    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      jimmydew @Guest
      @Bugsounet
      sure:
      pi@raspberrypi:~/MagicMirror $ cat /etc/*release
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        A Former User
        gyp ERR! System Linux 5.4.35-v7l+
        in the raspbian web site i see this:
        Raspbian Buster with desktop
        Image with desktop based on Debian Buster
        Version:February 2020
        Release date:2020-02-13
        Kernel version:4.19
        i don’t know why you are the 5.4.x kernel version and it seams the problem
        I don’t try to compile it with it so … sorry, i can’t help
        retry with 4.19.x kernel version
          jimmydew @Guest
          @Bugsounet
          hmm okay, is there a way to change my kernel version??
            sdetweil @jimmydew
            @jimmydew load a different version of the OS
              jimmydew @sdetweil
              oke thank you but I dont now how I load a diffrent Os
                sdetweil @jimmydew
                @jimmydew flash the SD card with a different is version
                  jimmydew @sdetweil
                  @sdetweil i have done now ive installed MM again and it gives me this on startup,
                  [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
                  [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                  Require stack:
                  - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
                  - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
                  - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                      at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
                      '/home/pi/MagicMirror/js/app.js',
                      '/home/pi/MagicMirror/js/electron.js',
                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      undefined
                  [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
                  [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
                  [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
                  [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
                  [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
                  [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
                  [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
                  it still not detects my voice, only when i click on the assistant
                    sdetweil @jimmydew
                    @jimmydew @Bugsounet will be by to help…
                      A Former User
                      I ordered an RPI4, I await the end of delivery for tomorrow.
                      So I’m going to do a new installation on it.
                      I come back to you once done
                        sdetweil @Guest
                        @Bugsounet use my script…
                          A Former User
                          @sdetweil : of course ! it’s planned ! ;)
                            A Former User
                            yeah, I receive my RPI, SD card but missing : RPI case, fan and power supply
                            It’s the second order and it’s will be deliver tomorrow ;)
                            Note: ahahah, I have no RPI for developping !!!
                            • L
                              Lasmazze
                              Hi everyone!
                              The module works very well. Good work!
                              I just have a request:
                              When I say “JARVIS” I would like the sound to be cut or lowered to the minimum if not the assistant records what it is broadcasting like the radio or a youtube video. When I finish talking to the assistant, I would like the sound to come back as it was before.
                              Thank you in advance for your help!
                                A Former User
                                @jimmydew : i confirm there is a bug in my installer. (missing 2 library, I say “bravo !” in French)
                                I correct it ;)
                                in AMk2 directory retry with:
                                npm run update
                                and do all process
                                It should work now
                                • T
                                  triguyrn
                                  What microphone/speaker are you all using?
                                  Looking to add voice control to my mirror as well!
                                    sdetweil @triguyrn
                                    @triguyrn I use a Logitech C270 webcam, and also just added a PlayStation Eye webcam to one of them
                                    • Cr4z33C
                                      Cr4z33 @Guest
                                      @Bugsounet I’ve turner on my MagicMirror after a stop of 6 months.
                                      At first I ran sudo apt-get update && sudo apt-get upgrade, then I updated both MM and its modules.
                                      Now MM it ends up with a black screen.
                                      So I ran npm run update in MMM-AssistantMk2 folder and answered Yes to all the answers.
                                      I still keep getting the black screen at the end of MM loading.
                                      What shall I do next now? :smiling_face_with_open_mouth_cold_sweat:
                                      Here’s what happening:
                                      > magicmirror@2.11.0 start /home/pi/MagicMirror
                                      [2020-05-22 08:14:49.750] [LOG]    Starting MagicMirror: v2.11.0
                                      [2020-05-22 08:14:49.763] [LOG]    Loading config ...
                                      [2020-05-22 08:14:49.776] [LOG]    Loading module helpers ...
                                      [2020-05-22 08:14:49.792] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:49.794] [LOG]    Module helper loaded: MMM-WatchDog
                                      [2020-05-22 08:14:49.926] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:49.927] [LOG]    Module helper loaded: MMM-Remote-Control
                                      [2020-05-22 08:14:51.650] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:51.651] [LOG]    Module helper loaded: MMM-RTSPStream
                                      [2020-05-22 08:14:51.652] [LOG]    No helper found for module: alert.
                                      [2020-05-22 08:14:51.717] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:51.718] [LOG]    Module helper loaded: updatenotification
                                      [2020-05-22 08:14:51.780] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:51.781] [LOG]    Module helper loaded: newsfeed
                                      [2020-05-22 08:14:53.984] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:53.985] [LOG]    Module helper loaded: MMM-AssistantMk2
                                      [2020-05-22 08:14:53.986] [LOG]    No helper found for module: clock.
                                      [2020-05-22 08:14:54.001] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:54.002] [LOG]    Module helper loaded: MMM-Spotify
                                      [2020-05-22 08:14:54.583] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:54.584] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                      [2020-05-22 08:14:55.464] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.465] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                                      [2020-05-22 08:14:55.472] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
                                      Require stack:
                                      - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                                      [2020-05-22 08:14:55.473] [LOG]    Loading module helpers ...
                                      [2020-05-22 08:14:55.484] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.486] [LOG]    Module helper loaded: MMM-WatchDog
                                      [2020-05-22 08:14:55.486] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.487] [LOG]    Module helper loaded: MMM-Remote-Control
                                      [2020-05-22 08:14:55.488] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.489] [LOG]    Module helper loaded: MMM-RTSPStream
                                      [2020-05-22 08:14:55.490] [LOG]    No helper found for module: alert.
                                      [2020-05-22 08:14:55.491] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.492] [LOG]    Module helper loaded: updatenotification
                                      [2020-05-22 08:14:55.493] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.494] [LOG]    Module helper loaded: newsfeed
                                      [2020-05-22 08:14:55.497] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.500] [LOG]    Module helper loaded: MMM-AssistantMk2
                                      [2020-05-22 08:14:55.502] [LOG]    No helper found for module: clock.
                                      [2020-05-22 08:14:55.504] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.505] [LOG]    Module helper loaded: MMM-Spotify
                                      [2020-05-22 08:14:55.507] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.509] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                      [2020-05-22 08:14:55.510] [LOG]    Initializing new module helper ...
                                      [2020-05-22 08:14:55.512] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                                      [2020-05-22 08:14:55.517] [ERROR]  App threw an error during load
                                      [2020-05-22 08:14:55.519] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                                      Require stack:
                                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
                                      [2020-05-22 08:14:55.522] [LOG]    Whoops! There was an uncaught exception...
                                      [2020-05-22 08:14:55.523] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                                      Require stack:
                                        requireStack: [
                                          '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                                          undefined
                                      [2020-05-22 08:14:55.542] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      [2020-05-22 08:14:55.546] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                                      [2020-05-22 08:14:55.768] [LOG]    Launching application.
                                        A Former User
                                        @Cr4z33: just because this errror is not related to MMM-AssistantMk2 module ;)
                                        • Cr4z33C
                                          Cr4z33 @Guest
                                          @Bugsounet oops sorry then! 😅
                                          • A
                                            acowx
                                            I am trying to work out how I can use MMM-AssistantMk2 to voice control the MMM-CalendarExt2 module.
                                            My basic needs are to use a voice command to notify MMM-CalendarExt2 to swap to another view.
                                            eg, I say “[wakeword] scene monthly” and the Calendar Module will swap to a scene which shows my Monthly calendar view.
                                            Or I say “[wakeword] scene weekly” and the Calendar Module will swap to a scene which shows my Weekly calendar view.
                                            I have considered TelegramBot but I don’t think that is triggered by a voice command ?
                                            Any ideas guys ?
                                            • 5 / 7
