    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
    • E
      electros Project Sponsor @Guest
      @Bugsounet OK, thank you
        jimmydew @Guest
        @Bugsounet
        sure:
        pi@raspberrypi:~/MagicMirror $ cat /etc/*release
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
          A Former User
          gyp ERR! System Linux 5.4.35-v7l+
          in the raspbian web site i see this:
          Raspbian Buster with desktop
          Image with desktop based on Debian Buster
          Version:February 2020
          Release date:2020-02-13
          Kernel version:4.19
          i don’t know why you are the 5.4.x kernel version and it seams the problem
          I don’t try to compile it with it so … sorry, i can’t help
          retry with 4.19.x kernel version
            jimmydew @Guest
            @Bugsounet
            hmm okay, is there a way to change my kernel version??
              sdetweil @jimmydew
              @jimmydew load a different version of the OS
                jimmydew @sdetweil
                oke thank you but I dont now how I load a diffrent Os
                  sdetweil @jimmydew
                  @jimmydew flash the SD card with a different is version
                    jimmydew @sdetweil
                    @sdetweil i have done now ive installed MM again and it gives me this on startup,
                    [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
                    [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                    Require stack:
                    - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
                    - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
                    - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                        at Module.require (internal/modules/cjs/loader.js:685:19)
                        at require (internal/modules/cjs/helpers.js:16:16)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                        at Module.load (internal/modules/cjs/loader.js:645:32) {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: [
                        '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
                        '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
                        '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
                        '/home/pi/MagicMirror/js/app.js',
                        '/home/pi/MagicMirror/js/electron.js',
                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                        undefined
                    [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                    [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
                    [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
                    [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
                    [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
                    [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
                    [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
                    [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
                    it still not detects my voice, only when i click on the assistant
                      sdetweil @jimmydew
                      @jimmydew @Bugsounet will be by to help…
                        A Former User
                        I ordered an RPI4, I await the end of delivery for tomorrow.
                        So I’m going to do a new installation on it.
                        I come back to you once done
                          sdetweil @Guest
                          @Bugsounet use my script…
                            A Former User
                            @sdetweil : of course ! it’s planned ! ;)
                              A Former User
                              yeah, I receive my RPI, SD card but missing : RPI case, fan and power supply
                              It’s the second order and it’s will be deliver tomorrow ;)
                              Note: ahahah, I have no RPI for developping !!!
                              • L
                                Lasmazze
                                Hi everyone!
                                The module works very well. Good work!
                                I just have a request:
                                When I say “JARVIS” I would like the sound to be cut or lowered to the minimum if not the assistant records what it is broadcasting like the radio or a youtube video. When I finish talking to the assistant, I would like the sound to come back as it was before.
                                Thank you in advance for your help!
                                  A Former User
                                  @jimmydew : i confirm there is a bug in my installer. (missing 2 library, I say “bravo !” in French)
                                  I correct it ;)
                                  in AMk2 directory retry with:
                                  npm run update
                                  and do all process
                                  It should work now
                                  • T
                                    triguyrn
                                    What microphone/speaker are you all using?
                                    Looking to add voice control to my mirror as well!
                                      sdetweil @triguyrn
                                      @triguyrn I use a Logitech C270 webcam, and also just added a PlayStation Eye webcam to one of them
                                      • Cr4z33C
                                        Cr4z33 @Guest
                                        @Bugsounet I’ve turner on my MagicMirror after a stop of 6 months.
                                        At first I ran sudo apt-get update && sudo apt-get upgrade, then I updated both MM and its modules.
                                        Now MM it ends up with a black screen.
                                        So I ran npm run update in MMM-AssistantMk2 folder and answered Yes to all the answers.
                                        I still keep getting the black screen at the end of MM loading.
                                        What shall I do next now? :smiling_face_with_open_mouth_cold_sweat:
                                        Here’s what happening:
                                        > magicmirror@2.11.0 start /home/pi/MagicMirror
                                        [2020-05-22 08:14:49.750] [LOG]    Starting MagicMirror: v2.11.0
                                        [2020-05-22 08:14:49.763] [LOG]    Loading config ...
                                        [2020-05-22 08:14:49.776] [LOG]    Loading module helpers ...
                                        [2020-05-22 08:14:49.792] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:49.794] [LOG]    Module helper loaded: MMM-WatchDog
                                        [2020-05-22 08:14:49.926] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:49.927] [LOG]    Module helper loaded: MMM-Remote-Control
                                        [2020-05-22 08:14:51.650] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:51.651] [LOG]    Module helper loaded: MMM-RTSPStream
                                        [2020-05-22 08:14:51.652] [LOG]    No helper found for module: alert.
                                        [2020-05-22 08:14:51.717] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:51.718] [LOG]    Module helper loaded: updatenotification
                                        [2020-05-22 08:14:51.780] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:51.781] [LOG]    Module helper loaded: newsfeed
                                        [2020-05-22 08:14:53.984] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:53.985] [LOG]    Module helper loaded: MMM-AssistantMk2
                                        [2020-05-22 08:14:53.986] [LOG]    No helper found for module: clock.
                                        [2020-05-22 08:14:54.001] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:54.002] [LOG]    Module helper loaded: MMM-Spotify
                                        [2020-05-22 08:14:54.583] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:54.584] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                        [2020-05-22 08:14:55.464] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.465] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                                        [2020-05-22 08:14:55.472] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
                                        Require stack:
                                        - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                                        [2020-05-22 08:14:55.473] [LOG]    Loading module helpers ...
                                        [2020-05-22 08:14:55.484] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.486] [LOG]    Module helper loaded: MMM-WatchDog
                                        [2020-05-22 08:14:55.486] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.487] [LOG]    Module helper loaded: MMM-Remote-Control
                                        [2020-05-22 08:14:55.488] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.489] [LOG]    Module helper loaded: MMM-RTSPStream
                                        [2020-05-22 08:14:55.490] [LOG]    No helper found for module: alert.
                                        [2020-05-22 08:14:55.491] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.492] [LOG]    Module helper loaded: updatenotification
                                        [2020-05-22 08:14:55.493] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.494] [LOG]    Module helper loaded: newsfeed
                                        [2020-05-22 08:14:55.497] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.500] [LOG]    Module helper loaded: MMM-AssistantMk2
                                        [2020-05-22 08:14:55.502] [LOG]    No helper found for module: clock.
                                        [2020-05-22 08:14:55.504] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.505] [LOG]    Module helper loaded: MMM-Spotify
                                        [2020-05-22 08:14:55.507] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.509] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                                        [2020-05-22 08:14:55.510] [LOG]    Initializing new module helper ...
                                        [2020-05-22 08:14:55.512] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                                        [2020-05-22 08:14:55.517] [ERROR]  App threw an error during load
                                        [2020-05-22 08:14:55.519] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                                        Require stack:
                                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
                                        [2020-05-22 08:14:55.522] [LOG]    Whoops! There was an uncaught exception...
                                        [2020-05-22 08:14:55.523] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                                        Require stack:
                                          requireStack: [
                                            '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                                            undefined
                                        [2020-05-22 08:14:55.542] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        [2020-05-22 08:14:55.546] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                                        [2020-05-22 08:14:55.768] [LOG]    Launching application.
                                          A Former User
                                          @Cr4z33: just because this errror is not related to MMM-AssistantMk2 module ;)
                                          • Cr4z33C
                                            Cr4z33 @Guest
                                            @Bugsounet oops sorry then! 😅
                                            • 5 / 7
