    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 102.5k Views 25 Watching
    • E Offline
      electros Project Sponsor @Guest
      @Bugsounet OK I understand that but if I configure that “stop” in english for example just I must say " jarvis stop" or “jarvis stop radio” ?
        [[global:former-user]]
        It’s depend what’s google return in transcription
        for verify what it return
        You have 2 solutions:
        1. turn Fullscreen ui , activate jarvis and say stop.
          AMk2 will display in real time what it understand, so if it display stop, it’s ok
          en french it display stoppe then i have to modify A2DStopCommand: "stoppe",
        2. in console and debug mode actived
          you will see the transcription of google
          transcription: { transcription: 'stoppe', done: true },
        notes:
        • if you say stop and method 1 or 2 result is stop too
          no A2DStopCommand configuration require
        • stop command defined in A2DStopCommand stops all process of A2D : weblinks, cast, youtube, radio, photos (and MMM-FreeboxTV for french user)
        Use:
        just say jarvis (for activating) … stop (or your prefered A2DStopCommand)
        • E Offline
          @Bugsounet OK, thank you
            jimmydew @Guest
            @Bugsounet
            sure:
            pi@raspberrypi:~/MagicMirror $ cat /etc/*release
            PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="10"
            VERSION="10 (buster)"
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
              gyp ERR! System Linux 5.4.35-v7l+
              in the raspbian web site i see this:
              Raspbian Buster with desktop
              Image with desktop based on Debian Buster
              Version:February 2020
              Release date:2020-02-13
              Kernel version:4.19
              i don’t know why you are the 5.4.x kernel version and it seams the problem
              I don’t try to compile it with it so … sorry, i can’t help
              retry with 4.19.x kernel version
                jimmydew @Guest
                @Bugsounet
                hmm okay, is there a way to change my kernel version??
                  sdetweil @jimmydew
                  @jimmydew load a different version of the OS
                    jimmydew @sdetweil
                    oke thank you but I dont now how I load a diffrent Os
                      sdetweil @jimmydew
                      @jimmydew flash the SD card with a different is version
                        jimmydew @sdetweil
                        @sdetweil i have done now ive installed MM again and it gives me this on startup,
                        [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
                        [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                        Require stack:
                        - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
                        - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
                        - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                            at Module.require (internal/modules/cjs/loader.js:685:19)
                            at require (internal/modules/cjs/helpers.js:16:16)
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                            at Module._compile (internal/modules/cjs/loader.js:786:30)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                            at Module.load (internal/modules/cjs/loader.js:645:32) {
                          code: 'MODULE_NOT_FOUND',
                          requireStack: [
                            '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
                            '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
                            '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
                            '/home/pi/MagicMirror/js/app.js',
                            '/home/pi/MagicMirror/js/electron.js',
                            '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                            undefined
                        [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                        [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                        [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
                        [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
                        [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
                        [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
                        [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
                        [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
                        [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
                        it still not detects my voice, only when i click on the assistant
                          sdetweil @jimmydew
                          @jimmydew @Bugsounet will be by to help…
                            I ordered an RPI4, I await the end of delivery for tomorrow.
                            So I’m going to do a new installation on it.
                            I come back to you once done
                              sdetweil @Guest
                              @Bugsounet use my script…
                                @sdetweil : of course ! it’s planned ! ;)
                                  yeah, I receive my RPI, SD card but missing : RPI case, fan and power supply
                                  It’s the second order and it’s will be deliver tomorrow ;)
                                  Note: ahahah, I have no RPI for developping !!!
                                  • L Offline
                                    Lasmazze
                                    Hi everyone!
                                    The module works very well. Good work!
                                    I just have a request:
                                    When I say “JARVIS” I would like the sound to be cut or lowered to the minimum if not the assistant records what it is broadcasting like the radio or a youtube video. When I finish talking to the assistant, I would like the sound to come back as it was before.
                                    Thank you in advance for your help!
                                      @jimmydew : i confirm there is a bug in my installer. (missing 2 library, I say “bravo !” in French)
                                      I correct it ;)
                                      in AMk2 directory retry with:
                                      npm run update
                                      and do all process
                                      It should work now
                                      • T Offline
                                        triguyrn
                                        What microphone/speaker are you all using?
                                        Looking to add voice control to my mirror as well!
                                          sdetweil @triguyrn
                                          @triguyrn I use a Logitech C270 webcam, and also just added a PlayStation Eye webcam to one of them
                                          • Cr4z33C Offline
                                            Cr4z33 @Guest
                                            @Bugsounet I’ve turner on my MagicMirror after a stop of 6 months.
                                            At first I ran sudo apt-get update && sudo apt-get upgrade, then I updated both MM and its modules.
                                            Now MM it ends up with a black screen.
                                            So I ran npm run update in MMM-AssistantMk2 folder and answered Yes to all the answers.
                                            I still keep getting the black screen at the end of MM loading.
                                            What shall I do next now? :smiling_face_with_open_mouth_cold_sweat:
                                            Here’s what happening:
                                            > magicmirror@2.11.0 start /home/pi/MagicMirror
                                            [2020-05-22 08:14:49.750] [LOG]    Starting MagicMirror: v2.11.0
                                            [2020-05-22 08:14:49.763] [LOG]    Loading config ...
                                            [2020-05-22 08:14:49.776] [LOG]    Loading module helpers ...
                                            [2020-05-22 08:14:49.792] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:49.794] [LOG]    Module helper loaded: MMM-WatchDog
                                            [2020-05-22 08:14:49.926] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:49.927] [LOG]    Module helper loaded: MMM-Remote-Control
                                            [2020-05-22 08:14:51.650] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:51.651] [LOG]    Module helper loaded: MMM-RTSPStream
                                            [2020-05-22 08:14:51.652] [LOG]    No helper found for module: alert.
                                            [2020-05-22 08:14:51.717] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:51.718] [LOG]    Module helper loaded: updatenotification
                                            [2020-05-22 08:14:51.780] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:51.781] [LOG]    Module helper loaded: newsfeed
                                            [2020-05-22 08:14:53.984] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:53.985] [LOG]    Module helper loaded: MMM-AssistantMk2
                                            [2020-05-22 08:14:53.986] [LOG]    No helper found for module: clock.
                                            [2020-05-22 08:14:54.001] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:54.002] [LOG]    Module helper loaded: MMM-Spotify
                                            [2020-05-22 08:14:54.583] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:54.584] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                            [2020-05-22 08:14:55.464] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.465] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                                            [2020-05-22 08:14:55.472] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
                                            Require stack:
                                            - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                                            [2020-05-22 08:14:55.473] [LOG]    Loading module helpers ...
                                            [2020-05-22 08:14:55.484] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.486] [LOG]    Module helper loaded: MMM-WatchDog
                                            [2020-05-22 08:14:55.486] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.487] [LOG]    Module helper loaded: MMM-Remote-Control
                                            [2020-05-22 08:14:55.488] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.489] [LOG]    Module helper loaded: MMM-RTSPStream
                                            [2020-05-22 08:14:55.490] [LOG]    No helper found for module: alert.
                                            [2020-05-22 08:14:55.491] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.492] [LOG]    Module helper loaded: updatenotification
                                            [2020-05-22 08:14:55.493] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.494] [LOG]    Module helper loaded: newsfeed
                                            [2020-05-22 08:14:55.497] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.500] [LOG]    Module helper loaded: MMM-AssistantMk2
                                            [2020-05-22 08:14:55.502] [LOG]    No helper found for module: clock.
                                            [2020-05-22 08:14:55.504] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.505] [LOG]    Module helper loaded: MMM-Spotify
                                            [2020-05-22 08:14:55.507] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.509] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                            [2020-05-22 08:14:55.510] [LOG]    Initializing new module helper ...
                                            [2020-05-22 08:14:55.512] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                                            [2020-05-22 08:14:55.517] [ERROR]  App threw an error during load
                                            [2020-05-22 08:14:55.519] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                                            Require stack:
                                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
                                            [2020-05-22 08:14:55.522] [LOG]    Whoops! There was an uncaught exception...
                                            [2020-05-22 08:14:55.523] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                                            Require stack:
                                              requireStack: [
                                                '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                                                undefined
                                            [2020-05-22 08:14:55.542] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            [2020-05-22 08:14:55.546] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                                            [2020-05-22 08:14:55.768] [LOG]    Launching application.
                                            • 5 / 7
