        @Bugsounet
                        pi@raspberrypi:~/MagicMirror $ gcc --version
                        gcc (Raspbian 7.3.0-19) 7.3.0
                        Copyright (C) 2017 Free Software Foundation, Inc.
                        This is free software; see the source for copying conditions.  There is NO
                        warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
                        • E
                          @Bugsounet Hi, again. I managed to make my radio station list and everything works fine, just I don’t know how to stop the radio. Can you please explain me how to add a stop radio command?
                          Thank you
                            A Former User
                             @jimmydew can you do this command for more informations, please ?
                            cat /etc/*release
                            @electros :
                            Good job !
                            For stop radio (and other A2D module), i create a feature in AMk2 (A2D Server part)
                            You can define your prefered stop command
                            by default it’s stop but … it’s depend of your language !
                            for exemple in french language, when i say stop, google transcript stoppe
                            you have an exemple in AMk2 structure sample
                            E J 2 Replies Last reply
                            • E
                              @Bugsounet OK I understand that but if I configure that “stop” in english for example just I must say " jarvis stop" or “jarvis stop radio” ?
                                A Former User
                                It’s depend what’s google return in transcription
                                for verify what it return
                                You have 2 solutions:
                                1. turn Fullscreen ui , activate jarvis and say stop.
                                  AMk2 will display in real time what it understand, so if it display stop, it’s ok
                                  en french it display stoppe then i have to modify A2DStopCommand: "stoppe",
                                2. in console and debug mode actived
                                  you will see the transcription of google
                                  transcription: { transcription: 'stoppe', done: true },
                                notes:
                                • if you say stop and method 1 or 2 result is stop too
                                  no A2DStopCommand configuration require
                                • stop command defined in A2DStopCommand stops all process of A2D : weblinks, cast, youtube, radio, photos (and MMM-FreeboxTV for french user)
                                Use:
                                just say jarvis (for activating) … stop (or your prefered A2DStopCommand)
                                • E
                                  @Bugsounet OK, thank you
                                    jimmydew @Guest
                                    @Bugsounet
                                    sure:
                                    pi@raspberrypi:~/MagicMirror $ cat /etc/*release
                                    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                    NAME="Raspbian GNU/Linux"
                                    VERSION_ID="10"
                                    VERSION="10 (buster)"
                                    VERSION_CODENAME=buster
                                    ID=raspbian
                                    ID_LIKE=debian
                                    HOME_URL="http://www.raspbian.org/"
                                    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                      A Former User
                                      in the raspbian web site i see this:
                                      Raspbian Buster with desktop
                                      Image with desktop based on Debian Buster
                                      Version:February 2020
                                      Release date:2020-02-13
                                      Kernel version:4.19
                                      i don’t know why you are the 5.4.x kernel version and it seams the problem
                                      I don’t try to compile it with it so … sorry, i can’t help
                                      retry with 4.19.x kernel version
                                        jimmydew @Guest
                                        @Bugsounet
                                        hmm okay, is there a way to change my kernel version??
                                          sdetweil @jimmydew
                                          @jimmydew load a different version of the OS
                                            jimmydew @sdetweil
                                            oke thank you but I dont now how I load a diffrent Os
                                            • 5 / 7
